#26 | ||
PITbut
Re: Starting the beast. Any tips i should know?
I will update as the gay goes on.... |
#27 | |
Sierra Grande Club
Wrong element^ you meant Zinc! But I think they removed it from Rotella T also. You may want to double check. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() Last edited by Sport/Truck; 11-30-2008 at 12:57 PM. |
#28 |
PITbut
#29 | |
Sierra Grande Club
![]() s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
#30 |
Active Member
![]() Join Date: May 2005
I hope you have some gauges connected.... Water temp, Oil pressure MINIMUM!!! Got your timing light? cant have too many fans cooling. Fresh battery, fresh gas.
I think youve got everythign else covered! Fire it up!
Cadillac Powered |
#31 | ||
PITbut
I will come back on here in a few hours or tomorrow and give the rest of the story.. it only ran for 5 minutes.... |
#32 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Whhhhhhhhhaaaaatttttttttttttttt no way...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#33 |
![]() Join Date: Apr 2004
Crap, I think we forgot to say fire extinguisher.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#34 |
Sierra Grande Club
Fire extinguisher now on top of my list......and not a kitchen sized unit!
I hope it's not that bad.... (worried sick) s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() Last edited by Sport/Truck; 11-30-2008 at 11:09 PM. |
#35 | ||
PITbut
Luckily i had a towel to distinguish the flames that come from the carb every once in awhile, and my buddy had the extinguisher...... So, it went up, i freaked, he put it out, it came back, he put it out, it came back. So on and so on about 5 times. ahaha... What happened was the line running to the guage cluster melted and poored oil on the headers....... ALSO, i had a plastic, (not glass) filter that i guess got a bit hot and MELTED and was leaking gas. We found this LATER after we checked the damage. Im glad the oil side went up and not the gas side. Since then i have repositioned the filter, rewrapped all wires and im good to go i think. Sooo, about 2 hours later, everything is clean, everything is rerouted, and tomorrow im going to fire it up again and do the full break in... Needless to say, everyone else acted like it was no big deal. I actually SAT and didnt say anything for 15 minutes because it felt like a TOTAL failure to me..... I guess when i think about it now, its not uncommon for small things.. Glad i was prepared. One thing that did concern me is that my mufflers go through the center crossmember. Those mufflers are DAAAMMMN hot.... Anyone running mufflers high, do you have heat shields on the bottom of the cab???? I have pics of the damage, and what i did to fix any future problems, but i will post them later.. Im just a bit down at the moment.... |
#36 |
PITbut
also, what i have learned.
1) always have an extinguisher 2) run electical guages 3)always have an extinguisher. 4) take your time. thats all.. |
#37 |
Sierra Grande Club
Glad to hear the damage was minimum......
I'd remove anything plastic or rubber after the fuel pump. Its a bad combo. s/t
#38 |
laying low
![]() Join Date: Mar 2001
And I suppose you were doing this IN your shop? If so it could have been worse. It could have caught the ceiling on fire and burned the house.
Sounds like your helper stayed calm though. Gas and oil fires can get out of hand real fast.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#39 | |
PITbut
I have a video uploading right now, along with some pictures of some stuff. Burnt fuel filter, burnt plug wires, (just discolored, they are in great shape after i cleaned em)..... pics and vid on the way.. I dont have the vid of the fire cause i told the wife to grab the car to hook the battery up to the charger and thats were the fire started. You can see the smoke getting worse... |
#40 |
laying low
Ah outside, good. I know you were excited, to say the least. Sounds like a little clean up and moving the oil and gas lines are in order and it should be ready to run.
Hey this reminds me of the last one I fired off. I had the timing too retarded so it heated up pretty quick and I had a short piece of plugged heater hose pushed down onto the pipe nipple at the intake manifold but never had put a clamp on it. I had it rev'd up there real good when all of a sudden that short piece of hose shot off and bounced off the shop door and a hot stream of water followed it. Water and steam went everywhere. ![]() ![]()
#41 | |
PITbut
#42 |
no vid of the flames?
#43 | |
PITbut
Here are the pics of the mess and my plug wires. This is the other side of the motor. THe fuel filter was probably 4 inches away from the header, maybe less... if that caught fire, i dont know what would of happened. ![]() Heres my burnt wires.. Its just soot... I got em all cleaned up, i wrapped a few of em with some heat tape. ![]() This is where i screwed in the stock plastic oil line and thats what opened up and dumped oil on the header. The picture is of the autometer oil pressure guage that i had SITTING IN A BOX THAT I FORGOT about ahahaha..... ![]() This is my wife. BOOZER ![]() |
#44 |
PROJECT 7DEUCE
Glad the fire was minimal sounded pretty good though gotta love the b.b. chevys. Love those front daisey wheels too..
#45 |
BlahBlahBlah
Wondered what all that smoke over the Frylands was today. Glad you got it all sorted out.
#46 | ||
PITbut
ya ya. It was ALMOST that bad... SOOOO glad i had a fire extinguisher... I moved my fuel filter and got everything else set where it should be. I decided im going to replace the rubber piece of the fuel line with some braided hose. Im also going to throw on the stock clutch fan for break in so i can guaruntee that it will stay cool. I dont think that little fan i had will work at all... PT 2 of the video will be up later today... |
#47 |
![]() Join Date: Dec 2006
Ditch that little see-through gas filter! There's a reason the factory doesn't have plastic parts on a PRESSURIZED FUEL LINE!!!
I'd say you dodged a bullet,no,a meteorite.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
#48 |
You are only going to see 5 to 6 PSI unless you have a special pump, plastic fuel filters are fine. FI is another story.
#49 |
Texas Big Wig
I like your wife
![]() Glad it didnt burn to a crisp, I know that any lil fire woulda freaked me out too I hate it when they back fire & you cant keep it running... |
#50 | |
