Old 01-23-2009, 12:23 AM   #26
Texasdeere
Texasdeere's Avatar
Re: 59 Apache 3200 Fleetside
I was a little aggravated when I couldn't get the old sending unit out of the original fuel tank. (screws seized) But after removing the tank I can tell there is about a pound or two of rust sliding around in the bottom. So the new fuel tank was a good idea after all!
Texasdeere is offline   Reply With Quote
Old 01-23-2009, 10:50 AM   #27
Texasdeere
Texasdeere's Avatar
Hey, Is it possible that these trucks were sold without hubcaps sometimes?
Maybe all four were swapped out a long time ago.
This is what the wheels look like that I have on the truck now.
Old 01-23-2009, 01:17 PM   #28
entourageguy
Yellow truck club
entourageguy's Avatar
Look like a bit later rim. Those will take a dog dish type cap.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 01-23-2009, 04:53 PM   #29
Norselander
Clunker Farm, Proprietor
Norselander's Avatar
That's a 60s GM wheel. A factory half-ton wheel will have three clips (maybe four clips for the heavy-half 17.5").
Drew
Chief Junk Jockey
Norselander is offline   Reply With Quote
Old 01-23-2009, 05:05 PM   #30
justcuz
justcuz's Avatar
Folks probably swapped out to those wheels either after the clips broke or to get away from split rims. As I recall my 63 4x4 had split rims on it.
justcuz is offline   Reply With Quote
Old 01-23-2009, 05:52 PM   #31
Texasdeere
Texasdeere's Avatar
That is what I figured. I will put the correct ones on it eventually
Old 01-28-2009, 07:45 PM   #32
Texasdeere
Texasdeere's Avatar
I have been getting some work done to the truck. I got the wheels blasted, primed and painted for $90.00. The new tires make the ride so much quieter. Here are some updated pictures.
Old 01-28-2009, 07:49 PM   #33
Texasdeere
Texasdeere's Avatar
These pictures show the new fuel tank and what the interior looks like. I haven't put the door panel back on yet.
Old 01-28-2009, 07:50 PM   #34
justcuz
justcuz's Avatar
Looks nice! Thanks for posting the pics.
Old 01-28-2009, 07:52 PM   #35
Texasdeere
Texasdeere's Avatar
Here is the engine bay and a bed shot.
Old 01-28-2009, 09:20 PM   #36
Texasdeere
Texasdeere's Avatar
Thanks, and you are welcome.
I have been having a blast working on it. Next will be a carb overhaul, valve cover and side cover gaskets. Replacing the headlight adjusters and the speedometer head.
I might go and get it inspected first.
Old 01-28-2009, 09:39 PM   #37
justcuz
justcuz's Avatar
Wow that is funny to see the old road draft tube on the side of the engine and a breather cap. California years ago made people install closed crancase systems on old trucks and you rarely see this anymore.
It is also neat to look through the engine compartment and see the ground!
Gotta love those old trucks, simple and easy to repair.
Old 01-28-2009, 10:24 PM   #38
1956cameo
1956cameo's Avatar
Awesome thread! Can't believe this is my first time to see this. You would be very hard pressed to find many other 50 year old work trucks that are that straight and rust free. Trust me that the money you paid is well worth it. Sometimes it seems like a bargain to get a more beat up truck cheaper, but it isn't. The only projects I will buy now are ones like your truck. They make a restoration go so much faster and cheaper!!
Santa Fe is just around the corner from me. When I get my Cameo roadworthy I will have to make the trip down to see your truck. Just let me know if you need a hand with anything.
1956cameo is offline   Reply With Quote
Old 01-28-2009, 10:48 PM   #39
Texasdeere
Texasdeere's Avatar
I am with you on that one. It was more than I wanted to spend but at least the trip to pick it up was cheap, about $120 for fuel. Plus it looks cool just like it is.
When I picked up my 64 C20 in Kansas a year ago I spent about $1500 on the trip to pick it up. (fuel, motel rooms, and food)
Thanks, That sounds good, I have never seen a Cameo in person before.
Old 01-28-2009, 10:49 PM   #40
dwcsr
Hollister Road Co.
dwcsr's Avatar
I thought it was a bit pricey at first but looking at the pictures I see all the work you don't have to do easily covers the price.
dwcsr is offline   Reply With Quote
Old 01-28-2009, 10:52 PM   #41
Texasdeere
Texasdeere's Avatar
I am pretty sure a breather cap is original. There was one on it that I still have but it seemed to be pretty clogged up so I put a new one on it.
Old 01-28-2009, 11:03 PM   #42
Texasdeere
Texasdeere's Avatar
It will need both cab corners replaced, (hidden by the fleetside) a few small dents fixed and that back fender unrolled and straightened.
The lack of rust, originality, fleetside, and big back window were big sell points for me.
I am not much of a body man, but I may try to pull that fender down myself.
Old 01-28-2009, 11:21 PM   #43
joemacho
joemacho's Avatar
dang realy nice pick m up truck like the rear view mirror but over all nice work getting it all fixed.
joemacho is offline   Reply With Quote
Old 01-29-2009, 12:54 AM   #44
OrrieG
OrrieG's Avatar
Easy to do, secret is to find where it started to crease and relieve the tension at that point while pulling it down. If you just yank on it it will want to spring back and weaken the metal at that point. Use a picking hammer at the crease. If its been there for a while you might have to shrink the metal at the crease.
OrrieG is offline   Reply With Quote
Old 01-29-2009, 12:58 AM   #45
1956cameo
1956cameo's Avatar
Sounds good. Yeah I have only seen about 5 or 6 cameo's in person myself. This was the only one I saw in person that was for sale. Its pretty rough but it is a genuine cameo originally red with white trim, and originally a 265 v/8 truck. Much rougher than your 59. Found it down in Rosharon.
Old 01-29-2009, 06:42 PM   #46
Texasdeere
Texasdeere's Avatar
Never seen one before but here is a Californiaized 235:
Old 01-30-2009, 04:03 PM   #47
justcuz
justcuz's Avatar
Thats what I am used to seeing. Although a variation of it is to use a Ford FE series engine oil filler cap with the hose going to the air cleaner from the top of the oil cap.
Old 02-08-2009, 02:54 PM   #48
Texasdeere
Texasdeere's Avatar
I got the new headlights adjusters installed Saturday. I couldn't find any rivets that would fit, 1/8 too small and 3/16 too big, so I just used the screws that came with the adjusters. I need to tighten up the steering box some next.
The Big News I guess would be that I finally figured out what was painted on the doors. I never could figure out what the top word was. (P or R***mond?) It used to say "Rosamond" as in Rosamond CA. "Rosamond Trailer Sales" The front bumper has an Edwards AFB sticker and a Air Force registration sticker on it still. Rosamond is pretty close to Edwards Air Force Base. The guy I bought the truck from did say it was originally from California before the long stay in a Oklahoma barn. He said the previous owner sanded the words off but you could still make them out some.
http://www.avhub.net/RosamondCa.htm
Old 02-08-2009, 04:02 PM   #49
Daniel U
Daniel U's Avatar
To me that's one of the cool things about having an older vehicle.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 02-08-2009, 04:42 PM   #50
OrrieG
OrrieG's Avatar
That is cool, you might dump a message on the Rosamond Craigslist and see if anyone associated with the old company might have a photo of the truck back then. Its amazing what you can dig up on the internet.
