Old 09-23-2008, 09:38 PM   #26
1974k5blazer
Re: Who hates rust? I DO!!!!
whats rust?????
I
<---------- I
1974k5blazer is offline   Reply With Quote
Old 09-23-2008, 11:42 PM   #27
Chevyman680063
Chevyman680063's Avatar
Originally Posted by jonzcustomshop View Post
If you want take a screw driver and jab a hole in that crack, then get a vaccuum cleaner, and you will suck a good couple pounds of dirt out of that cab brace. some will probably still be wet.
I already got all the dirt and rust flakes out when I pulled what was left of that cab corner off.
Chevyman680063 is offline   Reply With Quote
Old 09-24-2008, 08:05 AM   #28
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
when i was doing my 61 and 65, the braces were full of dirt, luckily the metal was still pretty solid.
when I did the left fender I cut the rusty sheet metal off, exposing the inner brace, it was packed so tight with mud that I had to scrape it out.
On the braces, I drilled some 3/4 inch holes towards the bottom so that the dirt and water would have an easier time draining out.
I also plan to periodically presure wash them so that they don't get clogged up.
Last edited by jonzcustomshop; 09-24-2008 at 08:06 AM. Reason: cant spell/thick fingers
Old 10-19-2008, 03:56 PM   #29
Chevyman680063
Here are some pics of the driver's side floorboard. The passenger side doesn't look too much better. I don't won't to pick at it too much otherwise I'm going to be Fred Flintstoning the truck when I start moving.
Old 10-19-2008, 03:57 PM   #30
Chevyman680063
More.
Old 10-19-2008, 04:02 PM   #31
Chevyman680063
I have one question that doesn't concern the floor. What is the bushing in the firewall that the accelerator pedal rod runs through that holds it in place and is there anywhere you can get one other than a junkyard because the bushing or whatever it is in mine is messed up so the accelerator rod is loose and slides in and out through the firewall. Thanks for the help in advance. Here's a pic of what I'm talking about.
Old 10-19-2008, 11:17 PM   #32
protrash64
Resistance is Futile
protrash64's Avatar
All the stuff Ive seen thats a new one to me! Maybe you could tac it on w/ a weld or two.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 10-20-2008, 09:15 AM   #33
jonzcustomshop
1961 crewcab
It looks worn out, if you remove the firewall pad , you will see the rest of it still bolted to the firewall with 2 bolts. your best bet is just a new/ different pedal assembly. just look for one without any play, and it should last you another 300,000 miles
Old 10-20-2008, 09:22 PM   #34
Chevyman680063
So anyone have a good pedal assembly for a '63 or that will work with a '63? Oh where's Tony at, he has all the parts for these trucks.
