09-22-2008, 01:22 PM | #26 | |
Active Member
Re: shudders at 70
The one that I fought for months, was balanced and checked at least 2 times. I finally got some different brand tires and problem went away. Keep us posted. |
09-22-2008, 08:30 PM | #27 |
laying low
Re: shudders at 70
It would be great if you can find a tire shop that can spin balance the tires ON the truck. That could help narrow it down. Some people like that kind of balance as it balances the tire, wheel, rotor and hub as one.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
09-23-2008, 06:57 AM | #28 |
Re: shudders at 70
I would try to find a complete set of tires that you could swap onto the truck for a trial or swap them out one at a time with a spare or any known good tire.
Tim |
10-01-2008, 09:48 PM | #29 |
Re: shudders at 70
Gary - have you figured this out yet?
10-01-2008, 09:57 PM | #30 |
Keepin it runnin!
Re: shudders at 70
Jack up the rear of the truck real solid. Start the engine, put her in gear so the rear tires spin. Look at the rims and see if any are bent. Your initial post said a shutter, so if I had a shutter, which I did recently, it was a bent rim.
If you have an assistant, have them rev it until you see if the rear starts moving in any bad way. If you get nothing, then I'd check the front rims and see if one of them is bent. Frank
1970 K-5 4X4 Blazer 1970 K-20 4X4 Long Bed "Liberty Means Responsibility, that is why most men dread it" |
12-12-2008, 11:31 PM | #31 |
Re: shudders at 70
Sorry it took so long, but after everything else i changed the flywheel and that fixed the problem. Did not look bad but changing it did fix the problem . Thanks for all the input and maybe this can help someone else. Gary
