#26 |
Re: Summit rear disc conversion kit
I found out some more info for what its worth. the car and truck flange is not the same. Also, it looks like the summit kit is really SSBC which is good to know.
#27 | |
![]() Join Date: Sep 2006
I just looked at the link for summit and their price is down to $386
#28 |
I just bought this kit. The bracket will not fit the 12 bolt truck flange. It wont even fit over the axle housing. I plan to machine the opening slightly so it will fit and drill new holes in the bracket to match the flange. I am still waiting on my new axles to verify the rotor will fit the axle before I do anything.
#29 |
[QU axlOTE=lindsey;3204876]I just bought this kit. The bracket will not fit the 12 bolt truck flange. It wont even fit over the axle housing. I plan to machine the opening slightly so it will fit and drill new holes in the bracket to match the flange. I am still waiting on my new axles to verify the rotor will fit the axle before I do anything.[/QUOTE]
I think your going to have another problem. I did ALOT of researching today. While redrilling the bracket to match the flange is no big deal, what you're other problem is going to be is the caliper fitting over the rotor. I'm only speculating here, but this is my reasoning: The axle flange offset(which is the distance from the face of your axle to the face of your axle flange is different from a truck 12 bolt to a car 12 bolt. Truck 12 bolt is 2.42 inches. A car 12 bolt for this particular kit should be between 2.75 and 3 inches. If you can keep me updated on your experience, I would appreciate it. |
#30 |
Good point. I may need more shims and longer bolts.
#31 | |
![]() Join Date: Feb 2008
Just some thoughts. Anyone have info on the possibility of this swap?
Bryan '52 Bel Air 2dr HT - in pieces '68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed “Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin "And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery) |
#32 | |
In case anyone is interested here is a pic of the exact brake kit except this is With the e-brake. retail on this kit is like $599.00 I believe. I can go as low $575.00 on them, but I don't have a ton of room. on the same kit from Summit which is without e-brake I can go $475.00. I know it's more than Summit, but to them it's just a loss leader. So they are losing on that kit in hopes that you buy other stuff.
Jeff Savaglio Scott's Hotrods Oxnard CA 93030 |
#33 |
So you guy's like to beat up horses too.
I have to admit I didn't understand that when I saw it either... |
#34 | |
VA72C10
![]() Join Date: Mar 2008
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#35 | |
The rotors you see in the picture do come that way drilled and slotted Justin www.scottshotrods.com |
#36 |
OK. I had to machine out the center of the bracket from 2-7/8" 2-15/16" and weld up the 8 mounting holes. I will drill new holes in the bracket to mount it to the axle flange and hopefully get everything installed this weekend.
#37 |
I got the drivers side mounted up last night. The only thing that has to be modified on the Summit kit is the bracket that mounts to the flange (see above). You could avoid welding up the holes and just rotating the bracket, but I wanted to be able to mount the caliper wherever Everything else fit like it was made for the truck. Nice kit and you cant beat the sale price.
#38 |
pictures? the caliper centered on the rotor without any modification?
#39 |
I will try to get some pictures for you soon. I thought there was going to be issues with getting the caliper to center over the rotor, but I just had to use the provided spacers and it lined up really close.
#40 |
Where's those pics!?!
