#26 |
knuckle buster..
![]() Join Date: Oct 2007
Re: Master Battery Disconnect Switch Placement
hmm never saw the "extra power lead" batt cut off switches... also interested where you can find these...
_______________________________________________________________________________ Eric THIS SITE ROCKS!!! ![]() Check out my suburban on 20's with fresh paint! Click here to support the site Check out the Member Photo Gallery here StreetCruizin FAQ thread Site vendors list (scroll down to vendors in red) ![]() ![]() |
#27 |
Here are a couple
http://www.watsons-streetworks.com/battery.html |
#28 | |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
You don't need an extra terminal just run your wire from the battery cable side of the switch to whatever you want to be powered all the time.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#29 |
1970 Daily Driver
That is what I did on mine. The ones with an extra terminal cost more and unless you have a crap load of things you run strait off of your battery there is no need for it. Save the money and run your alarm and stereo memory off the battery side of the switch as VetteVet said.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
#30 | |
Eat My Rust
#31 |
Heres a question.
Can i just hook the switch directly to the starter's "S" post so i can manage its function and also keep the radios and everything else intact?? |
#32 |
![]() Join Date: Feb 2001
Well....after reading this thread and doing a lot of Googling I ended up purchasing the Watson's PressTech TM Touch Pad Battery Disconnect. This way I can install the "Touch Pad" inside the cab someplace out of sight. This has been a great thread.Thanks guys for all the input.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 01-16-2009 at 02:54 AM. |
#33 | |
![]() Join Date: May 2006
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#34 |
lts70 ...I gave you a reputation. Great thread and very useful.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#35 |
I know this thread is old, but this is a good idea. Thanks
#36 |
![]() Join Date: Dec 2015
I was wondering about the same thing, thanks for resurrecting 88Stanger.
1968 Long Bed 2016 Honda Civic Coupe EX-T ticket magnet |
#37 |
so i was talking to a good friend of mine and he suggested that maybe we also install a battery tender permanently, just under the battery, 5amp one that is water proof. This would be for long winter storage and such, i thought it sounds like a good idea.
#38 |
Old member
I have a battery shut off on my 71 but it's on the negative cable. I have been seeing my tach and lights deeming at night since I installed it. I have been thinking about a upgraded alternator and a capacitor for the amp I run.
I went by my local Stereo Store yesterday and he said remove the cut off and see what happens. This is my goal for the day. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
