Old 01-08-2009, 03:17 PM   #26
ont_guy_38
ont_guy_38's Avatar
Re: Guys with 15x10 Wheels - Inside Please
Originally Posted by Richard D View Post
I need to get some good overall shots of the truck, but here are some to show the fit.
Yes Richard I would really like to see more pictures of this setup,I,m liking the idea
ont_guy_38 is offline   Reply With Quote
Old 01-08-2009, 06:53 PM   #27
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Originally Posted by moneyeater View Post
I have 10x 15 589 eagle alloys all around with 295/50 and 265/50 Bfgs but i canīt tell you the backspacing,sorry! The papers say ET -45 mm but i canīt tell what that means!
That would mean a negative offset of 45 millimeters. 0 offset would mean the wheel mounting surface is halfway between the rim hoops, or 5 inch backspace on a 10 inch wheel. 45 millimeters is about 1 7/8 inches. If I'm figuring correctly, the backspacing is 3 1/8. That seems like it would push out of the fenders, though. I could be wrong.
-- Will
killthewabbit is offline   Reply With Quote
Old 01-11-2009, 09:49 AM   #28
moneyeater
moneyeater's Avatar
Originally Posted by JW76 View Post
moneyeater, what size drop do you have? That looks great
No i donīt have bags!
I have a static drop of 4 and 6 inches with belltech spindles,springs and a flipkit and shocks all around!
The backspacing of the wheels is right with what lillthewabbit says!
My little US vehicle parts business:
http://www.thegearheaddepot.com/
Come have a look!
ī81 GMC C 10, Spanish Red
moneyeater is offline   Reply With Quote
Old 01-12-2009, 08:56 AM   #29
Richard D
Richard D's Avatar
I'll try to snap a few in the next day or so.
Richard D is offline   Reply With Quote
Old 01-18-2009, 03:54 AM   #30
Pyrotechnic
Pyrotechnic's Avatar
I'm a little late to the party but here goes. 15x8 with 3.75 backspace up front with 275/60/15 tires and 15x10 with 3.75 backspace in the rear with 325/50/15 drag radials.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 01-18-2009, 04:21 AM   #31
Slammed '87
Slammed '87's Avatar
nice truck pyrotechnic! I'm thinkin you should lower the front 3 more inches and the rear about 2 tho lol.
Too bad BFG doesn't make a larger tire than the 295 in the radial T/A. I have been keepin my eyes open for the pirelli 345/45/15 tires normally used on Lambouginis. My buddy who owns one told me they are really hard to come by, and sadly very exspensive when you can find them.
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough!
Slammed '87 is offline   Reply With Quote
Old 07-28-2009, 03:59 PM   #32
cyberpine
cyberpine's Avatar
Originally Posted by westie 666 View Post
Here is mine 15x10 4.5 back space with 29x15x12.5 tyres
Is this dropped just in the front and a stock rear? If so, how much is the drop?and what did you use?
Wow I really like this look and it's what I'm going for once my project gets to tires and suspension.
http://picasaweb.google.com/cyberpine/1987C10#
cyberpine is offline   Reply With Quote
Old 07-28-2009, 04:01 PM   #33
cyberpine
cyberpine's Avatar
Originally Posted by vern350 View Post
4.5 inch backspacing with 295/50/15. I don't have these on now because of the lack of drop and the little tires make things looks out of place.
Is this truck stock 2wd hieght.. cause I think that looks awsome.. I would have thought those 50s would have thought the gap would have appeared greater. By any chance do you have more shots of the truck when it was with these tires?
Thank you.
Old 07-28-2009, 04:11 PM   #34
westie 666
westie 666's Avatar
That pic was before I dropped the rear, the front just has 1 coil cut, the rear now has 4 leaves removed and the rest were reworked, I'm left with 2 leaves and the helper. I'll find a pic and post it.
77 Cheyenne no longer in bits
westie 666 is offline   Reply With Quote
Old 07-28-2009, 04:42 PM   #35
cyberpine
cyberpine's Avatar
Really like that front only drop look.
sorry about the 20 questions.
So you only cut one full coil? That's cutting a perfect ring right? .. nothing else? Did you notice any adverse effect in the ride like stiffness, stearing, handling or anything else? Did you have to get it aligned afterwards? when you cut the coil how much did it drop?
I wonder why we don't hear about more people cutting coils instead of buying kits?
How tough of a job was it to do that ? Any special tools needed?
I just read that for every 1/4 coil you cut expect a full inch drop.. wow. Are you guys cutting coils while they are still in place? Any good DIY writeups for cutting coils on the C10? What are people using to cut?
Thanks!
Old 07-28-2009, 05:05 PM   #36
flamingbig10
6.0 powered square
flamingbig10's Avatar
to cut the coils you'll first need to remove them from truck, 1 coil will bring you down 2" inches, to cut you'll will need use some thing like saw saw, cut off wheel or something similar, but not a torch it make the entire coil week, the rides not to bad if you coil are good to start with
my truck with one cut coil in front and stock in the back
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-28-2009, 05:23 PM   #37
cyberpine
cyberpine's Avatar
SWEET! Thank you! I'm going to do the exact same thing. If anybody knows of a write up with step by steps and pics, please send it to me.
BTW, do you think 295/50/15s on the stock 15x8 Rallys would fit in the front with no problems, even at full lock and sharp turns up ramps?
Old 07-28-2009, 05:37 PM   #38
flamingbig10
6.0 powered square
295/50 will work with the rallies and there might slight rubbing on the truck not for sure but with 275/60 you won't have any problems
Aaron
Old 07-29-2009, 10:19 AM   #39
cyberpine
cyberpine's Avatar
Is that based on a 2 inch drop in the front and if there is a rub where will it be? Someone implied I could probably hammer the problem away. Also wonder in that slight rub is aggevated with swaying.
One issue with 275/60/15 is that I think it's a taller tire than 295/50/15.. Really wanting 295 in the back and 295/60/15 is a rare and expensive tire.
I'm okay with some rubbing on the inside if I can cut and hammer it away.
Anybody know what I can expect to pay for a decent 2 inch drop coils? Recommended 2" drop Spring Coils? Ground Force any good?
Thanks.
Old 07-29-2009, 11:01 AM   #40
vern350
like a rock
vern350's Avatar
cyberpine - my truck with the 15x10s was sitting at stock 2wd height. I did have more pitures of it, but I cant seem to find any right now. If I come across any, I'll let you know or post them here.
vern350 is offline   Reply With Quote
Old 07-29-2009, 11:33 AM   #41
flamingbig10
6.0 powered square
Thanks.
a 275/60/15 is almost 2" taller than 295/50 but a 235/60/15 is just a tad shorter than 295/50, I think you be fine, there's a guy on hear with 305/35/26 and he said he had very little rubbing, ground force is a good brand and summit racing sells them really cheap
http://www.summitracing.com/parts/SUM-G727/
Aaron
Old 07-29-2009, 11:43 AM   #42
cyberpine
cyberpine's Avatar
I'm only concerned with the front rear is going to stay stock and I was planning to add 1.5 " spacer anyways for an even wider look back there.
305/35/26 is 34.4 x 12.. wow. In the front? with a drop and no cutting ?.. that doesn't sound right. Do you have the link to his pics?
Appreciate the info.. Thank you!
Old 07-29-2009, 11:49 AM   #43
geunther
geunther's Avatar
I am trying to locate 10" x 15 rally wheels. I know the originals were 8" but I want to retain the factory look with factory beauty rings and center caps with a wider wheel.
Open for ideas
The lid is stuck on my jar of anti seize
geunther is offline   Reply With Quote
Old 07-29-2009, 01:49 PM   #44
Tony_SS
Tony_SS's Avatar
Open for ideas
Wheel Vintiques has them.
Tony_SS is offline   Reply With Quote
Old 07-29-2009, 02:56 PM   #45
flamingbig10
6.0 powered square
http://www.summitracing.com/parts/WVI-42-500505/
Aaron
Old 07-29-2009, 05:11 PM   #46
geunther
geunther's Avatar
Sorry, my mistake, I should have mentioned 4x4. Needing 6 holes. Thanks big10 and Tony, I will check both places.
Old 07-29-2009, 09:05 PM   #47
ghettoluxury
ghettoluxury's Avatar
15x10's not sure on backspacing but the tires are 33/12.5/15
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 07-31-2009, 08:15 PM   #48
vern350
like a rock
vern350's Avatar
cyberpine - heres another picture I found
Old 08-01-2009, 02:25 AM   #49
Colesnsty68
Colesnsty68's Avatar
i'd like to help you here but the guy i bought my 10in truck ralleys from didnt have a lotta info. i'll have to check and let you know. that and they where custom made.
1970 Chevrolet custom camper 20
2000 F@$d F250 Powerjoke
"And i still like bologna on white bread now and then" -Alan Jackson
Colesnsty68 is offline   Reply With Quote
Old 08-01-2009, 11:43 AM   #50
jjgmc
jjgmc's Avatar
15x10 4inch bs 305/50/15
jjgmc is offline   Reply With Quote
