#26 |
Re: I think she **** the bed....
ok, I replaced the p/s pump today and found out that wasn't the problem!
There is a loose big metal ring around the main pulley area under the water pump. I'm not sure what it is, but it's a big metal ring that is loose, sitting on the pulley. Harmonic balancer ring? I just bought a haynes manual but I'm not seeing it in the book. It's sitting on the pulley and bouncing around loose when the truck is running, like a hoola hoop. What is it?!? I'll get a pic in the am when it's light out. Last edited by sweatmachine; 12-07-2008 at 11:19 PM. |
#27 |
WTB:Patience and Talent
Harmonic balancer
69 shortwide |
#28 |
yeah, balancer
i wouldn't run the engine until it is fixed, could cause some major problems...
#29 |
Yep.... Sounds like it tossed the harmonic balancer ring (it's steel held in place w/the molded rubber). Do not run the engine until getting this repaired. It's a common problem on high milage OE balancers. Pull it off & install a new one (new, not a different used one).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-08-2008 at 08:23 AM. |
#30 |
thanks guys, back to the auto parts store!!!
#31 |
Replacing the harmonic balancer requires alittle effort. Not a hard job, but you have to remove a few things to get to it. Fan assy, probaly the water pump, crank pulley and space will be limited. But I am sure you can do it, just take your time. I suggest, while you are down there, go ahead and throw a new timing chain on her. With that many miles I am sure she would bennifit from a new chain. Oh yea, you are going to need a harmonic balancer puller to get the old one off. Most auto parts store will rent or loan you one. Good luck.
#32 |
I'm pretty sure my uncle replaced the timing chain. It has a new cam in it and I think he put a new chain in with the new cam, but I'll check to be sure.
thanks again guys! |
#33 |
Right turn Clyde
Dont forget about the balancer installion tool. Dont beat the balancer on!
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
#34 |
hey guys, I wanted to update this post, it ended up being the harmonic balancer, but I replaced both the balancer and the power steering pump. Now she runs smooth as glass!
Last edited by N2TRUX; 02-07-2009 at 07:18 PM. Reason: Only subscribing member may post items for sale! |
#35 |
btw, the Haynes manual is a giant piece of ****. Worthless.
#36 | |
2WD 4 Life
Big D 1969 c10 1960 cadillac 1978 king cobra |
#37 |
Right turn Clyde
They make good coloring books.
#38 |
yes, i do
i only use mine for torque specs and when i can't remember the firing order.
#39 |
![]() Join Date: Dec 2008
buy a Chiltons, Haynes suck,
#40 |
Unfinished Project Club
![]() Join Date: Jul 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() Handle every Stressful situation like a dog. If you can't eat it or play with it, Pee on it and walk away. 1996 Dodge Intreped ES Nice car great on gas ![]() 1993 Jeep Cherokee. Looking for a swb chevy 73-87 Last edited by lvschevytrucks; 02-08-2009 at 12:07 AM. |
#41 | |
Cheyenne Super
People buy em cause they are cheap and at autozone. The one I got with my Volvo does seem pretty complete, I built a new ignition harness with it, but in general haynes manuals are for basic repairs, and I don't need a manual for basic repairs. Napa has Chilton, and maybe pep boys? The dampner must have been pretty wasted to make all of that noise. |
#42 |
