Old 11-17-2008, 01:11 PM   #26
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: refinished a NOS sway bar today..
we put ECE 2 1/2 drop spindles with the ECE mounts and lowered frame bar mounts. . do you have a pic of yours installed. do you have alot of upward pull on the bar in the LCA? i can see a gap in the bushing where it's pulling up.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 11-17-2008, 02:01 PM   #27
67ChevyRedneck
67ChevyRedneck's Avatar
I have an ECE 1-1/4" sway bar using stock height brackets. Maybe because you lowered your truck with spindles and not springs there is a little bit of pull on the sway bar? Drop spindles do not affect the overall suspension geometry, just the location of the spindle. Springs change geometry.
Also: You have NO WEIGHT at all on your suspension, that will drop the suspension a good bit, which will ease the "pull" on the LCA mount You're probably fine, just need to get your truck done
These are the only pics I have.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-17-2008, 04:08 PM   #28
70rs/ss
70rs/ss's Avatar
I've seen those mounted without the frame bracket part, I just figured that was for a lowered truck?? I pulled a couple of them from a motorhome, need one for my 4X4, 73 and up looks like that'll work for the 4X, any ideas on the no bracket/lowered deal ??
70rs/ss is offline   Reply With Quote
Old 11-17-2008, 04:19 PM   #29
72BlckButy
Tot Roddin'
72BlckButy's Avatar
70rs/ss... you can either mount the bushings directly to the frame by drilling new holes; or you can buy the "lowered" brackets and mount it this way. I believe either method is best used on a lowered truck as the bar will be pulled to high on a stock height truck and bind the sway bar. 2/4 I would use stock brackets, and anything lower I would use either method mentioned above.
Here's another thought as well....
I've also seen people use the stock brackets on a lowered truck, but mount the bushing on the inside of the stock bracket, so the bar is actually high off the ground, but optimized the stock brackets.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-17-2008, 04:28 PM   #30
dfosh
I used a 1 1/4 inch bar from salvage yard with ECE lowered bracket kit on my 68 GMC . It fit great about 30 min install . Truck is all stock for now . Truck did handle better . I still have the skinney stock tires .
dfosh is offline   Reply With Quote
Old 11-17-2008, 05:16 PM   #31
my67chevytruck
Under Construction
[QUOTE=72BlckButy;2978654] 2/4 I would use stock brackets, and anything lower I would use either method mentioned above.
I found my stock brackets after i placed the ECE of course. ECE recommended the lowered version of the mount brackets when i ordered my 2.5 / 4 kit, i did not think i needed it, and was going to get stock height but they suggested the lower. If it seems to bind, i will paint up the stockers and use them.
I called and spoke with ECE a few minutes ago. They recommend the lowered brackets for 2.5 and lower front drops.
I beleive my issue is there was not enough weight (bare frame) for any resistance on the LCA during install, and when the drive train gets installed it should should resolve my worries.
ECE stated if after the drive train is installed and i am still not happy to call them back and they would be happy to switch out with stock height mounts.
Chris - sorry to threadjack!!!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 11-17-2008, 05:35 PM   #32
67ChevyRedneck
That's a neat idea! I won't need new brackets when I lower my truck
Jesse James
Project "On a Dime"
