09-14-2008, 11:29 PM | #26 |
Re: what did you get done for your truck this weekend?
I got some new headers hooked up, and decided to go ahead and do the plugs, and plug wires while I was at it.
It's sweet, no more exhaust leaks!!! Greg |
09-14-2008, 11:40 PM | #27 |
saweet guys, sounds like you all got quite a bit done on your trucks too. next weekend i plan to do very little with mine except drive it and take lots of pictures at the car show im attending.
09-15-2008, 12:07 AM | #28 |
Sisyphus was my mentor!
The Army has posted me to my home province & so I'm able to work on my trucks again... SO I woke my green 67 from its almost 3 year sleep at my uncles farm & drove it home. I then installed LED backup & brake lights from 724x4a/cchevy. They look really cool & wow are they bright...
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
09-15-2008, 01:09 AM | #29 |
Did a top end overhaul. Discovered that the truck had two different heads on it, a 487 casting and an original 441 casting, but the 441 head had bad valve guides. So I just replaced both heads with some GM crate engine ones.
Unfortunately the engine runs rough now. Still have to get it dialed in. |
09-15-2008, 02:11 AM | #30 |
1969 Short, Fleet, and Beat
I've had the truck over a year now and I washed her fo the first time (I know, pretty sad huh).
I finally hung up some cabinets in the garage and cleared the way so I can now put her under a roof, hurray! |
09-15-2008, 04:48 AM | #31 |
got both window reg. in, extended the brake piston rod, cable throttle mod, replaced a hood hinge, cleaned out the cowl,removed heater core, and bleed the brakes
09-15-2008, 06:42 AM | #32 |
Keepin it runnin!
Cleaned all the old caulk out of the drip rail (felt like a dentist), POR-15'd it and put in the new 3M seam sealer stuff. Clean up and paint some time this week.
Frank
1970 K-5 4X4 Blazer 1970 K-20 4X4 Long Bed "Liberty Means Responsibility, that is why most men dread it" Last edited by Old Chevy Mech; 09-15-2008 at 06:43 AM. |
09-15-2008, 07:16 AM | #33 | |
The Older Generation
LockDoc
09-15-2008, 09:50 AM | #34 |
i will have to join the "front end removal team" also. then I had my little boss get things squared away on the inside, so he could tell me what i needed to get done with next . then he told what tools to hand him to get his front end back in great working condition i told him i think he needed new ball joints, he told me that was not the problem
Lug Nuts Classic Rides. (Bodywork, small fab, and Restorations) Perry, Ok. We're just two guys, trying our best. 72 cheyenne super https://67-72chevytrucks.com/vboard/...d.php?t=811512 55 chevy truck http://67-72chevytrucks.com/vboard/s...d.php?t=840174 |
09-15-2008, 10:07 AM | #35 |
Looks like he lost a couple tie rods to me?
...and he really needs to use jack stands if he's going to be under that thing!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 09-15-2008 at 10:08 AM. |
09-15-2008, 05:17 PM | #36 |
Middle-aged Curmudgeon
I finished installing a complete '93 serpentine drive on the front of my 350.
Also completed some research on POA air conditioners. Getting ready to restore my air and didn't exactly know how they worked. Made a run to my local Pick 'n' Pull and scored some 8-lug steelies. And while I was there, I happened onto a Turbo 400 already pulled and just sitting on the ground, as if waiting for me to load it up in my wheelbarrow and trundle it outta there, which I did. |
09-15-2008, 05:58 PM | #37 |
new dimmer switch, replaced the seat, clips on the window levers, new brake pedal and washed it
~Nora '69 Chevy C20 350/TH350 LWB '99 TJ Sport '07 Dodge Caliber www.myspace.com/jeeplvr79 |
09-15-2008, 06:26 PM | #38 |
Nvrsatisifeid, you are raising a true car guy there. Those are cool pics!
------------------------------------------------- Jim Garage fillers... 85 Chevy C10 Silverado LWB 07 Nissan Altima 2006 Mini Cooper S |
09-15-2008, 07:03 PM | #39 |
I went all out and replaced my Flasher. Yeah I know what you all are thinking. This guy must be a Mechanic God. Nope, I am just one man that now has working blinkers.
09-16-2008, 02:19 AM | #40 |
Hey 72 cheyenne pdx do you work at the airport "PDX"
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" |
09-16-2008, 10:00 AM | #41 |
Next project: 1970 K10
Nothing.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
09-16-2008, 11:38 AM | #42 |
well after a couple of month of researching and pondering I finally opened up my 700r4 that I bought 3 months ago and did the 2 wire solenoid to normally open switch wiring and then cracked opent the tail shaft housing to convert the electric speedo to mechanical, talk about pulling hair out!!. then I e sniped some 2" front drop srings for 2.20!!! sweet deal and won another auction for 67 only radio knobs. now to find a working radio... (hint hint)
I also won a new hayden 16" fan for 10.00 to convert to electric my buddys 60 chevy 3/4 ton lifted. all this and I just got elbow surgery last wednesday. (i cant stay still) nversatisfied: thats classic man, I wish I had a boy to play in the garage with me, I`m working on converting my baby girl to a tomboy, she already lost my 3/8 drive socket set. (took after dad on that one . )
1967custom Last edited by michael bustamante; 09-16-2008 at 11:47 AM. |
09-16-2008, 12:18 PM | #43 | |
09-16-2008, 06:35 PM | #44 |
This weekend i got the front bumper shaved. I used 1/2" sq. stock to plug weld the bumper holes left by the bolts. I left enough on the back side so that I could use those to affix the bumper to the original mounting points.Once i know for sure it's ready for a final mount, I will then plug weld those pieces to the mounts. Then i can spread some filler to fix the lows left by the plugging. I'm still not ruling out using a donor bumper to do a cut and splice. anyone got an extra?
09-17-2008, 06:36 AM | #45 | |
Keepin it runnin!
It was the 3M stuff, 8361. I went to "West Marine" supply and purchased those empty caulk tubes where you can put anything in them, cut the foil pack, stuffed the end in and squeezed it into the caulk tube. I used it just like caulk then, and resealed the tube when done. I originally bought 2 foil packs, I would up only using the one. The stuff reacted just like the instructions say, except in my opinion you are not going to effectively "brush" the stuff on! I simply masked the area off, spread/smoothed it with my finger. I pulled the tape/masking immediately. It turned out ok, not "precision perfect as I had hoped, but then it was my first use of the product. I suggest making a small "trowl" from a body filler applicator, cut it about 3/4" -5/8" wide and use that to smooth it. I did just that when repairing the 2 small front seams above the windshield, and it worked great. Frank
1970 K-5 4X4 Blazer 1970 K-20 4X4 Long Bed "Liberty Means Responsibility, that is why most men dread it" |
