#26 |
Almost Satisfied
![]() Join Date: Mar 2002
Correct! Lost Wages and I are not going to have E-Brakes on the trucks. Now I know that will open a can of worms with some folks. Lost Wages just needs to get on the ball and cut those ebrake cable holders off his trailering arms!! hehehe
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
#27 |
POLEVAULT
THATS NOT A PIC OF MY FRAME (I WISH) ITS A PICTURE OFF OF PARTS WEBSITE.
bogey5 |
#28 |
Well here's another way to go. This way is through the frame so the exhaust can run and not interfere with anything a lot better. Some of you may be speaking of this.
Brandon |
#29 |
Fabricate till you "puke"
71Stepside, E brake.....whats that? Im not running the E brake on my truck either(alll them d@mn cables get in the way of stuff!). My thoughts are that its a parking brake for stick shift trucks(a brick is more low maintaince),& it sure wont stop you in the event of brake failure......might slow you down a little, but an auto trans truck dont need one! If you didnt open the can of worms....ill bet i did!........crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#30 |
Almost Satisfied
I hear ya crazy! Besides all of that I priced SS cables for that sucker and that cemented the deal that I don't want or need one.
Brabra, that is a slick truck. I don't like that routing because it forces you to run the exhaust out right at the back of the cab. That would be pretty loud in the truck IMO.
#31 |
Brabra that can't be real, It's a model right? I'm still droling!
#32 |
Hers a pic of one side of my through the frame pass throughs. Hope it works
