#26 |
Re: Oil Filter?
I too have, for the most part, always used Fram & never have had any problems.
Curious....If Fram is all that bad and getting that kind of publicity, (whether true or not), then why hasn't Fram come out & say anything about this, or correct the problems? Also, I never heard of "WIX" filters Maybe it's not in my area.
1997 GMC Sierra Ext 1965 Mustang |
#27 |
![]() Join Date: Aug 2005
Re: Oil Filter?
#28 |
BOHICA
Re: Oil Filter?
I have always used fram and valvoline, and never had any problems. I've torn down motors that have always had purolator and mobil, and another that uses k&n and Qstate. both of those engines had a large amount of sludge in them. Whether the oil and filter did it or the drivers habits, I don't know. I think this is like the old Ford vs Chevy argument. You can always find people on both sides of any argument. Bottom line is all oils lubricate, and all filters well...filter. Do some research and use what you feel is best, or use what your dad always used like I do. sorry so wordy, just my.02. happy hunting!
#29 |
Re: Oil Filter?
[QUOTE=BluTrukker;3085673] I think this is like the old Ford vs Chevy argument.QUOTE]
Is it though? I mean, you can look and find articles written and pictures of all these filter's guts. Chevy v. Ford... consumer reports will actually tell you which models are holding up or costing more... just like people have openned up these filters and found cheap materials and poor craftsmanship... the information is out there. actually... some of the information is in this thread...
RN U OVR |
#30 |
Re: Oil Filter?
good info. i guess i have never really thought about it that much. i have always grabbed fram if it was available. i might be passing it up now for what i previously thought was an inferior filter.
#31 |
![]() Join Date: May 2004
Re: Oil Filter?
I don't use FRAM anymore because of what I have read from everybody. I now use the WalMart brand, anybody know who makes those??
#32 |
Moderator
![]() Join Date: May 2007
Re: Oil Filter?
#33 |
Re: Oil Filter?
WIX or NAPA Gold (same thing)
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#34 |
Old member
Re: Oil Filter?
I just bought a Mobil 1 filter yesterday. For the first time my 71 hasn't gotten a A/C Delco on it. I have ran AC Delco's on everything I own. They are harder and harder to find around here. I alway's used the bigger PF 35 filter which now is a PF 1218 I think. It's half the size of the older 35 and I just felt for the money the bigger Mobile 1 was a better choice. I hope it was, time will tell.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#35 |
WORTHLESS CRUISERS
Re: Oil Filter?
Fram makes a filter for racing engines. Thats what several of us around here run. Also Advance Auto Parts filters are made by fram.
Scott Hammond Lancaster, SC 1969 Chevy ![]() If you don't live for something, then you'll die for nothing. www.xclusive-images.com ![]() |
#36 |
![]() Join Date: Jul 2003
The regular consumer grade Frams are crap, bar none.
The HP series are fine, but they do not have the fine particle filtration for constant street use. They are built for high pressure/high flow. I still recommend WIX or Baldwins.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
#37 |
Re: Oil Filter?
I did a Google search and found no large recall on Fram filters.
#38 |
Re: Oil Filter?
I use K&N on my car, and we use Wix filters on all of our other vehicles.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
#39 |
Re: Oil Filter?
i have fram ph5 and have no problems..
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
#40 |
Re: Oil Filter?
i have a fram HP on my 350 it has the relief valve plugged, i will look into the K&N, Wix, i have a 2002 dodge w/Cummins when i went to change oil the first time i talked to Cummins they said the Mopar filter was made by Wix, they said Fram was not approved, i have used the Fleetguard from Cummins they have 3 grades of filter for the Cummins 5.9
#41 | |
Sierra Grande Club
Re: Oil Filter?
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
#42 | |
Sierra Grande Club
Re: Oil Filter?
http://www.broadbandreports.com/foru...-FILTER-REVIEW
#43 |
Sisyphus was my mentor!
![]() Join Date: Sep 2002
Re: Oil Filter?
WIX is excellent. Read the reviews. There are other good ones out there that are good too, but I certainly wont put a fram or similar cheapie filter on anything I drive. I changed the oil on the three cars in my driveway last weekend & they all recieved a WIX. Here in Canada, it's tougher to get a quality oil filter. There's fewer independent parts places up here & you tend to end up at Canadian Tire where all you get is a house-brand Fram...
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
#44 |
Re: Oil Filter?
#45 | ||
Re: Oil Filter?
#46 | |
Re: Oil Filter?
And yet they seem to be good enough to protect multi-million dollar vintage Ferrari's....hmmmm, curious. ![]() ![]() |
#47 | |
Re: Oil Filter?
In actuality there are very few differences in the actual designs and materials in oil filters. The most important thing is that you change your oil and filter regularly and frequently to remove contaminants from the engine. There are thousands upon thousands of Fram oil filters sold in outlets like Wal-Mart and Advanced Auto and if they were as bad as some people say; A. I don't think these retailer would carry them and B. There would be engine failures and lawsuits left and right but that just is not the case. |
#48 |
Between Trucks...
Re: Oil Filter?
Beat it to fit, Paint it to match... ![]() |
#49 |
Re: Oil Filter?
I have pretty much always used Frams, I've been driving for 20 years. I have never had a complaint. A few times I have had a filter that was hard to get off, but I got that on the few times I used other brands too.
These days, I use the Frams with the grip substance on them, hand tighten with one hand, then use 2 hands to tighten some more and leave it at that. I usually have no problems getting them off. I aways put some new oil on the seal before I put them on. Anyway, no complaints with Fram from me. |
#50 |
Good question. That's because there are no big problems. It's just the Internet rumor-mill run amok.
