Old 12-10-2008, 08:47 PM   #26
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: Frame Sag
Did you put something like these on it??
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 12-10-2008, 09:22 PM   #27
mseymour
Re: Frame Sag
yep, they are the polyurethane red mounts, cant remember the name of them, but they also make the stops and bushings for leaf springs etc., yep that was the first thing i checked to make sure they were the right height etc., any ideas to stiffen up the frame/body?
mseymour is offline   Reply With Quote
Old 12-10-2008, 09:23 PM   #28
mseymour
Re: Frame Sag
yep, thats them the energy ones.
Old 12-10-2008, 10:46 PM   #29
BLUE THUNDER
BLUE THUNDER's Avatar
Re: Frame Sag
If you used the new mounts at the time of your build shimming is the way to go. I wld suggest loosen your body mounts in the area that you are trying to fix and start jacking up the body from the middle of the truck with a 4x4 spanning th rocker boxes til your lines are where you like them and then fill the gaps on the body mounts with shims and you're good to go. Hope that helps. Mario
BLUE THUNDER is offline   Reply With Quote
Old 12-10-2008, 10:51 PM   #30
AJs72K5
AJs72K5's Avatar
Re: Frame Sag
If you're going to add more shims, or adjust some, I'd recommend loosening all the body mounts on the tub. Otherwise you can cause some binding. It's a very tedious process.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 12-11-2008, 06:55 AM   #31
vtblazer
vtblazer's Avatar
Re: Frame Sag
Originally Posted by mseymour View Post
put it this way, there is @ a 1.5inch (the amount of spacer) dip in the frame right below the doors, if i put it on the lift or put a jack under the frame, it goes away. the door area is the weak point of the body, as there is no lateral support there
Torsion box & Lower 'A' pillar
I see that they run forward past the doors, but they are in good (solid) shape. what is allowing the sag? again I have to use 1-1.5 inches of spacers in the middle mounts to get the doors to close, other wise the body buckles in the middle
Possibly to much space under the firewall mount
dont have a top, if it was a little more rigid it would be ok, but the flex causes the doors to rub against the bed, rattles and has chipped the paint, I may end up doing some bracing underneath, if i can ever engineer it. I will probably try and find a roll bar for it first and see if I can connect everything
Big project but it does work, it's a band aid though
Everything your describing suggests your body mounts are not correctly adjusted, either not torqued enough, not shimmed enough or could even be torqued to much or shimmed to much.
Also, the torsion boxes ARE what's meant to keep the tub rigid in the door area, that's exactly what their there for, pull the rear cover off and check em out.
How are the lower 'A' pillars looking?
Is there any noticeable rust on the tub?
Keep in mind that these frames are designed to flex, have you compared it to another one to see if there's any differences?
Pics of a "good looking" lower 'A' pillar for ya.
#1 - looks pretty solid
#2 - ...guess not after all.
#3 - Here's the internal support system, it isn't your door openings sagging, it's your firewall moving/flexing here.
vtblazer is offline   Reply With Quote
Old 12-11-2008, 09:49 AM   #32
Jtrux
Jtrux's Avatar
Re: Frame Sag
You're not kidding. No fun at all.
Old 12-11-2008, 12:56 PM   #33
RED69K5
Re: Frame Sag
I have this same problem with my '72, but I haven't taken it apart yet to investigate the issue. I've read several threads about this issue, and everyone always says shims will fix it. They are probably right, but I don't know for sure. This link to a similar thread might help.
http://coloradok5.com/forums/showthr...Y+MOUNT&page=2
RED69K5 is offline   Reply With Quote
Old 12-11-2008, 01:33 PM   #34
vtblazer
vtblazer's Avatar
Re: Frame Sag
Same only different...
Old 12-11-2008, 04:45 PM   #35
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Frame Sag
Originally Posted by jaros44sr View Post
Hinges are in good shape right?
If they are aftermarket this could be some of the issue, I had this problem.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 12-14-2008, 07:40 PM   #36
mseymour
Re: Frame Sag
anybody know where to get those little striker plates (chrome blocks) at the top of the doors
Old 12-14-2008, 08:30 PM   #37
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Frame Sag
Repops aren't made. You'll have to start searching for used ones. If you become a subscribing member, you can post a "wanted-to-buy."
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
