Old 01-22-2009, 05:15 AM   #26
64GMCHorsepower
Justified!
Re: came across a motor
Also, if you stay with the computer, I would reccomend having a custom chip burned getting rid of VATS, and all the emission stuff, unless you want to keep it for some reason......also will need to look at what you need to do for the speedo....electric or cable type....
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 01-27-2009, 12:44 AM   #27
zane2513
zane2513's Avatar
Where can you get a chip burned so I can get rid of the emission stuff
just rockin out in Oklahoma
oh and rebuilding my 66' stepside
66' Chevy LWB
in my own way!
zane2513 is offline   Reply With Quote
Old 01-27-2009, 01:52 AM   #28
Captainfab
60-66 Nut
I've not personally used these guys, but I've heard good reports about them
http://www.fastchip.com/
These guys we have used, and had some issues. They've been around for a long time and a lot of people use them though.
http://www.tpis.com/
There are many other places to get a chip burned too......might try googling
Old 01-27-2009, 06:20 PM   #29
64GMCHorsepower
Justified!
I bought my harness and my computer from the guy on Chevythunder.com. He just asked for info about your engine/tranny combo other stuff. It has all worked out good for me. He sells them on ebay under the username chevy_tpi.
Chad
Chad
Old 01-28-2009, 12:57 AM   #30
zane2513
zane2513's Avatar
64GMCHorsepower does this look like the right crossmember for the transmission? I found it on ebay for $65 http://cgi.ebay.com/ebaymotors/63-72...3A1|240%3A1318
Thanks for the link Chevythunder.com I spent the entire night reading this guys website. I think he in OKC.
Same thanks goes out to Captainfab for the links also. I check them both out and found http://www.fastchip.com/ was in Tulsa about 10 miles from me.
Zane
66' Chevy LWB
in my own way!
Old 01-28-2009, 09:14 AM   #31
64GMCHorsepower
Justified!
yep, that looks like what I used....
Chad
Old 02-07-2009, 11:43 AM   #32
zane2513
zane2513's Avatar
Just some questions and a update.
Got the crossmember for the transmission, I found it on ebay for $65. Found a tail housing for the 700r4 that will mount to the crossmember, another ebay find. Hopefully we can start putting in the motor soon but first I have a question. I want to put in new brake lines before I put the motor and transmission in, I have new disc brakes on the front and have rebuilt the drum brakes and plan on converting them to disc at a later date. My question is what size line do I use? Also what size of fuel line should I use? I was thinking of bending them myself but not sure if I should. Please help I am kinda at a stand still.
Zane
66' Chevy LWB
in my own way!
Old 02-07-2009, 02:05 PM   #33
64GMCHorsepower
Justified!
I used 1/8 brake line..I bought a roll of line and fittings from INLINETUBE.com.....My local Advance auto had pre-made sticks of brake line with the fittings also.....
I used Earls fittings for my fuel line, and a 3/8 High-pressure fuel hose instead of bent metal lines.....either way works just fine......
I bought the fuel line stuff at my local racing supply store....
I know Summit and Jegs carry's the stuff.....
Chad
Chad
