Old 06-10-2009, 07:17 PM   #26
mycool72
mycool72's Avatar
Re: Project "Nympho"
A lil update on the truck, drove it around today! I've done a ton of work...I will update with pics and descriptions when I'm not in class..lol...later..also, I'm picking up my bed this weekend!
mycool72 is offline   Reply With Quote
Old 06-10-2009, 07:31 PM   #27
my67chevytruck
Under Construction
my67chevytruck's Avatar
sounds like you have made some good progress. get those pics loaded when you can...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-16-2009, 08:10 AM   #28
mycool72
mycool72's Avatar
Ok so here's my official update....
I had a hard time finding a driveshaft to fit and didn't want to pay 300 for a new one, so I finally found one that would fit with a long tail (mine is short tail turbo 350). My neighbor gave me a long tail so I installed it...long story short...it didn't work! So I reinstalled my short tail, moved the motor back two inches(PITA-requires new holes to be drilled for mounts) and finally a match.
After that was done a played with it a little-drove it around the block and did some burnouts! This past weekend I drove to the Texoma area and picked up a bed..I did an even trade with a guy for a cab that I purchased for another build. I brought the bed home and realized that it wouldn't align very well so last night I cut the rails off the rear notch, set the bed where I wanted it to be and rewelded the rails in the correct position...needless to say it has been a handfull. The truck is making real progress though and should see some road time this summer-at least the road between me and the body shop!
Old 06-16-2009, 08:14 AM   #29
mycool72
mycool72's Avatar
Soon to come...I bought a york 210 off flebay and have started the bracket work for it!!! Also as you can see in the pics I have started the bodywork on the bed and cut a tunnel in the cab for the ds, I will also be revisiting areas on the rest of the truck. I also need to trim out more of the inner bedsides, I'll prob do that tonight.
Old 06-16-2009, 09:25 AM   #30
my67chevytruck
Under Construction
nice progress.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-24-2009, 04:06 PM   #31
mycool72
mycool72's Avatar
Movin right along with the bodywork...also I found a couple of pics I forgot to post....
Old 06-24-2009, 04:10 PM   #32
mycool72
mycool72's Avatar
Started messing with the tailgate...and the LH bedside is smacked pretty good near the tail lamp area, that will take some work.
Old 06-24-2009, 04:21 PM   #33
mycool72
mycool72's Avatar
....the frame looks tweaked in the pic w/out the bed but I didn't have the cab mounts on at that point-all good now though. Also, I FINALLY fixed the trans leak-my garage floor is water proof for sure now!
Note: that's my 05 in the background.
Old 06-24-2009, 04:39 PM   #34
nuke1
nuke1's Avatar
It is lookin real tastey, i like it. that color is gorgeous, looks great on these trucks.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 06-24-2009, 08:42 PM   #35
kev2809
low n' slo
kev2809's Avatar
wow, it gets that low with just a notch and mounting the bags on the trailing arms? how far from the ground is the frame?
kev2809 is offline   Reply With Quote
Old 06-25-2009, 08:23 AM   #36
mycool72
mycool72's Avatar
I wish it were that easy...take a closer look...the bags are mounted on the axle, the cab has a tunnel for the ds, and the crossmember is cut...I'm not sure on the height of the frame but the bedside is about 3 inches from touching and I still need to put in some 2 in blocks on the back.
Old 06-25-2009, 08:43 AM   #37
my67chevytruck
Under Construction
looking good bro, need to check it out one day, I'm down the road in Midlothian....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 10-15-2009, 03:50 PM   #38
mycool72
mycool72's Avatar
Doin an update today...I'll post some pics when I get done with the lcas in a bit.
Old 10-16-2009, 01:33 PM   #39
mycool72
mycool72's Avatar
Left side is on......huge difference from before as you can see in the pics
Old 10-17-2009, 09:59 AM   #40
mycool72
mycool72's Avatar
I finished the right side lca last night, i'll pull it out today and upload some more pics.
Old 10-18-2009, 08:06 PM   #41
kev2809
low n' slo
kev2809's Avatar
that lca mod made a big difference...truck looks good
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
Old 10-22-2009, 07:45 PM   #42
04 orange
04 orange's Avatar
The truck looks good. Keep up the work.
04 orange is offline   Reply With Quote
Old 10-23-2009, 08:39 PM   #43
mycool72
mycool72's Avatar
Thanks guys.
Old 10-23-2009, 10:58 PM   #44
kev2809
low n' slo
kev2809's Avatar
you anywhere near rosenberg?? maybe i could get you to do my lca's like that! im not sure if i want to attempt that myself
-_--_--_ _________
Old 10-25-2009, 12:59 PM   #45
mycool72
mycool72's Avatar
I don't know where rosenberg is so i guess not. I'm se of ft. worth and sw of dallas.
