10-30-2008, 11:31 AM | #26 |
Built 4 Speed
Re: Engine runs hot
seems to me somthing is a miss and if it doing this consistently it doesnt sound like you accidently got a reverse flow pump.. i agree with alot of above take a thermometer to it...
kinda like getting a royal flush but it is possible to get 2 bad units. ive had that problem with Motorcraft relays.
1969 C/10 Short Box: 496/T-56 in worx. "To Be Old And Wise, First You Must Be Young And Stupid" |
10-30-2008, 12:51 PM | #27 |
Rusty Nuts
Re: Engine runs hot
I would check your timing, i have had first hand experence with this on a 235 six cylinder and after all the thing you have done i did. and went to the distributor and sure enough adjusted the timing and problem gone.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
11-03-2008, 06:22 PM | #28 | |
Re: Engine runs hot
11-03-2008, 06:27 PM | #29 |
Re: Engine runs hot
Have run with timing from 0 to 4 degrees. Specs call for 0 degrees w/manual tranny but it runs better at 4 degrees. Neither setting had any affect on temp.
I am back from parts store with mechanical gauge. Figure this will solve the issue of whether or not engine is running hot. |
11-03-2008, 06:40 PM | #30 |
vw guy & now c-10 guy
Re: Engine runs hot
if you have access to an infrared thermometer, that helps out a lot- you can check the temp of the upper and lower hoses, different sections of the radiator, heater hoses, etc. while it's running and system is closed- and see if you're getting a big temp difference somewhere (restriction) and you can also see if the coolant temp is really as high as your gauge is reading...
11-03-2008, 06:52 PM | #31 | |
Re: Engine runs hot
Timing too retarded can cause to run hot too. I would get the timing dialed in.. and not pay too much attention to the guages.. if it's hot.. you will know it. Do you seem to lose a little power too when this is happening. |
11-03-2008, 09:14 PM | #32 |
Re: Engine runs hot
Installed mechanical temp gauge. Highest reading sitting on driveway - (can't drive truck since master cylinder cover off and along with other pb parts are off being plated....getting ready for pb conversion) is just under 210degrees. When I rev up engine it cools down to 190-195 degrees. I assume driving truck at 60 mph with more airflow through radiator it will run even cooler. I am playing around with the two (old and new) temp sending units. Have them tucked between lower rad & heater hose and alternating gauge comnnector between them (also grounded to battery) and they transmit identical readings although at low temp. I am relieved that engine is not overheating, OK with 190-195 degrees. I don't really want to install mechanical gauge as permanent so I may try another new sending unit with no thread sealant to rule that out. I also cannot find any wires grounding block to frame so I will take care of that. There is ground from valve cover to firewall and neg battery cable is bolted to cyl head. I am leaning towards conclusion that this is a grounding issue since replacing sending unit did not change gauge reading and old sending unit was installed with no thread sealant. Thanks to everyone for their tips and suggestions!
11-03-2008, 09:33 PM | #33 | ||
Sierra Grande Club
Re: Engine runs hot
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
11-03-2008, 09:55 PM | #34 | |
Re: Engine runs hot
12-20-2008, 08:15 PM | #35 |
SWBs: 67 2x4, 67 4x4, 70 4x4
Re: Engine runs hot
I have a 292 and 250, and also live about 150 miles from you.
The reason a six has no real fan shroud is it really does not need it. It can almost cool itself off the heater. I just had an issue with mine, the original 67 rad cap finally lost it's 7 lbs of spring. A 14lb. off the other one and I was down the road. If the lifters do not start rattling it usually is not hot. They usually will vapor lock way before then. Now that it is cooler you should not have a problem.
FINISHED Project thread: 67 SWB 4x4 FINISHED Project thread: 67 SWB 6 cyl cruiser Project thread: Road Toad 70 SWB Step, 4x4, 292, 3OT 01 C5 convertable 08 Z06 |
12-20-2008, 09:00 PM | #36 |
Watch out for your cornhole !
Re: Engine runs hot
Question to answer is, does it overheat only at idle or going down the road ?
At idle = airflow issue, fan shroud, fan, etc... At speed = coolant flow issue, radiator, pump, clog somewhere. This applies to all liquid cooled cars.
12-20-2008, 10:55 PM | #37 | |
Re: Engine runs hot
i work in a shop where we constantly trouble shoot that complaint. i have never heard of the test you say the radiator shop performed. what we do is take a 16 ounce coke bottle and fill half the bottle with water. then stick the radiator over flow tube in the bottle. let the engine run and watch the bottle. if it starts bubbling then you have a blowed head gasket. the best way to verify a faulty reading is with a ray gun. shoot the area around the thermostat housing and compare to the gauge and shoot around the temp sending unit and compare.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
12-20-2008, 11:22 PM | #38 |
Truck and auto performance nut
Re: Engine runs hot
stock crank and water pump pulley?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
