01-02-2009, 10:14 PM | #26 |
Re: rear locker??
i am still looking for my camera cable sorry for delay on pictures
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_- 1972 K10 4"lift 33"tires (soon to be bigger and better) 2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's |
01-03-2009, 12:44 PM | #27 |
Re: rear locker??
I have taken 14 bolt apart and added frictions and shims to tighten it up. When I did so I removed the flyweight and governor mechanism. Now it acts like a locker on low traction surfaces. It will still slip a little in corners but tightens up pretty good on dirt. Enough to keep me happy. It behaves a lot like a Detroit locker off road.
01-03-2009, 12:54 PM | #28 |
Re: rear locker??
If the snapping and popping you describe, could it also be a clicking type noise? You may have a no-spin aka Detroit locker. The noise is the engagement teeth racheting past each other. Supposedly the locker out of a 14 bolt will interchange with the ones in the Eaton. The difference is the inner axle splines. The Eaton has less splines (17 or 19 I believe) and the 14 bolt has 30 if I remember correctly.
03-08-2009, 08:29 PM | #29 |
Re: rear locker??
03-08-2009, 09:44 PM | #30 |
Re: rear locker??
Yessir, No-Spin (Detroit). You can tell by looking through the holes in the carrier...if you just saw gear teeth, it would be an open diff (you'd be seeing the spider gears). But there is just smooth metal, which means locker. Congrats
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
03-09-2009, 08:51 PM | #31 |
Re: rear locker??
i pulled it apart and its clean inside and very little slop/play i ordered my disc brakes and now its time to sand blast housing and paint and install
03-10-2009, 12:21 AM | #32 |
72 C30 Trailer Queen
Re: rear locker??
I had a NOS locker with the factory literature, here goes:
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts |
03-10-2009, 08:20 PM | #33 |
Re: rear locker??
very helpful info
