Old 02-13-2009, 12:14 AM   #26
RustenPaines
RustenPaines's Avatar
Re: Torchered
Honestly I have not done much Nick the guy bending over in the upper picture has done alot of the latest work.
The donor truck has been chopped and sold or scrapped.
The 69 has been stripped in the engine compartment and dash.
Going to refinish the dash in black with a painted pad and chrome gauge bezels and glove box.
All the little brackets have been sent off to powder coat so soon we can put it back together.
Nick's been stripping the frame past the bed so it can be primed and undercoated. 1/2 frame off restoration.
Looking at paint colors now I like gun metal blue, with matching valve covers and air intake.
RustenPaines is offline   Reply With Quote
Old 03-31-2010, 01:08 AM   #27
RustenPaines
Re: Torchered
Its been awhile, Originally I was going for a satin black shop truck. Do to lack of funds i have to do more work to get better parts. Like most of us. New updates:
CPP lowerd truck trailing arm cross member installed
CPP trailing arms
New bed sides
LWB bed floor chopped and welded for the new SWB bed floor
Cab has been primed and we are sanding down to spray base
One peice window kit not installed
Test color painted on cab - I call it metal Blue - picture coming soon
I will be buying a ridetech pro level system wednesday
this truck should be based and clearcoated buy end of next week.
The bed has a few issues around the tail gate so it will be painted after I finish the metal work. Pictures will be added this week.
Old 04-01-2010, 12:20 AM   #28
RustenPaines
Expensive day!
I finally broke down and whipped out the card. Purchased a ridetech prolevel system with height sensors and a second tank. I also called Porterbuilt with 45minutes left on the clock for there droped crossmember sale. I didnt realize it needed a rack system, oh well with a $300 discount it maded a hole lot easier to say yes.
Old 04-06-2010, 05:42 PM   #29
RustenPaines
Pictures
CPP C-notch installed, bolted and welded
69 C10 "Torchered"
RC Crawler Nut
http://www.dorkstarproductions.com/orcrc.com/forum/
Old 04-06-2010, 05:45 PM   #30
RustenPaines
pictures
Fabed the upper rear crossmember to hose my shock mounts and new lower shock mounts. I built the lowering blocks for welding practice.
69 C10 "Torchered"
RC Crawler Nut
Old 04-06-2010, 05:46 PM   #31
RustenPaines
pictures
more
69 C10 "Torchered"
RC Crawler Nut
Old 04-06-2010, 05:47 PM   #32
RustenPaines
Re: Torchered
The frame/crossmembers were cleaned with a sanding disk or wire wheel and sprayed with rubber undercoating.
69 C10 "Torchered"
RC Crawler Nut
Old 04-06-2010, 05:50 PM   #33
RustenPaines
Pictures
The air ride parts came in. The E3 controller is much smaller then I thought it would be. I would like to have a program for this thing with an automatic speed height sensor. Say at 55 your truck automatically drops to a preset height.( 1 inch lower for the highway ) I also purchased the extrenal height sensors.
69 C10 "Torchered"
RC Crawler Nut
Old 04-06-2010, 05:51 PM   #34
RustenPaines
Pictures
More
69 C10 "Torchered"
RC Crawler Nut
Old 04-06-2010, 05:53 PM   #35
RustenPaines
Pin striping
The boys and I were thinking of running a colored stripe down the groove in the center of each spoke. This would bring the blue into the wheels
69 C10 "Torchered"
RC Crawler Nut
Old 04-06-2010, 05:54 PM   #36
RustenPaines
Pictures
Cab
69 C10 "Torchered"
RC Crawler Nut
Old 04-06-2010, 06:29 PM   #37
RustenPaines
Pictures
This is the test paint test. It is a metalic blue/metal color. The other picture is the line up of the front valence with the doors and such. I ended up chopping both ends off the valence and rewelding them on to get better gaps.
69 C10 "Torchered"
RC Crawler Nut
Old 04-07-2010, 01:40 PM   #38
RustenPaines
Pictures
Pulled these 10mm muscle bar ends off my Nova to put on the truck. Im swapping in 12mm ends for the Nova considering its weight.
69 C10 "Torchered"
RC Crawler Nut
Old 04-07-2010, 02:26 PM   #39
nuke1
nuke1's Avatar
Re: Torchered
Sweet ride!!!! how about a couple pics of that nova of yours, pretty please.......
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 04-07-2010, 03:58 PM   #40
*Dylan
Mean Buzzin' Half Dozen
*Dylan's Avatar
Re: Torchered
I thought it wasn't going to be a show truck? Lol.
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
MY TRUCK (Now for sale)
1967 C10 SWB
Dylan
*Dylan is offline   Reply With Quote
Old 04-07-2010, 04:24 PM   #41
RustenPaines
Re: Torchered
LOL, No show. I'm painting it. Its about function. I dont like to peice together or half ass it in parts. It causes headaches later.
69 C10 "Torchered"
RC Crawler Nut
Old 04-07-2010, 04:46 PM   #42
RustenPaines
Nova
You asked so here you go. This will be the only post about this car. I will be starting a build thread for it on another site. So I will include that link later. Thanks for your interrest.
http://www.stevesnovasite.com/forums...d.php?t=148565
400 SBC 470hp on dyno, had a 350 but went bad. It had alot of new parts and I had to decide between a 383 and a 400 to reuse as many as possible. This motor may endup in the truck.
700R4 built, 3,000 stall
Retrotek Paddle shift
Tubular control arms up front with coil overs and 1-1/4 sway bar
aluminum tall spindles with C-6 hubs ( the C-6 has a 3" sealled bearing)
C-6 front and rear brakes (12.8 inch rotor, twin piston front, single out back)
CSR billet vacume pump for power brakes.
12bolt car axle with posi and 3:42 gears
18x8 front and 20x8 rear, will be 19front and 20x10rear by years end.
20 ft paint and interior
Its all function
69 C10 "Torchered"
RC Crawler Nut
Old 04-07-2010, 05:16 PM   #43
VA72C10
VA72C10
VA72C10's Avatar
Re: Torchered
Truck is looking great and that Nova looks good in the pics and sounds like it's a whole lotta fun
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-07-2010, 08:34 PM   #44
67-72crazy
67-72crazy's Avatar
Re: Torchered
welcome from greenfield,in. nice truck it keep up the good work.
1991 1500 longbed: my daily driver
1937 chevy 2dr sedan. dads project
67-72crazy is offline   Reply With Quote
Old 04-08-2010, 12:46 PM   #45
RustenPaines
Re: Torchered
Thank you, Im hoping to get the fire wall done, and cab painted by end of April so I can start the metal work on the bed. Id really like to have it go to Puyalup Wa for the Good guys show.
69 C10 "Torchered"
RC Crawler Nut
Old 04-08-2010, 04:29 PM   #46
cstm68
cstm68's Avatar
Re: Torchered
nice build!! you better have that thing ready for goodguys! ill be there with my 68
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 04-08-2010, 05:40 PM   #47
RustenPaines
Re: Torchered
Were going to have to reserve spots next to each other! Do they do that?? LOL
69 C10 "Torchered"
RC Crawler Nut
Old 04-09-2010, 12:22 AM   #48
cstm68
cstm68's Avatar
Re: Torchered
its a free for all!!!
Old 04-09-2010, 12:14 PM   #49
RustenPaines
Re: Torchered
In that case mine will be at the very end. Its little motor just can't compete.
69 C10 "Torchered"
RC Crawler Nut
Old 05-14-2010, 01:57 AM   #50
RustenPaines
Re: Torchered
Been a little slow, finally had the cab prepped for the final coat of paint and we tore it back down to the frame to install a Porter built crossmember. Still waiting for some parts to get that sucker on but in the mean time built a paint booth. The sides are meant to remain while the fornt and back will roll up so we can move it as needed.
69 C10 "Torchered"
RC Crawler Nut
