Old 12-29-2008, 04:52 PM   #26
LuckyHenriksen
LuckyHenriksen's Avatar
Re: Rims for my 70... help
The only way to get them cheaper is if you found a used set, or maybe another store will have them for a few bucks cheaper. Check on AR's site and see how much they want for them there. Thats why I never bought caps or trim rings for my ralleys, they want like 25 bucks apiece for this stuff
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-30-2008, 11:15 AM   #27
desertrat
desertrat's Avatar
I am (inpatiently) waiting to see pictures of it when you get the wheels installed.
"Men are like steel. When they lose their temper, they lose their worth." — Chuck Norris
desertrat is offline   Reply With Quote
Old 12-30-2008, 11:37 AM   #28
lts70
1970 Daily Driver
lts70's Avatar
desertrat I am (impatiently) waiting to take pictures of it when I get the wheels installed. First I have to figure out what I am going to do with my rear 6lug problem. I already have the 5lug rotors for up front but I still need to figure out If I am going to try to modify my old axles or purchase new or used 5lug axles to switch over the back. I need to go get some quotes from some machinist and also look up prices for new ones to compare my options. I thought I had some used ones lined up but the guy flaked on me. Then I also have to get new brakes and drums for a 71 or 72.
Any guidance or suggestions would be appreciated!!!
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 12-30-2008, 11:51 AM   #29
69chevybmx
69chevybmx's Avatar
TireRack.com has those caps, They are $25 each also. Most vendors charge a premium for their caps because it deters people from buying the cheap knock off wheels and then putting a cap on it to make it look like the name brand. It is kind of like putting a Ferrari body kit on a Fiero. It might look better and people think it was expensive, but underneath it is still a Fiero......
69chevybmx is offline   Reply With Quote
Old 12-30-2008, 11:52 AM   #30
jholley
jholley's Avatar
Summit sells replacement axles that are drilled for 5 lug. I think this link will take you to the right one.
http://store.summitracing.com/partde...5&autoview=sku
Jim
Garage fillers...
85 Chevy C10 Silverado LWB
07 Nissan Altima
2006 Mini Cooper S
jholley is offline   Reply With Quote
Old 12-30-2008, 12:32 PM   #31
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
On my '69, with stock rear axle, I used 15x10's with a 5-inch backspace. Since the '70-72 rear axle is wider (1-inch?), then the backspace would need to be deeper, wouldn't it? More backspace means less off-set to the outside.
This is the only shot I have that shows them, and I don't think you can tell enough by the view. Besides, it's disassembled.
Member Nr. 2770
Old 12-30-2008, 05:21 PM   #32
kcjones
I wish I was a cowboy
kcjones's Avatar
Here's a few things I learned recently when sizing wheels/tires:
1) Sometime in '70, they began installing the wider rearend, so some 1970 1/2 tons had the narrow, some the wide. If I remember correctly, both were 6 lug.
2) If you have the wide rearend, which I would say pretty confidently you do (58.5" backplate to backplate), you buy the regular 5 lug axles, ECE is your best bet because they'll know exactly what you need when you call, and their price is only about $5 higher than anywhere else. If you have the narrow (which I doubt), you'll just get the 6 to 5 conversion axles.
3) When using the wide rear axle, and disc brakes, your front track width is a little bit wider than the front. To compensate for this (if you want even tire to fenderwell gaps in front and back), you buy a wheel that has 1" less backspace if they're the same width. In other words, to get an even track width front and back, get a 15x7x4bs in front, and a 15x8x4bs in back. Essentially the front then extends the track width 3" on each side, and the rear wheels extend the track width 4" on each side, thus evening things out.
4) Lucky - your 10" wide, 5" bs wheels will be fine on your truck, bet you'll have at least an inch still available. Front discs you shouldn't go anymore than about 4" "frontspace", which is width minus bs (8" wide / 4" bs is as far out as you can stick without rubbing).
5) Tire sizes matter a lot when sizing all this stuff. A 275 tire will be an inch wider on a 10" rim than an 8" inch. Although I wouldn't put a 275 on a 10" wheel...
6) 7" wide wheel is no problem for 255/70. If you were going to run a 255/35/18, then you'd want an 8" wheel.
I could be completely wrong about some of this, so take what I say with a grain of salt!
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
Old 12-31-2008, 01:48 PM   #33
lts70
1970 Daily Driver
lts70's Avatar
Thanks for all of the help guys. So I have decided to buy new inner axles from summit racing. The same ones jholley suggested above. They are $99.95each and $199.90 for two. There is free shipping. Handling is $11.75. There is no tax because I am in Utah. So a grand total of $211.65.
Before I order these axles can some one tell me for sure they will fit my 58.5" backplate to backplate" 1970 posi rearend? Here is the link again
Thanks Guys!!
Old 12-31-2008, 02:44 PM   #34
kcjones
kcjones's Avatar
FYI, the "wide" rear end axle shafts are 31.5" long, the "narrow" rear end axle shafts are 30.75" long.
The axles you need (if in fact you have the "wide" rear end) are 30-spline, 31.5" long, 5x5 bolt pattern with 1/2" lug studs.
-Kris
Old 12-31-2008, 02:54 PM   #35
kcjones
kcjones's Avatar
Check this link, take a look at the "1970 Complete rear axle conversion, 31 1/2 inch kit"...pricier than the bare axles from Summit, but you get the drums, studs, axles, and cover gasket:
http://www.classicperform.com/6092ch...e%20Components
-Kris
Old 12-31-2008, 05:23 PM   #36
lts70
1970 Daily Driver
lts70's Avatar
Thanks kcjones that kit looks like the route I will take, $329 is not bad depending on how much their shipping and handling is. One question though. It said it is a complete 5lug conversion kit but there are no brake pads included. Are the 70's brake pads the same as the 71-72's or do I need to buy 72 year bake pads as well? Thanks!
Old 12-31-2008, 09:40 PM   #37
Pont406
I looked on ebay and can't find these wheels. I am looking for 5 lug wheels also. Can someone post a link? Thanks
Pont406 is offline   Reply With Quote
Old 12-31-2008, 10:45 PM   #38
HuggerCST
HuggerCST's Avatar
Yes, the rear brake shoes are the same. I'm about to do the same axle swap on my '70 this weekend, but I am using used axles from a '72 and used drums from a '85.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 01-02-2009, 11:37 AM   #39
lts70
1970 Daily Driver
lts70's Avatar
Pont406 here is a link to the ones I bought.
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
Thanks HuggerCST, IIRC I changed my back brakes not to long ago so that will save me some cash.
CCP's shipping was around $50 so out the door it would have been $380 total. So I went with summit's axles for $211.65 out the door. Drums cost me $75 for the set,$12.50 for the wheel bolt, and $3.65 for the seal. So all totaled up it was $303 to swap to 5lug in the back. By putting my own kit together I saved around $80.
Old 01-02-2009, 12:13 PM   #40
lts70
1970 Daily Driver
lts70's Avatar
When I put my new axles in I plan on changing the gear oil to a full synthetic. Before I button it back up and fill it with the new oil how should I clean it out besides draining it? Brake clean? Is there any thing else I should do or check while I have it pulled apart? Bearings or seals? Right now I have no problem with my posi slipping, no noise, no leaks. I am hoping i can just swap the axles out and be done with it for time and cost. But if there is someting I should do I want it done right.
Thanks guys
Old 01-05-2009, 02:28 PM   #41
kcjones
kcjones's Avatar
Thanks guys
I bet someone else has better advice/experience, but I'd say don't try to clean up the innards with anything. Drain and refill unless you see metal shavings or other foreign materials (gasket material, seal falling apart, grime). Cleaning with any cleaner would be you'd have to get all the cleaner out...not easy on a diff.
-Kris
Old 01-05-2009, 02:49 PM   #42
lts70
1970 Daily Driver
lts70's Avatar
kcjones that is a good point. I have not done this before so it is nice to get advice from you guys.I thought this thread was dead so I started a new thread "Rearend Advice" So some of this is a repost but what can you do?
More Questions:
I bought Valvoline Syn Power Full Synthetic 75W-90 Gear Oil and Lucas synthetic Oil Stabilizer Pure Synthetic that I use for my motor but on the back it says, " Adds additional lubricity and extra protection for any racing application; use in engines, transmissions and differentials". I figured I would go half and half. Is there a better option for Posi rearends?
How much capacity does the rear differential have? What ratio of oil to additive would you guys use? Would you use some thing else besides what I got for an additive or oil?
My shipping confirmation said I will get the axles today or tomorrow. I will be posting pics as I go.
Old 01-05-2009, 05:46 PM   #43
HuggerCST
HuggerCST's Avatar
If it were me, I'd use this stuff, or something equal. http://cgi.ebay.com/ebaymotors/GM-Li...271110005r6887
I've seen cases where a posi would pop and chatter, and all it needed was a gear oil change with posi lube. The oil stabilyzer may work too, I'm not sure, but I know the GM stuff does. By the way I changed my axles saturday and found both of my old axle races to be rough and pitted, which means I need new axle bearings. Be sure and check that while it's apart unless you already plan to change them.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 01-06-2009, 11:31 AM   #44
kcjones
kcjones's Avatar
HuggerCST is right, stick with the GM posi additive. You may be able to use both additives, but history has shown the GM additive is correct for posi diffs. Lockers and spools and trutracs are all a little different, but for Eaton type posis, put the GM posi additive in.
-Kris
Old 01-06-2009, 11:47 AM   #45
lts70
1970 Daily Driver
lts70's Avatar
That is why I love this site. Everyone knows alot about something and when you put us all toghther we know alot about most everything. Which helps us all learn and get the best results in the end. Thanks for all of the addvice guys it is nice to the have peace of mind that I know what it will take to do the job right the first time. I just hope I can help with questions you may have some day.
Old 01-06-2009, 03:33 PM   #46
lts70
1970 Daily Driver
lts70's Avatar
I may have found a solution to getting nicer caps for these wheels. I found a Coy's dealership here in Provo Utah that will sell me their caps for $10 each. Once I get the wheels on I think I will drive down and see how they look and fit held up to the wheel. If they look like I think they will I will definatly be getting them.
Old 01-15-2009, 08:40 PM   #47
pumpgas
pumpgas's Avatar
Can we get a new link to those sexy wheels please??
00' Z28 ("wifes" car)
92' Mustang w/sbc everything needs a little heart beat
87' GMC Sierra Classic Short Bed Fleet side almost stock
69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it
pumpgas is offline   Reply With Quote
Old 01-16-2009, 12:29 AM   #48
lts70
1970 Daily Driver
lts70's Avatar
These are the only ones I can find from that seller right now.
http://cgi.ebay.com/ebaymotors/15X10...3A1|240%3A1318
Or use the key words *BRAND NEW* HALIBRAND GASSER MAG WHEELS 15" in the search function
I would email him and let him know what you want. Or start watching his ebay store periodically for when he puts new ones up.
Old 01-16-2009, 07:23 AM   #49
pumpgas
pumpgas's Avatar
Thank you for posting a new link to these for some reason I think they will begin to sell again for him.. lol
Old 01-16-2009, 12:14 PM   #50
lts70
1970 Daily Driver
lts70's Avatar
No problem, I agree, at that price I would think they would be flying off of the shelf. Then again I may be bias as I have already made the purchase.
