12-21-2008, 06:27 PM | #26 |
Re: Caddy Light Install
i said in my previous post he is doing fine it was just some advice from someone who has done customizing similar to what he has done. didnt realize some of you guys are so sensitive. jrsmith_2010 i thought you were using the bondo to just fill in the empty spots, my bad on that. if practicing on other metal and taking your time means im critizing too much, then sorry for writing anything.
12-21-2008, 07:51 PM | #27 |
Low & Fast!
I am just happy that you are working on trucks and not out doing bad things. You know how teens are now. So good job!
Here is a link that has fillers and I know I have seen a pre made box that you can by too. But you can try and make it if you like. Please keep doing what you are doing. Let us know if you need anything.. http://www.*****************/node/331 Later, Trav
12-21-2008, 08:19 PM | #28 |
Good Job. It looks like you have a nice project going on.
12-21-2008, 10:57 PM | #29 |
I like turtles...
well i got the other side hooked up and working. now i need to trace the benzle around the hole and grind it smooth it out, and then make a way for it to screw in. they are really bright! i like them alot.
thanks for the info and links, it helped me out shows how bright they r they look awesome to show how cold it was
1979 Silverado- lowered 5/7, 20 inch Boss rims, everything shaved, caddy lights, billet interior, UP FOR SALE! 1983 Scottsdale-on the back burner...SOLD!!! 1992 Silverado- extended cab, stock for now, but no promises SOLD!!! 2006 Chevy Cobalt-college car, staying stock Whatever can't get fixed with a hammer, a roll of duct tape, a clothes hanger, a tube of glue, and a case of beer, can wait until tomorrow. |
12-22-2008, 12:16 PM | #30 |
It'd be alot cooler if you did
You can also buy those tail light fillers much cheaper here. They are the same ones I have on my truck.
http://www.truckshop.com/catalog/73-...n-p-18125.html |
12-22-2008, 12:20 PM | #31 |
I like turtles...
thanks smashingchuck, its funny how they say (weld on) do they make them (bolt on)?
12-22-2008, 01:31 PM | #32 |
hell, even the bolt on stuff doesn't bolt onto my truck
12-22-2008, 01:55 PM | #33 |
Trucker.
Quick modding it and you won't have that problem.
12-22-2008, 02:06 PM | #34 |
I like turtles...
^^ mines gettin to that point too, nothin bolts to where it did stock in 79
12-22-2008, 03:38 PM | #35 |
Real Projects never die
sounds like you need a bigger hammer and a drill jr.
maybe picking that 78 up this weekend... short step bed south of lawrence, id have a full bodied 78, clear title, needs tires and a transfer case.. mmwahhahahhaa. But man do those caddy lights look sexy. Are they really that bright in person? or is it just the camera?
Ill put it this way, ive got a few lawn ornaments My name tag says Ryan KansasTwister On other forums
12-22-2008, 06:26 PM | #36 | |
I like turtles...
sweet dude, cant wait to see u tear it about and rebuild! yea they r REALLY bright, its like 10x as bright as the euros i had in it
12-22-2008, 07:34 PM | #37 |
looks good man just take your time cleaning it up .... i been trying to convince my gf to get me a welder for christmas so i can start messin a lil more with my truck... keep it up
12-22-2008, 07:49 PM | #38 |
It Is What It Is,,,,
Lookin good, And it does look like a larger task to take on. But just as I, learning skillzz,,,,
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture My Rat Den |
12-22-2008, 09:00 PM | #39 |
high-Tech Red Neck
JR, I am going to throw a little constructive criticism at you. It was brought up that you aren't welding out 100%, trust me on this, it will lead to problems in the long run. What you need to do is move around as you weld. weld a very small section, then move on to another further away, and bounce around until you are welded out.
Also, keep your heat low, and don't drag long beads. Also if the wind is blowing, put up a barrier so as that your shielding gas does not get blown away. You want to weld it all out for another reason as well. The bondo doesn't have a expansion/contraction rate that is identical to the steel, it is close, but not the same. when you have two pieces of metal that meet that are not welded together, the bondo will crack here because it is not designed to work in that function. It is filler, not glue. Another thing you can do to keep warping to a minimum is get some old towels, fold em over a few times, wet them down with cold water, and hang them over the side of the truck, an inch or so away from where you are welding. this will absorb the heat, and keep the panel from heating rapidly, and thus keep it from warping. And one final thought, if it doesn't work out cutting the lights in vertically like you have, I would seriously look at frenching them into your roll pan turned sideways. Good Luck - Beast
"He used to be a pretty nice feller, now he's a welder!" |
12-22-2008, 09:09 PM | #40 | |
I like turtles...
12-22-2008, 10:00 PM | #41 | |
Low & Fast!
12-22-2008, 11:21 PM | #42 |
So jr, what next modification u going to do? The skys the limit.
Its Kool to be a square 2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's 1985 C-10 ......My dream truck (under construction) 1984 k 10 Silverado...6" lift with 38.5 super swampers New Mexico Member --- Member of the Square Body Club--- |
12-22-2008, 11:23 PM | #43 |
I like turtles...
well i think im pretty much done when the caddy lights r in, the interior is all custom, motor is healthy and the body is almost done. hopin by the end of winter break it will be in paint
but i am gonna do something custom with the licence tag, im gonna make a holder where i can mount it up by the cab in the corner of the bed on the drivers side
1979 Silverado- lowered 5/7, 20 inch Boss rims, everything shaved, caddy lights, billet interior, UP FOR SALE! 1983 Scottsdale-on the back burner...SOLD!!! 1992 Silverado- extended cab, stock for now, but no promises SOLD!!! 2006 Chevy Cobalt-college car, staying stock Whatever can't get fixed with a hammer, a roll of duct tape, a clothes hanger, a tube of glue, and a case of beer, can wait until tomorrow. Last edited by jrsmith_2010; 12-22-2008 at 11:24 PM. |
12-23-2008, 04:53 PM | #44 |
looks sweet
72 cheyenne super 83 chevy...4x4...454 |
12-23-2008, 11:13 PM | #45 |
I like turtles...
well they r closer to be done! should be done for too long! heres what went down today. ive decided that when they r in, its gonna be sunk in an inch from the normal body line, for a total of 2 inches where i need to weld in the clip nut for it to screw in.
heres to show how much i have to fill in when i weld it all up, i cut to much but its not to bad it can be fixed. passenger side drivers side
1979 Silverado- lowered 5/7, 20 inch Boss rims, everything shaved, caddy lights, billet interior, UP FOR SALE! 1983 Scottsdale-on the back burner...SOLD!!! 1992 Silverado- extended cab, stock for now, but no promises SOLD!!! 2006 Chevy Cobalt-college car, staying stock Whatever can't get fixed with a hammer, a roll of duct tape, a clothes hanger, a tube of glue, and a case of beer, can wait until tomorrow. Last edited by jrsmith_2010; 12-23-2008 at 11:25 PM. |
12-23-2008, 11:21 PM | #46 |
I like turtles...
more
did some side projects as well, finished up shaving the cargo light, and relocationg the licence plate and for the tag,i got in the Christmas spirit and wraped it with wrapping paper!! it a candy cane!!
12-24-2008, 01:26 AM | #47 |
what did you do wtih your cargo light? pm me if you dont want it on your shelf lol
12-24-2008, 01:32 AM | #48 |
I like turtles...
yea i still got it, i couldnt get it to work after i redid my interior so i took it out, i still have the wiring harness too
12-24-2008, 01:52 AM | #49 |
I give it to you for having the guts to cut your truck up...... BUT is there anyone near him that would volunteer to help him out a little??? I LOVE caddy tails in just about anything that they don't belong in.. AND NO before everyone jumps on my back.. I'm not bashing him but someone needs to help him cause there isn't going to be any bed left to fix....... He is definitely not scared to work and shown initiative. He deserves some help.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
12-24-2008, 02:00 AM | #50 | |
I like turtles...
