07-23-2009, 09:57 AM | #26 |
Re: bbc headers
Glad to see you finally got them in.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
07-23-2009, 09:16 PM | #27 |
Re: bbc headers
Thanks, i take it that you ended up keeping your truck? You also have a nice project.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
07-23-2009, 09:18 PM | #28 |
Re: bbc headers
thanks drag truck, especially for your help on picking a crossmember.. I ended up finding one almost just like yours thru trans dapt. Summit racing has them.
07-29-2009, 01:03 PM | #29 |
Re: bbc headers
Glad you finally got them in. I went with the same headers on my 59. I had to notch the outer shell on the drivers side motor mount (didn't change structurally), and grind on the a-fame a bit just for added clearance. Mine is a 427 CBB.
1961 GMC Suburban Custom 1969 Short wide project http://67-72chevytrucks.com/vboard/s...d.php?t=535479 (SOLD) 1959 Apache fleetside (frame off in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=348746 1960 Apache short/narrow shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=350780 (SOLD) 1951 Plymouth leadsled project 2005 Corvette conv. Procharged 1969 Corvette stingray 2006 Cadillac XLR-V 1950 Oldsmobile 98 custom project |
08-10-2009, 04:53 PM | #30 |
Re: bbc headers
new pictures of completed exhaust
09-07-2009, 08:56 AM | #31 |
Re: bbc headers
69trk - Thanks for the pictures. What size of pipe did you use to reinforce your cross member thru holes? Also, what size of exhaust are you running through your cross member? Thanks.
09-09-2009, 09:40 PM | #32 |
Re: bbc headers
I didn't weld anything in the holes. The pipe is 3" After the dumps.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 Last edited by 69trk; 09-09-2009 at 09:41 PM. |
09-16-2009, 12:07 AM | #33 |
Re: bbc headers
You might consider reinforcing your crossmember.
http://67-72chevytrucks.com/vboard/s....php?p=3250018 http://67-72chevytrucks.com/vboard/s...d.php?t=266474 http://67-72chevytrucks.com/vboard/s...d.php?t=318690 Last edited by gene_ensor; 09-16-2009 at 12:09 AM. |
09-16-2009, 06:36 AM | #34 |
Re: bbc headers
i'm going to buy the ece crossmember. I was going to reinforce mine, until i seen a guy here at the track running low 10's for over 8 years and he never reinforced his. I do believe it's good insurance tho...I'll have my welding buddy come over and weld some flatstock on both sides this winter...
09-22-2009, 06:28 PM | #35 |
Re: bbc headers
Can you take a picture from the drivers side and show us where #7 primary comes down? I cannot find a header that will work with my big block zbar and bell crank. It keeps wanting to hit primary #7. I need a header that goes straight down there.
09-22-2009, 10:03 PM | #36 |
Re: bbc headers
will this work? I don't have a very good picture of the number 7 primary. if not i'll get some other pictures when i get my truck back from the body shop.
