12-31-2008, 11:58 AM | #26 | |
Re: Any home made car trailers here?
Looks like yours is very low to the ground. Did you use drop axles? Does it have springs on it or is it a rigid trailer?
'67 C20 Lwb 350 4-Speed '01 Chrysler Concorde LXI (wifes ride) '91 Gmc Suburban 3/4 2wd 454 Tbi '51 Jeep Cj3a "Willys" 350 V8 |
12-31-2008, 12:32 PM | #27 |
I'M TRUCK CRAZY!
12-31-2008, 12:47 PM | #28 |
high-Tech Red Neck
Thank you, and yes it is AutoCAD R14
"He used to be a pretty nice feller, now he's a welder!" |
12-31-2008, 12:51 PM | #29 |
I'M TRUCK CRAZY!
Cool MrBeast. I always want to draw something for myself but end up coming to the site and getting sucked into it. HAHAHAHAHA
I LOVE THIS SITE! |
12-31-2008, 01:01 PM | #30 |
high-Tech Red Neck
*stands on chair and screams* THIS PLACE IS NOT ADDICTING, AND I DO NOT HAVE A PROBLEM!!!!
12-31-2008, 01:09 PM | #31 |
Here's the one I built, tows great.
12-31-2008, 01:32 PM | #32 |
I'M TRUCK CRAZY!
12-31-2008, 01:56 PM | #33 | |
Rottenwood Garage Member
With that said...if the steel, power for the welder and you consider your sweat equity FREE...than it may be cheaper to build one!
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 12-31-2008 at 02:00 PM. |
12-31-2008, 02:40 PM | #34 |
I dont consider my time free. The point to all this is i want to build a trailer for myself for the fact is then i can say Yep i built that. Yep those custom touches are all mine. I have the main rails for it. I can get steel cheap (friend on the inside) And i can do it in stages.
12-31-2008, 02:41 PM | #35 |
You need to find one at a dealer that you like and get the best price. Then compare that to one you want to build. I helped my uncle build several trailers over the years. The only reason we built them was to make them stronger and customize them the way we want. We would over build them which makes them stronger but also makes them heavier. The weight adds up fast so do your math to figure your axles out. We put two 6000lbs axles under his hydraulic tilt trailer but had it registered for 10,000lbs or you need to have it inspected twice yearly. But we would usually build two at a time and in the end it isn't much cheaper. There is a lot of work involved, cut and welding metal, paint, wiring and lights, axles, wood for the floor, tie downs and the hassle of getting a title.
We would use channel for everything. |
12-31-2008, 02:47 PM | #36 |
Mr. Beast, My uncle and buddy's have three total hydraulic tilt trailers like the one you want built. Theirs have a 19ft deck and removable fenders which came in handy several times. These are nice trailers and you will love it.
12-31-2008, 03:35 PM | #37 |
high-Tech Red Neck
I think so, I have wanted to build one of these for a long time, it is actually a variation of the trailers my dad used to have, he had 2 tilt decks, unfortunately his guys beat them to death, but that is the way it goes. I am also working on a design for a 40' tilt deck goose neck. It would have triple axles on it and everything, but would require a much larger ram to tilt. and a pony motor, and that gets expensive fast.
12-31-2008, 03:45 PM | #38 |
i have a trailer i built about 15 years ago, get alot of comments on it and it is " overbuilt" used to use mobile home axles on it and that will do but not very nice. in my opinion, the best thing would be 5k tandem with both being brake axles. maybe use the mobile home axles just not the spindles, the tube is 5k - 8k axle rated and weld your own hubs on . the frame i used is mobile home I beam. i cut 12" I beam in half and made 6" I beam double thickness out of it welded front and back pattern , then took the same I beam and made 4" double thickness for the toungue all the way to the front axle. hate to toot my own horn but i have never seen a trailer quite like it and have loaded 14k plus on it and it did not even phase it. I plan on building a new one the same way only 24' or so , with a goosneck. IT IS TWO TITTY TUFF guaranteed
12-31-2008, 04:07 PM | #39 |
The LuvShack Garage
Can't say I have built any, but I agree on this quote above.
I put one on my LWB Truck Bed Trailer that I bought in Oct.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
12-31-2008, 04:26 PM | #40 |
Hey MrBeast that drawing looks like my trailer, but mine has an 18' deck. 16' in my opinion just isn't long enough. I didn't build it, but it is titled. Has 3500lb axles,electric brakes on both axles. ramps set in there spot of the back. The way I load, is basically pull the pin, drive or winch the vechicle on the ramps as it rolls up it pushes down and tilts the trailer and then eases itself right back down. Neat set up.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
12-31-2008, 09:33 PM | #41 |
72 chevys 4 life
chevrolet on the tailgate is upside down and backwards?
I dont call it being young and dumb....I call it young and havin fun |
12-31-2008, 09:57 PM | #42 |
Hahahahah! Good eye! Looks like somebody went to alot of work on that or something!
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
12-31-2008, 10:21 PM | #43 |
LET'S GO RACIN'
Here's a trailer i built. The axles are from a 5th wheel camper trailer, just made them wider to fit my need. 6in channel for the main frame and 3in channel for stringers. 1/8 tread plate 5x10 sheets(very heavy). 20 ft floor with 2 ft dovetail. Fenders are made out of same tread plate. Has hauled anything i've wanted. Also ran some angle down the length of trailer where the tire's run. Could have bought one, but wanted to make my own. Also added a toolbox in the floor up front. ""
Daren 04 Chevy Extend cab 2500HD 6.0 Liter 4x4 71 CHEVY 3/4 4X4 402 BB, th400/np205, dana44/eaton ho52 w/4:10-TOY Rip El Jay RIP BOBBO'S MOM |
12-31-2008, 10:30 PM | #44 |
Resident of Here
I'll buy or build a 40' goose neck trailer in a few years. That'll be one long sucker behind a crew cab dually.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
01-01-2009, 12:24 AM | #45 |
For all the guys that have built your own trailers. I have a couple questions. I am wanting my trailer to be 20 ft long.
How long does the tongue need to be? What is the IDEAL placement for axles?
01-01-2009, 12:40 AM | #46 |
LET'S GO RACIN'
On the axles, i was told to use the 60/40 method. On the length of the tongue, i'm not sure.
01-01-2009, 03:02 AM | #47 |
high-Tech Red Neck
To clarify, The 60/40 rule would be to put 60% of the weight on the tires, and and 40% on the tongue.
01-01-2009, 03:30 AM | #48 |
Hey guys I also subscribe to a lot of your thinking on these posts. I build and fix things, that's what I do, and it's how I relax. To me it's very rewarding to say "I built it myself."
Like a lot of you I over engineer stuff but I can garuntee it won't break! I agree with the 5K axles as well. I have my 5" channel for my 18 footer all cut up and it's just waiting for shop space. It will be pulled by my 71 C30 I am building now. Imacarguytoo, the length from your axle center line to your ball should be at least twice the tread width. Otherwise you'll have it doing the watoosie behind you down the road. Richard |
01-01-2009, 03:35 AM | #49 |
Just found these on craiglist!
Thought they fit this thread pretty good. If I had the extra $ I'd be checkin 'em out, http://stlouis.craigslist.org/pts/976153510.html
01-01-2009, 12:03 PM | #50 |
72 C30 Trailer Queen
I just bought a 20' hydraulic tilt deck aluminum trailer from H&H Trailer.
1600 pounds empty and a 12k gross rating. It has an electric hydraulic power pack, so tilting the trailer up takes about 10 seconds of pushing a button. Load up and then hydraulic power down takes another 10 seconds. Tie down and go!
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts |
