#26 |
Re: Kickdown Switch????
i removed switch bracket and wiring form heart donor truck witch was 79 1 ton 454/400
#27 |
I'M TRUCK CRAZY!
Thanks for the info Lumpy
#28 |
![]() Join Date: Nov 2008
The kickdown switch is pretty common on GM Fullsize cars , 1968 - 1976 Olds Delta 88 , 98 , Wagons , Impalas , Bonnevilles ... more common on these than trying to find a GM "A" body ... Good Luck !!!
![]() Last edited by 62 Longbed; 10-22-2009 at 03:09 PM. |
#29 | |
#30 | |
![]() Quote:
HTH. |
#31 |
Just out of curiosity I did about 10 minutes worth of searching and found that '67,'68,'69 Firebirds used a carb mounted trans kickdown for the TH400. Found on ebay for $30 with bracket. The bracket would be the best part, the switch looks like a regular brake light switch. Will try to post a link or pic.
#32 |
subscribed! Just picked up a TH400 and this is some good info.
