Old 10-14-2008, 11:14 PM   #26
Gray Ghost
Gray Ghost's Avatar
Re: swimming in a sea of choices.. (engine choices)
Originally Posted by skchevota View Post
Having built many th350s and th400s, the 400s are wayyyyyyyyy stronger.
the gears, clutches, sprags, eveything is biger. They came behind 450hp big blocks, in moter omes, dump trucks, you name it. With aftermarket parts they will suport what ever kind of hp you make. The down fall of the TH 400 is the 1st gear ratio is 2.48 to 1, the 700 r4 is 3.06 to 1. tis is like going from a 3.08 rear end to 3.73s off the line.
Yep....and the other drawback is the 400 takes a bunch more hp outta the mix than a 350.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 10-15-2008, 03:20 PM   #27
gintaras
so, I am pretty set on a 5.3/4L60E combo from SPS, sounds a killer deal at right around $5k
But has anyone installed an LS1 or an LS2? a 400hp LS2 would be just about perfect, and they have one available with a GTO 6-speed for $8k!!! (but alas, i think the 6-speed might be a real PIA and I dont want to cut up the truck anyway.
2004 VW R32 450 HP money pit (faster than a Viper in the 1320 )
2001.5 VW Passat beater
1972 Custom Deluxe Highlander 69k miles and counting, all original, even the paint
gintaras is offline   Reply With Quote
Old 10-15-2008, 03:37 PM   #28
boostat4500
Is the SPS all brand new parts? If not, you can do much better price wise. A used 5.3 and 4l60e can be had for under $1500 complete. Then depending on what else is needed, if anything, your looking at about $100 for a programmed PCM and about $3-500 for a ready to go harness if the motor didn't come with one. The 6.0's can be had for about the same, throw a small cam in and your at 400hp easy.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc.
boostat4500 is offline   Reply With Quote
Old 10-15-2008, 03:47 PM   #29
Gray Ghost
Gray Ghost's Avatar
That's a great choice....you will love the driveability no doubt. Sometimes I wish I had gone that route with mine....maybe next time.
Kelly
Old 10-15-2008, 03:54 PM   #30
brad_man_72
the boat guy
brad_man_72's Avatar
working in a driveline shop, alot of the hotrod ls/manual trans guys are having trans problems, and have you ever put a cluch in one you wouldnt mind an auto, they seem to last quite a bit longer. no shock load, but not as much fun.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 10-15-2008, 04:12 PM   #31
gintaras
sounds real good, but from where? wrecking yards, I assume?
Old 10-15-2008, 09:15 PM   #32
boostat4500
Either the wrecking yard or just watch Craigslist for even better deals. I paid $1800 for my 6.0L/4L80e/NP-241 combo complete with everthing. I just picked up another complete ( minus harness and pcm ) 6.0L a few months ago for $500 and a 4L60E for $400, there going in a 57' Nash Metropolitan for my wife.
brad man 72: what are your customers doing to there T-56's to break them? What problems are you seeing? A few years I was heavily into drag racing with an 01' WS6 making 750hp. Daily driven with nothing upgraded tranny wise but the clutch. All my buddies with 4L60E's were constantly breaking with much less power. Just curious...
Old 10-16-2008, 01:32 AM   #33
71/454
Turbo Guy
71/454's Avatar
Nothing says street and strip better than a twin turbo!
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles.
1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit!
Things I've broken so far:
12 bolt diff
saginaw 4 spd many, many pieces
Aluminum case Super t-10 4 spd
71/454 is offline   Reply With Quote
