12-26-2008, 10:11 PM | #26 |
1967 C10 SWB
Re: Goodbye Long Bed, Hello Short Bed
I got in some good practice welding the other day by replacing my drivers side rocker.
Here are a few pics. Thanks again LFD.Inc for the good thread on how to do this. There wasn't much left to cut out but it is solid now. Here is a shot of the inner rocker. I will post one of the final product soon. This took most of the day because I had to replace the rear cab support as well. Replace rocker panel and cab support ~ 8 hours VV Last edited by vexvader; 12-26-2008 at 11:53 PM. |
12-26-2008, 10:15 PM | #27 |
VA72C10
Looks like a great project...I love my LWB because they are getting more and more rare because they were well used and now are being turned into SWB. Plus, when dropped, they look really good to me personally. But I know the value is in the SWB trucks and that 90% prefer them.
Looking for a 67-72 swb or blazer project in or around VA. |
12-26-2008, 10:20 PM | #28 |
Thats a lot of rust
12-26-2008, 10:25 PM | #29 | |
1967 C10 SWB
What can I say? I like the short beds... |
12-26-2008, 10:28 PM | #30 |
1967 C10 SWB
Yeah, it is strange. The driver side rocker was just about gone from all the rust, but there is hardly any other rust in the cab. I am going to replace the passenger side rocker while I am at it, and there is a little hole in the cab corner on the driver side, but the rest of the cab is good. Oh yeah, the driver side door was toast also. I bought a new one from goodmark.
I also have a completely new 1967 front clip from goodmark as well. I figured, what the heck... why buy a 67 SWB, when I can just make one... VV Last edited by vexvader; 12-26-2008 at 10:55 PM. |
12-26-2008, 10:58 PM | #31 |
Tot Roddin'
Nice work on the project! Keep us posted and keep the pics coming.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-26-2008, 11:00 PM | #32 |
1967 C10 SWB
12-26-2008, 11:35 PM | #33 |
1967 C10 SWB
Here is what I did today.
1. Unbolted the bed and removed it. It had 8 bolts in it and I had to use a cut of wheel on 6 of them. The were so rusty the would not budge, even after soaking them in liquid wrench. This was easy and I plan to buy new bolts anyway. I uses LFD.Inc "one man cab and bed lift" that I built. I would definitely recommend it. I did it all by my "one little man" self. Well maybe not "little" 6 foot 2 and 255 lbs. I will definitely have another person help when I put the new bed on. It is hard to raise and lower the hoist and hold the bed straight. 2. Next I cut off the front bed mounts. They won't be needed when I shorten the frame. They came off very easy. I cut the head off of the rivet and then drilled out the top. Once I drilled into the cab mount, they popped right off. Here is a little trick. I filled the cap of an quart of chain saw oil and dipped the tip of the drill bit in every 20 seconds or so. The rivet drilled out like butter. I plan to do the same thing with the rear cab mounts when I remove them. Here is another trick. Cut off and drill out the back rivet and then use a hammer to knock the bed mount around and you will have easy access to the front rivet with a cut off wheel. Removing the bed ~ 2 hours (rusty bolts) Removing the cab mounts ~ 30 mins Set up and clean up ~ 2 hours (I hate that!) |
12-26-2008, 11:41 PM | #34 |
Since the box is off, I am assuming you are going to cut the frame rather than replace it? Are you going to shorten the box or replace it with a SWB?
So far it is looking good!!!
1972 Cheyenne C10 Unrestored Original-3 Owner-RUST FREE Texas Truck Big Block-TH400-PS-PB-AC-AM/FM Radio |
12-26-2008, 11:45 PM | #35 |
1967 C10 SWB
Here is a question...
The front rivet on the front bed mount actually goes through the frame to the trailing arm cross member. I don't think it is really needed but I thought I would just weld a top on it after I cut it off to remove the bed mount. There are several cross member rivets loose. I thought about welding all the cross members to the frame. I saw this on a Trucks TV show and they said it will help to "stiffen" up the frame. I would not do it to the tranny cross member obviously, but would like to do it to the trailing arm one, rear shock member one and the one in the front of the truck right under the radiator. I know it would make it really hard to remove them if I ever needed to, but when would I ever need to??? What are ya'll thoughts on that. Any reason why I shouldn't do it? |
12-26-2008, 11:48 PM | #36 | |
1967 C10 SWB
12-27-2008, 12:22 AM | #37 |
Still livin the "dream" in '54
Sweet looking project. And welcome to the site BTW
I like the color choice you have picked. Gotta love orange and white! Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo |
12-27-2008, 12:43 AM | #38 |
1967 C10 SWB
12-27-2008, 01:09 AM | #39 |
Formerly- 1972SuperCheyenne
Welcome to the board, and good luck on your build.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
12-27-2008, 02:04 AM | #40 |
hey man im sry about my comments before...dad got on here and left some comments about the bed.. i told him about rules.. so mods i had talk with him...hope everything is cool...
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
12-27-2008, 02:34 AM | #41 | |
J/K Everything is fine. Don
12-27-2008, 07:37 AM | #42 |
Resident of Here
Whoa Whoa Whoa! I never said anything about buying the bed! I asked what he is going to do with it! Then went to bed, so I dont know what he said in response! Dont blame me! I wasn't even here to respond!
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
12-27-2008, 08:04 AM | #43 |
BFH is a really big hammer.
12-27-2008, 08:08 AM | #44 |
Resident of Here
BFG is a really big gun!
12-27-2008, 08:16 AM | #45 |
1967 C10 SWB
Let's just move on guys and forget about the long bed...
I read the rules and won't respond to any questions about selling stuff. Anyways I plan to join soon. vv Last edited by vexvader; 12-27-2008 at 08:20 AM. |
12-27-2008, 08:41 AM | #46 |
1967 C10 SWB
Hey guys... I moved this thread to the "projects and builds" thread. It will continue from there. Check it out.
http://67-72chevytrucks.com/vboard/n...te=1&p=3048841 THANKS FOR THE HELP GUYS! |
