10-15-2008, 06:00 PM | #26 |
Re: Rear bag mounting pics please
This is what I took out that the PO put in..
10-15-2008, 06:07 PM | #27 |
10-15-2008, 06:14 PM | #28 |
Keepin it old school
Dominators have much more stroke and alot more durable then a Firestone. They also have more stroke then Slams as well.
The Dominators design is very similar to Slams. They have a much nicer ride then the Slams though due to the Dominators being made of a softer matierial then the slams and they also take less air pressure to achive a set amount of lift when compared to a Slam which also helps achieve a much nicer ride.. The dominators are rated at 600PSI and only cost about $75 bucks each. I bought a full set of Dominators for my 63 |
10-15-2008, 06:16 PM | #29 |
3DrDwn--the 'burb not the band
Crap like that is why repairing someone elses FUBAR was a double shop rate bill.
At least it's fairly solid looking. What I don't get is why block the axle for MORE drop but then space the bag up for LESS drop? Yikes. Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 Last edited by RunninLo; 10-15-2008 at 06:18 PM. |
10-15-2008, 06:18 PM | #30 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-15-2008 at 06:21 PM. |
10-15-2008, 06:24 PM | #31 | |
http://media.putfile.com/New-Air-Lift-bag-10 http://media.putfile.com/New-Air-Lift-Bag-EP-2 Last edited by Bazooka; 10-15-2008 at 06:40 PM. |
10-15-2008, 10:23 PM | #33 | ||
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 10-15-2008 at 10:25 PM. |
10-16-2008, 12:15 AM | #34 |
RunninLo, I'm not sure what his thought was when he installed it. I don't know why he has a hudge block under the axle either. I am going to just put some 2" square tubing under the axle. I don't think my adjustable panhard bar will fit with that block in there.
There is alot about this truck that is making me shake my head.. |
10-21-2008, 12:00 AM | #35 |
Heres a pic of our rear bolt in kit installed.
10-21-2008, 12:01 AM | #36 |
Dominators are the new Air Lift bag we carry, and yes ride AWESOME! 10" of lift with the 2B7 and far better ride with angodly 600 PSI rating for way cheaper than a SLam. Stones are Firestone bags
10-21-2008, 12:13 AM | #37 |
Señor Member
Your "rear bolt in kit" is welded in.
10-21-2008, 12:17 AM | #38 |
I ordered 4-dominators from ***************** and I have got to say WOW they have good customer service. I had trouble getting through the online ordering cause it is a Canadian order so I emailed them. The next day Ricky phoned me and asked if I still wanted the bags and he emailed me an invoice right away. I though that was A1...
Trevor |
10-21-2008, 12:53 AM | #39 |
The notch is yes, but is able to bolt on. No offense but I would rather weld than bolt because I can. If you look yopu can see I plug welded the holes.
10-22-2008, 10:54 PM | #40 |
just wondering here but why didnt you extend your C- notch to cover the top back bone of the frame rail? it also looks like you didnt make any changes with the panhard bar, does your kit not need it?
10-23-2008, 12:05 AM | #41 | |
Señor Member
10-23-2008, 10:43 PM | #42 |
Got the dominators today- wow that was fast. They look huge. I got the 2600's. Which ones did you guys put in???
Trevor |
10-25-2008, 12:09 PM | #43 |
Dominator 1:1 ??? you got a part number?
Adam M STX Designs Motorcycles | Choppers | Hotrods Last edited by ShowSS12; 10-25-2008 at 12:11 PM. |
10-26-2008, 12:48 PM | #44 | |
Stirrer of the Pot
I always wanted bags so I could get my truck on concrete... but I'm finding there are a lot of people out there bagged who have no intention of laying frame. |
10-26-2008, 06:02 PM | #45 |
I got the c-notch in and just set the bags in there to see how they fit. Looks good. The only thing I did notice was that the diff hits the box before the axle hits the bumpstop. Should I just space the bumpstop down abit?
Trevor |
10-26-2008, 06:20 PM | #46 |
senior member
or trim a nice little hlole in the bed for the diff to pop thru
69 GMC bagged |
10-26-2008, 06:21 PM | #47 |
Here's the pic..
10-26-2008, 06:22 PM | #48 |
A guy with a truck
Sorry, what I mant was 1-for-1 swap. I removed the Slams and directly replaced them with the Dominators.
Yep. Taller bumpstop- or clearance the floor...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
10-26-2008, 07:49 PM | #49 |
Stirrer of the Pot
I'd clear the floor myself.... my buddy cut this hole for me, otherwise I would have been too whimpy to do it... but now that I've started cutting stuff, I can't stop:
but I have seen guys cut JUST enough for the dif, or the notch, or whatever they need. Last edited by Dustin07; 10-26-2008 at 07:49 PM. |
10-26-2008, 08:31 PM | #50 |
Hey gringoloco, which dominators did you put in. The 2600's look pretty big for the front....
