Old 04-10-2009, 03:44 AM   #26
MickMc
MickMc's Avatar
Re: Different brake assist systems?
Yes the synthetic is touted as better.
Most people use the synthetic when they are having problems.
Also the synthetic is supposed to eliminate the micro bubbles in the system.
Microbubbles seem to be the root cause for many problems.
Mick
MickMc is offline   Reply With Quote
Old 04-10-2009, 09:04 AM   #27
westofb
I really hate wet sanding!
westofb's Avatar
Go with the hydra boost. Like mentioned before it was designed for vehicles with low amounts of vac like diesels. With this system you could go crazy with cam, radical cams produce inadequate vac to operate vac power boosters. Actually just do whatever you like, unless you get a vac booster from 67-72 you are going to have to do some fab work. However, it should be easy to scope out an original vac booster in salvage yard for you truck. I helped my buddy put one from a 72 in his 69 was an easy bolt in install. If you go this route, you will need to get the booster, mounting bracket, and linkage (complete to the pedal) from the donor vehicle. His truck was non power drum set up, used existing mastercylinder and lines, just bolted on power stuff with no issues....well we did have to adjust the brake light switch which is a real pita to get the brake lights to operate properly. Good luck with whatever system you go with!
westofb is offline   Reply With Quote
Old 04-10-2009, 02:24 PM   #28
DjS71
FLaming River also makes an electric kit, I have no experience with it, nor have i read any reviews. Seems interesting though
-->Here<--
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
Old 04-10-2009, 03:57 PM   #29
DjS71
Disregard that last link, i read power steering power steering!
this is a brake thread.....
/facepalm
thank god its friday.
~Dan
Old 04-10-2009, 04:50 PM   #30
Old Goat
Old Goat's Avatar
Hydraboost thread, which uses the power steering pump.
Old Goat is offline   Reply With Quote
