Old 01-20-2009, 09:27 PM   #26
shilo
shilo's Avatar
Re: Some Q's
The Blazers are 3.08 10 bolts with a gov loc rear
71 swb 4x4, 37" Iroks, t400/205 496
77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20
shilo is offline   Reply With Quote
Old 01-20-2009, 09:32 PM   #27
1-tonmudder
Modern day Fred Sanford
1-tonmudder's Avatar
Re: Some Q's
The Blazers are 10 bolts with 3:08's.Contrary to popular belief they are the same axles that the civilian Blazer had.All with the 14 bolt rear had a detroit in em and some of the 60 fronts had a trak-lok in them.Parts are the same as the civilian versions.Second to maybe the 9 inch the Dana 60 is the most popular axle around.
1-tonmudder is offline   Reply With Quote
Old 01-20-2009, 10:14 PM   #28
jkade
jkade's Avatar
Re: Some Q's
Humm, my brother has a 1008 with no lift and is running 36's with just cut fenders. Now they do rub a little but not like you would think. I am certain with a 4" lift his tires wouldn't rub at all. That being said I am going to try 38.5's with a 5" lift on my 1009. 4" springs with a zero rate block = 5"
I think you should get a lift and some tires and drive the heck out of that thing.
jkade is offline   Reply With Quote
Old 01-21-2009, 06:27 AM   #29
Re: Some Q's
8" rims get you by where 10" won`t with certain lift/tire combos.Also flexier springs vs stiffer ones.My`91 3/4t Suburban w/4" EZ-Rides catches it`s 10" D-hole mounted 12.50/35 MTRs.The`84 3/4t truck w/4" Superlifts (in the`80s) was good about not catching the 9.75" trailer wheel mounted A/Ts.The wheels have more backspace than the ones made for trucks.
Old 01-21-2009, 06:52 PM   #30
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: Some Q's
Are those 15" or 16"? What brand? How do I shop for off road tires? What is the size? I cant find any sites that have tires in the inch width/tire height/Rim size.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-21-2009, 07:09 PM   #31
74 C-30
Dually Pride
74 C-30's Avatar
Re: Some Q's
4wheelparts.com has some variety on tires
and those wheel like like 17s
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
Old 01-21-2009, 08:09 PM   #32
thirdstreettito
Resident of Here
Re: Some Q's
Also, what are some cheap(in price)offroad tires? I want Mud Grapplers but $225+ per tire is a bit much. I want 31-33" for 16" wheels.
~Bradley~
Miss having a truck
Old 01-21-2009, 08:55 PM   #33
Re: Some Q's
The Suburban has 16s.The wheels are from 4WPH and so were the tires which are Goodyear MTRs,not cheap.The wheels aren`t to pricey.They are cheaper than round holes and more than wagon wheels.You can catch ProComps (4WPW`s house brand) on a buy 3 get 4 sale.
The tires that come on the M1008s are 235/85x16s and they`re right about 31".BFG M/Ts in 255/85s are about 33" and mount on stock wheels.
Old 01-21-2009, 10:24 PM   #34
Dooley
Dooley's Avatar
Re: Some Q's
My M1008 with 255/85-16 BFG's on the stock wheel. They are 33.3" tall and fit with room to spare.
Dooley is offline   Reply With Quote
Old 01-21-2009, 11:02 PM   #35
Re: Some Q's
^And,cut through mud like it`s not there,right?
Old 01-21-2009, 11:09 PM   #36
thirdstreettito
Resident of Here
Re: Some Q's
Thanks. I read somewhere that the M1008's come with 16.5's, is that right?
~Bradley~
Miss having a truck
Old 01-21-2009, 11:14 PM   #37
1-tonmudder
Re: Some Q's
Probably/maybe.I have had three of em and they all had 16's.There was a time when 16.5's were hard to find and expensive so it would stand to reason that could have been changed.
Old 01-21-2009, 11:22 PM   #38
Dooley
Dooley's Avatar
Re: Some Q's
NO, the CUCV's did not. The early Hummers had 16.5's.
Old 01-22-2009, 06:37 AM   #39
Re: Some Q's
Around 1980 GM stopped using 16.5s.I had a`78 Dooley that came with and that was pretty unusual by then.16.5s were short/wide profile that came along in the "Wide Oval" era.I believe`68 was the first year and maybe not on GMs until`71.At least that`s been my experience.
Old 01-22-2009, 08:08 PM   #40
jkade
jkade's Avatar
Re: Some Q's
as already stated m1008's came with 16's
Old 01-22-2009, 08:12 PM   #41
jkade
jkade's Avatar
Re: Some Q's
I can sell you some 37x12.50x16.5's all day long for $350 a set. They are hummer pull offs.
Old 01-23-2009, 06:43 AM   #42
Re: Some Q's
^That`s about what you`d pay for one 37" tire normally^
