#26 |
Re: Calling All 383ci Trucks
VDOG, you won't have to change your gears with a 383. The 3.08's will be fine as long as you don't get too radical with the engine and cam selection.
My suggestion would be this: 383 with Vortec heads, an RV cam, NO bigger than a 600 cfm carb, a dual plane intake, a good HEI ignition system, and a decent set of headers. This combo should be very similar to the GM crate engine noted above, but alot less money. It would have great street manners with a smooth idle and still provide about 300-320 hp which is plenty enough to smoke tires when you want.
#27 |
I had my 350 built for $1100 here locally & saved a ton of money! Mine gets 12mpg without OD [TH350 soon to be changed to a 700r4]. The motor is a very strong one that has a mild cam [pulls from 1000 rpm for towing]. The tranny is rebuilt as well.
The 383 will be much more fun, but I think for your application a stout 350 is all you really need.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. Last edited by Gray Ghost; 11-04-2008 at 08:39 AM. |
#28 |
Is it the longer stroke makes it less suited for highway and you`ll get less miles argument?It`s not that significant of a stroke over the 350 to matter there.It`s not like it`s in a whole new rpm range.Plus,you`ll get better power from lower rpms so that makes up for the extra travel on the piston at a given rpm.
#29 |
A 383 is a no-brainer in my opinion if you are sticking with a small block. You can build a 383 for ALMOST the same cost as a 350 since the 383 parts are so common now. I managed to get mine done for a touch over $1200. I used a 350 block out of a Monte I used up years ago. My rebuilder had a 400 crank he was saving for such a project. The rods are out of the Monte. The rebuild kit with the correct pistons was +/- $20 of the cost of a 350 kit. If you have a small block in your truck now EVERYTHING else is the same on the truck. (You state you have a 283 so you're good to go).
I run mine in a 4x4 with 3.73 gears. The only thing I would (actually am going to) change is the tranny. Right now I run a th350. The rpms are a tad high on the highway in the 70 mph zones. A well built 700r4 would be just the ticket and is on my list. With 3.08 gears you will be fine with a th350. In fact I read on these pages that people with 3.08 gears got worse mileage after switching to a tranny with OD. For me the benefits of the 383 far outweighed what I could get out of a 350. I pull my boat a lot. I pull stuff like docks and boat lifts out of the mud bottom of the lake. You really notice the difference. I just stuck a snow plow on the front of it for the winter. We'll see how that goes. If you're just going to drive around the city, nevermind. Get a 350.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#30 | |
Grand PooBaa Member
#31 | |
Grand PooBaa Member
#32 | |
Grand PooBaa Member
You know how the Mopar guys are, I told my friend anything I buy for my 283 will work on a 350 block, I think he is stuck on the 283, a small number so he does not think its worth repairing. My motor is all roller, been pulling strong for 10 years now. I appreciate all the input you guys have giving me, thus why I stay here for advice. |
#33 | |
![]() Join Date: Dec 2006
I have 3.73 and at 65 I'm at 2600 or so. My last truck had 3.07 rear (33" tires) and it cruised at 60 at 1875 RPM.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. Last edited by WorkinLonghorn; 11-04-2008 at 01:07 PM. |
#34 | |
A good streetable engine can be put together without a whole lot of cash outlay.
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: ![]() |
#35 |
All I can say is prior to buying my 69, I often used my dad's 70 which has a 383.. and the one thing I dreaded the most about using his truck was replacing the gas I used. Sometimes the cost of replacing gas outweighed the use. 'Seriously'. He also has a Victor Jr. Intake a Carter 850 AFB carb, and Dart heads. Way too much IMO. I think if he changed carb and intake he would see an improvement in gas mileage.. but not much, but I think it will lose some zip.
This motor was built for an El Camino, but was quickly taken out because the car would not go in a straight line at any speed. It was simply too much motor for a light car. Put in in a 3/4 truck loads of difference on behavior. Stall is something you'll have to add also. Why add the power if you can't get it to the ground. His truck is nice and you can hear it coming and going.. but I want something different for my truck. I will be going with a mild-stout 350. It drives plenty good right now with a very tired 327 in it.. so a freshly built 350 will be that much better. It's a 1/2 ton truck and only weighs 3780.. that's pretty light for a truck. Has a TH350 behind it and gets decent gas mileage since switching over to HEI. My dad still has the truck and I can't tell you the last time it was driven.. He calls it the beast. He too complains about the gas and says "that's why it's sitting there". He'll be making some changes soon that I mentioned above.. but the base will still be 383. Bottom line, it's your truck so you can do what you want to do. If you can afford to gas it and go COMFORTABLy,, then build the 383 and drive it like you stole it. If you want a better balance of the two, then 350. I'm going 350 route with my build. Will not be towing anything either, but in the event I do, I am confident the 350 will be able to handle it. Once you get up to speed the stress is pretty much off the motor anyways. I will be going with a 200/700, or leaving the TH350 in I already have. Doing this research now. Folks seem to like the TH350 over the overdrives. Anyone know why? Last edited by Slik69; 11-04-2008 at 01:45 PM. |
#36 | |
Grand PooBaa Member
Ok FT size 15x8 255x60x15 26 1/2 tall tires in the back RT size 275x60x15 27 1/2 tall tires on 3:08 gears and Th 350 trans with a 283ci motor. 4000 might be high but its in the high 3's easy |
#37 | |
I didn't write it down but the last time I was out in a 70 mph zone, I think I was taching around 3200 rpms. Again I have 3.73 rear end gears and 28" tall tires. Assuming I'm seeing 3200 rpms in my truck at 70 mph, 3.08s with 28" tall tires should be seeing approximately 20% lower R's or 2500 - 2600 R's.
#38 |
Ha! We posted at almost the same time.
#39 | |
Truck and auto performance nut
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#40 |
Sound more like a 4.11 gear. I too have 275/60r15 with 3.73, and I'm spinning 3-3.5k on the interstate. As far as gas milage........I've run a stock 307 2bl hopped up 283 4bl, and now a gmpp 350 ho. All three motors got nearly identical gas milage on the interstate.
#41 |
A vortec block and heads (roller cammed) can be found for a core price ($100-150) and it'll get you a set of heads, as well as a vortec roller cammed block, buy a balanced 383 kit that'll drop into the block for like $8-900 and all you'll need is a bore/hone and some small reliefs in the block for clearance. Get a mild roller cam and use the factory roller lifters, etc and the heads will ahndle up to .500 lift/flow so a .480-.500 lift cam would be fun smaller is OK and then you'll have an honest 350-400hp and over 400lb/ft of torq. With a 3.08 and a th350 you should be able to smoke em for as long as you want, get decent MPH and MPG on long road trips and it'll last forever under 6K RPM, so why not build one?? With a complete kit, you can do this for about $1500-1800 tops and as mrein3 said it can be done even cheaper, but the piecing it together can get pricey for a balance, whereas the balanced kits come ready to use, so a little more $$$ = less work and headaches?? Do I have one, yep, and it'll be north of the 450hp range with 500lb/ft of torq and a HUGE cam, but so what it'll outrun most anything I come across and I'll be OK with frequent stops for premium fuel, cause the smiles per/gallon is all I am worried about!!
#42 |
70rs/ss; I'm sure this has been beaten to death elsewhere but if he uses Vortec heads, will his accessories bolt up or not?
Also he'll need vortec intake.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
#43 |
I'm gonna have to agree about the numbers being off on your calculations. I have a TH350 and 3.73 gears and I turn about 3350 at 70. It would turn 2500 at 70 with 3.07 gears. I'm also thinking you have 4.11 gears.
How did you determine you have 3.08's? Check your calculations here.
#44 | |
Grand PooBaa Member
I also learned the hard way that 3:73's out of a 1970 6cyl 12 bolt truck will not fit in a 69 12 bolt truck. Would not line up and when installed one axel went in further then the other. (See attached inner drum pic.) Notice how the lip of the drum on one side has a lip while the other side is flush. So the guy rebuilt it to the stock gears, 3:08's |
#45 |
isn't that because there are 2 carriers for truck 12 bolts....1 for 3.73 down...and one for 3.73 up? ...or something like that.
#46 | |
Grand PooBaa Member
1970 uses different length axels. |
#47 |
There is a difference between the 3 and 4 series carriers. It has nothing to do with year models. The pre-70 rearends are shorter in width and do require slightly shorter axles than 70-72 model rear axles.
The reason your 3.73 gears(which are considered in the 4 series: 3.73- numerically higher gears) wouldn't fit is because you were trying to install them into a 3 series: 3.42-lower numerically gears carrier. The thickness of the 3 and 4 series ring gears are different. Most gear companies make gears to fit either carrier. You also could've just installed a ring gear spacer to install your 3.73 gears into your 3.08 carrier. Something is still wrong somewhere if your turning almost 4K rpm at 65-70 mph. Is your tach reading correct?
#48 |
born to lose
I drive my 383 powered 71 C20 everyday and before the race track closed for the season I was drag racing it almost every weekend and drove it to work the next night with no problems. I have taken it on long cruises and never had a problem. On the freeway with a th350 and 4.10's its turning about 3800-4000 rpm at 65-70 miles per hour. I would say build a stroker you will not regret it.
_____________________ '67 Chevy Belair Wagon 283 Powerglide '68 Chevy II Nova 2 door 350 TH400 ![]() '71 Chevy C20 350 TH350 '71 Chevy C10 Burb 350 TH350 ![]() Burb Build http://67-72chevytrucks.com/vboard/s...d.php?t=475155 Nova Build http://67-72chevytrucks.com/vboard/s...d.php?t=498979 Wagon Build http://67-72chevytrucks.com/vboard/s...d.php?t=543052 Not giving a truck. |
#49 |
I get 14 mpg on super when I don't play
#50 |
Grand PooBaa Member
Thanks guys. Now what im reading is im ok with my th350 trans but none of you are running 3:08's. I see 3:73's are the perfered gear for a 383 motor.
Which since it was rebuilt last year, I dont want to spend more money to change it. Again not opposed to the 383, and long as I cant get the right combination to work with what I already have installed. |
