01-15-2009, 05:14 PM | #26 | |
Eat My Rust
Re: Static Drops!!!
Wierd, the site shows a 6 in drop with the wheels sitting the same as my 3 in drop. My 5 in drop was tucking the rear tires!
5"-3"-stock 15x8 wheels, with 265/75/R15s I believe, maybe their 65s, can't remember off the top of my head. I'll double check this weekend. Quote:
01-15-2009, 05:22 PM | #27 |
Re: Static Drops!!!
yeah,
I thought it was probably normal for a lowered truck too... and it still might do it, but I don't want any rubbing |
01-15-2009, 05:47 PM | #28 |
Eat My Rust
Re: Static Drops!!!
If it is making metal on metal contact of course go and fix that. But if all is clear, it's just the geometry being weird. I'm sure one of our suspension guys on here could give a better fix. Maybe PM Scoti and ask what he thinks.
01-15-2009, 06:31 PM | #29 |
Re: Static Drops!!!
4.5/6 drop. no rubbing issues once i went to a 225/60-15 up front. I have since raised the front up 1" though to make it sit more level.
01-15-2009, 06:48 PM | #30 |
Re: Static Drops!!!
here's my truck with 2.5" drop spindles up front and 4" drop coils in the rear. I'm running 275/60R15 all the way around and I don't have any rubbing issues. This is a good drop cuz I can still haul crap in the back of my truck, motorcycle, engines, etc. I think I'm gonna heat the rear and cut a coil in the front to get a lower stance though...
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
01-15-2009, 09:02 PM | #31 |
accepting donations
Re: Static Drops!!!
Here's mine.
2.5"/4" 15" rally's 275/60
1999 Yamaha roadstar 1600 chop. (in progress.) See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/ "Ya'll can go to hell, I'm going to Texas." David Crockett |
01-15-2009, 09:22 PM | #32 |
Old Skool Club
Re: Static Drops!!!
With coil springs in the rear, you don't need to notch the frame, according to ECE. What you WILL need with a 4 to 6-inch drop in the rear, is an adjustable track bar and the shock mount relocator hardware. The bar is necessary to center the rear axle and the shock hardware restores the geometry of the rear shocks so that they will work properly.
If you're running leaf springs, you already know you'd need to notch the frame for a radical static drop.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
01-15-2009, 10:45 PM | #33 |
Re: Static Drops!!!
Nick Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg 04 Silverado Daily Driver 68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665 "I'll beat you to the gas station!!" |
01-23-2009, 09:21 AM | #34 |
Old member
Re: Static Drops!!!
Mine has a set of 2" coils in the front and 3" in the back. I bought a set of air bag helpers for the back since it would bottom out on a bad pot hole and since I installed them it's not happened since.
01-23-2009, 11:52 AM | #35 |
Re: Static Drops!!!
I'm not exactly sure what mine is because I've had the components for so long. It's at least a 4/6 + a little.
Stepped control arms with springs in front & springs with about an inch worth of block in the rear w/ shock relocators and long track bar. 18" rims with 50 series rubber up front and 55 series out back.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
01-23-2009, 12:51 PM | #36 |
Re: Static Drops!!!
1970 C-10 6/6 lowering springs
01-23-2009, 08:38 PM | #37 |
Re: Static Drops!!!
JDracing57, Looks great. Nice and clean.
01-23-2009, 09:07 PM | #38 |
On the road
Re: Static Drops!!!
Here's an older pic of mine and a more recent one. Mine has a ECE 4/6 drop. I've had it since 02 and never a problem, no rubbing or C-notch's.
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
01-23-2009, 09:32 PM | #39 |
Nothing to see here.....
Re: Static Drops!!!
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
01-24-2009, 12:13 AM | #40 |
Re: Static Drops!!!
Here's mine... still working on it. Front is 1 inch drop spring, 2 1/2 spindle. Rear is 5inch springs. Wheels and tires are, front 17x10 with 265/60 rear 17x10 with 285/60.
01-24-2009, 01:57 AM | #41 |
I have a radical idea!
Re: Static Drops!!!
I have a ghetto blue-tip firewrench approximately 3/4.5" drop on my beater truck. I'm running 15 X 6" and 15 X 8" steelies with 215/70R15 fronts and 275/60R15 rears. I just heated them up and it still rides are drives great, although it isn't the ideal way to do it. Buying springs would be the much better route, but it was great zero dollar mod on my old beater.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
05-30-2009, 07:04 PM | #42 |
Re: Static Drops!!!
hey where did you get the axle flip kit i am looking for one cause i have a 1972 chevy c10 3/4 ton and all i have found is axle flip kit for a 73 c10 could that work on mine????
05-31-2009, 06:28 AM | #43 |
Re: Static Drops!!!
few of the latest pics, a lot better then the previous...
05-31-2009, 09:03 AM | #44 |
Jason
Re: Static Drops!!!
Here is mine 2.5" spindle, 3" drop spring, and 1.5" drop block.
05-31-2009, 09:12 AM | #45 |
Re: Static Drops!!!
Here's my HT static drop (heating torch)......
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-31-2009, 10:08 AM | #46 |
Re: Static Drops!!!
show off! lol
R.I.P. Killer 71 10/26/07 |
05-31-2009, 03:03 PM | #47 |
Mean Buzzin' Half Dozen
Re: Static Drops!!!
Can you measure how tall your tires are? I'm running basically the same drop and I like the height of those tires. Only difference is I'll be running 18's instead of 17's.
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
MY TRUCK (Now for sale) 1967 C10 SWB Dylan |
05-31-2009, 03:38 PM | #48 |
Re: Static Drops!!!
Doug, What is that paint color called? I like that and the white top.
God is good all the time! Even when the truck wont start the first time. |
05-31-2009, 04:56 PM | #49 |
Re: Static Drops!!!
Jarridlem,
it's original paint, 504 Medium Olive per the SPID. by the looks of your avatar, you've got a "green machine" too!
01-19-2015, 06:47 PM | #50 |
Re: Static Drops!!!
what are the size of your tires?
