01-11-2009, 06:25 PM | #26 | |
James
Re: Cowl induction hood ?....
Block Casting# 3858174 HP (low)275 (high)350 Main 2
Never crush'em. Restor'em or recycle'em. The payoff is always worth it in the end. http://viewmorepics.myspace.com/inde...lbumId=1709080 http://s258.photobucket.com/albums/h...e_top_view_all |
01-11-2009, 07:51 PM | #27 |
gotcha
CHEVY ONLY |
01-11-2009, 08:07 PM | #28 |
James
Once I pull the motor I'm going to run the numbers myself. The only reason I have the casting number to it is because there was a rebuild tag in with some other receipts in the car. Basically the only info it had on it was casting no#, new bore size, and compression ratio. The PO doesn't know much about cars at all but after talking to him when I got the car I'm pretty sure that is what is in it.
01-11-2009, 09:09 PM | #29 |
Casting # 3858174 is the correct casting # for 1964-1967 327 block but, does not necessarily mean that it would be a #'s correct block for your vehicle. The date code on the block would have to pre-date the build date on your truck a maximum of 90 days. Also I know that on the Autos Chevrolet started stamping the Vin# in front of the Suffix code in 1962. I don't know if that is the case with the trucks or not. Only 1962 and after would a block with the Vin # stamped on it matching the Vin # on the vehicle be considered #'s matching block. This is also true for the transmission. The rear end, water pump, heads, intake, exhaust manifolds and, carburetor all would have to pre-date or be the same date as the block. Prior to 1962 all vehicles with the correct date codes and #'s are considered #'s correct as the Vin# was not stamped on the block or transmission.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD Last edited by 502tripower; 01-11-2009 at 09:10 PM. |
