Old 11-17-2014, 06:24 PM   #26
hotrod66
hotrod66's Avatar
Re: Anyone Using 4.1 Straight Six Engine?
i did the same thing to my truck used a 1985 250 with a early head i did well for a long time drove it every day for 4 years
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 11-18-2014, 12:04 AM   #27
RoughKuntry
RoughKuntry's Avatar
Went through the carb and cleaned the dirt out, hooked everything up. And still have this problem, I do think its time to buy or make a new intake manifold using my Quadra jet on a I6
RoughKuntry
73 GMC 25 HUNDRED :Sold
79 GMC High Sierra 4x4 (Ma-Duece) :Sold
99 Chevrolet LS 4.8l/5 Speed Manual 4x4 :Selling
88 Chevrolet Burban 2500 4x4 :Buying
RoughKuntry is offline   Reply With Quote
Old 11-18-2014, 12:38 AM   #28
LVPhotos
LVPhotos's Avatar
Just wondering if anyone has thought to use 4.2lt 6 from Trailblazer?
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 11-18-2014, 01:24 PM   #29
RoughKuntry
Haven't seen that one but the 262 v6 is a great motor.
RoughKuntry
Old 11-18-2014, 02:53 PM   #30
TJ's Chevy
TJ's Chevy's Avatar
You can purchase a Clifford intake and just buy an adapter to adapt a quadra jet carb to it. Clifford makes a sweet intake. You can see it at Clifford Performance.com
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-18-2014, 03:50 PM   #31
63burban
Chevy addict
Non-integrated head 6 with a good carb and hei ignition is the way to go.
63burban is offline   Reply With Quote
Old 11-18-2014, 03:51 PM   #32
63burban
Chevy addict
Is your choke working?
Old 11-18-2014, 04:21 PM   #33
chevy_mike
Never Ending Projects
chevy_mike's Avatar
This is in my '64 Chevy II wagon but it's a '70 250 with the Clifford intake, shorty headers and Holley 390cfm 4 brl. carb. Actually gets up and moves fairly well.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-18-2014, 05:36 PM   #34
NEWFISHER
NEWFISHER's Avatar
Mine, I also have the heated Clifford intake, Holley 390 and shorty cast Langdon headers. It's also sporting a huge cam, lump ported, milled and rechambered heads with bigger valves and beehive springs, studs etc. bored .40 over, balanced, HEI and it moves really well.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 11-19-2014, 12:21 PM   #35
TJ's Chevy
TJ's Chevy's Avatar
Here's my 292....little bigger then a 250. All stock except for an HEI, clifford intake and headers, and a 600 cfm edelbrock performer carb....The internals are 48 years old...and it has 150,000 on it...compression around 110 in all cylinders, but runs strong and really gets up an goes. I currently have another 292 I'm hotrodding which will easily compete with 350's when its done.
Old 11-19-2014, 02:16 PM   #36
RoughKuntry
Is the 292 I6 motor mounts off on one side? The I6 I have was perfect line up with the v8
RoughKuntry
Old 11-19-2014, 07:21 PM   #37
Oregoon
Roadside Rebuilder
Oregoon's Avatar
Personally, I'd stay away from the integrated head.
I used to warehouse, sell, and deliver remanufactured engines for an automotive engine rebuilder, and we had a strict policy of not selling integrated heads. The conventional wisdom was that they were prone to cracking due to heat transfer. We'd simply counsel owners to buy a non-integrated model and find the necessary manifolds, etc on their own. As I recall, we did a few integral heads, though the warranty was extremely limited.
Whether or not they're actually as lousy as I've heard, I have no idea. I've never owned an integral. However, I trust my old employer's knowledge implicitly. They did excellent work but sold the business and retired in 2003, or I'd still work there.
As for inline sixes, I've owned and loved a 250 and a 292, two Ford 240s and a 300, an AMC 258, and a Landcruiser 2F. I've worked on and driven slant sixes, a GMC 302, a Ford 262, Chevy 235, International 241 and 501, Hudson 308 (what a sweet sound!), Willys Hurricane 6, a Waukesha 817, as well as a bunch of others that escape my memory.
Something about the six cyclinder just gets in your blood. Such joys to work on and a blast to drive.
Oregoon is offline   Reply With Quote
Old 11-25-2014, 04:31 AM   #38
OldGMJon
OldGMJon's Avatar
Question Re: Anyone Using 4.1 Straight Six Engine?
Since we're talking about sixers...I have a 230 Inline 6 in my 65' GMC but have a 351E V6 big block I could switch from my 66' GMC 2503 parts truck. I was thinking it might be a better choice. The 65' is just a driver/beater and an eventual parts truck but everything works and I like to drive it. I thought with the V6 I could carry something or pull a trailer. The 230 is starting to leak oil, probably the rear main seal but the V6 smokes a little when I shift gears. What would you do?
OldGMJon is offline   Reply With Quote
Old 11-25-2014, 12:17 PM   #39
TJ's Chevy
TJ's Chevy's Avatar
The 230 would be cheaper to rebuild, But the 351 would have waaay more power. Personally I'd do the 351 for the brute low end torque.
Old 11-25-2014, 04:33 PM   #40
OldGMJon
OldGMJon's Avatar
Talking Re: Anyone Using 4.1 Straight Six Engine?
That is what I was thinking too...thanks for the response...
I got too many projects and only a beater that drives
Old 12-01-2014, 05:56 AM   #41
RoughKuntry
seems to be the electric choke is cracked on the varajet, not to mention I also I'm having a problem with one of the back vacuum valves it doesn't want to shut off the the chamber to the and the valve itself it's causing a whistling sound I think it's time for a new carb what about you
RoughKuntry
Old 12-01-2014, 06:01 AM   #42
RoughKuntry
I've also start this inline 6 into a 3 quarter ton 4 wheel drive call me crazy but I've just rebuilt the cab bed and full front clip the only slight modifications I've had to do this truck is power steering pump is from the 73 3 quarter ton and it's hooked up to a half ton power steering pump that sits on the front of the inline 6 so you could say this is jack of all trades. 73/80/89 Chevy and GMC
RoughKuntry
