01-25-2009, 06:12 PM | #26 |
Re: A little 4link help (Inner bars)
In relation to the axle.
If you can find it cheaper, I can fix it! |
01-25-2009, 06:30 PM | #27 |
Bodydropped71
Yea thats what i thought. So the was i have it wouldn't be the best idea. How much would you charge me for a wish bone?
01-25-2009, 09:30 PM | #28 |
Send me a PM and we can talk about it.
It sounds like you are on a budget? If so, you can probably turn your existing upper link bars into a wishbone with a little work.
01-27-2009, 06:04 PM | #29 |
Bodydropped71
Ok, after alot of thinking i decided to go with a wish bone. I would like to just make my own, but im not sure i can do that correctly with the link bars i have. My bushing ends on the bars are welded strait on and all the wishbones I see have them at the correct angle. Will it work the way i have it? Or will i have to try to cut the ends off and weld them on the correct way. Also is it possible to use a bushing or do I need a super pivot? Also is should it be the same angles? (35*-45*)
01-27-2009, 09:16 PM | #30 |
I prefer the bushings to be parallel to each other. It will work the other way, but it will bind a little through travel, and wear your bushings out a little bit faster than it should. It takes a long time to wear poly out though unless it is binding really bad.
The amount of triangulation doesn't matter so much on a wishbone, but the wider you can keep the bushings, the better control it will have. I prefer to use a pivot joint, or rod end on the single side of a wishbone. I feel it's the only way to build one without it binding. Here is one I built this morning.
01-28-2009, 12:49 AM | #31 |
Happy to be here
Nice work. You sure do a lot of Toyota's. I didn't think they were that popular any more.
01-28-2009, 01:12 AM | #32 |
Ya I seem to do more import trucks than American. But cars seem to be the opposite. Never worked on an import car.
01-28-2009, 10:25 AM | #33 |
Bodydropped71
Thanks a lot! I cant wait for the weekend so i can get working on it.
02-04-2009, 09:13 AM | #34 |
One day...
Any updates man?
02-04-2009, 10:15 AM | #35 | |
Bodydropped71
Yea i actually have a problem. I tried to just PM Twisted Minis but i might get a quicker response here.
02-04-2009, 11:29 AM | #36 |
your bushing need to be inline with each other
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
02-04-2009, 12:42 PM | #37 |
Too much difference in the angle of the bushings. If they are not parallel they will always bind. A small angle difference and they will still move, too much, and the angle is too severe for them.
