01-18-2013, 01:23 PM | #26 |
Re: Pristine engine bay in '66 Chevy C10 with 327 & factory A/C
I love these threads about the original specs of these trucks.
I have a 1965 GMC shortwide, made in the Fremont plant. It has a 230 / 3spd in it. I am planning on rebuilding the 230 and installing a 700R4 behind it. The information about the colour for the 1965 230 truck motor that I have found, says Blue. Can someone tell me the code / name / shade of blue that has been used. Thanks Ken |
01-18-2013, 01:37 PM | #27 |
Wow, what a huge amount of info added! Talk about kicking up a hornets nest, this thread exploded! I had no idea truck motors were different colors, mine was touched up orange. I kind of like the blue (being a pontiac guy and all) so i'll likely go that route.
Thanks for the info everyone, and wow, NOS PAINT!! |
01-18-2013, 01:49 PM | #28 |
Thread about '66 Suburban 327 blue engine color.
http://67-72chevytrucks.com/vboard/s...d.php?t=525379 I found this set of valve covers on eBay that appear to be original paint. Posted via Mobile Device
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
01-18-2013, 01:59 PM | #29 |
NOS Alpine Green engine paint still in the can!! How cool is that?
This NOS paint that 60-66 has could be the "Rosetta Stone" that answers all of the Alpine Green shade questions we've asking for years. If John is able to get a test panel and then have it analyzed and deciphered, this could be huge. There really has never been any solid information anywhere on that paint mix. We've all kind of "winged it" over the years.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
01-18-2013, 03:07 PM | #30 |
Moderator
The first photo looks just like the 327 in my 65 Impala. It's like someone restored that engine to look like a car, not a truck.
Since we're talking about engines, is there a source for the valve cover "High Torque" decals? |
01-18-2013, 03:15 PM | #31 |
01-18-2013, 04:44 PM | #32 |
Made this in MS Paint to better see the difference between the wet paint and the dried paint around the edge. Looks pretty close to the Alpine we've been using, just darker.
01-18-2013, 10:21 PM | #33 |
Hate to spoil the "Alpine Green" party, but this is not the correct shade GM used on 292's and 327's in pre '67 pickups. There were various blues, grays and greens GM used in the 40's 50's and 60's, but nobody sells the correct exact shade for 63-66 230's 250's 283's and 327's. used on 63-66 pickups. Another example of how difficult it is to pull off a 100% correct factory restoration.
01-18-2013, 10:25 PM | #34 | |
01-18-2013, 11:13 PM | #35 | |
01-19-2013, 12:25 AM | #36 |
the color also varied from supplier to supplier of paint to gm and lot numbers . i have various 327s that the motors was slightly varied . these colors samples i found were located behind the pulley on the damper. i think that many shades existed . i think it is very hard to know what is right or wrong . i had the same questions when i did mine. so i think if you pick a color that is close you are probably correct .
01-19-2013, 01:23 AM | #37 |
Where do you get the color Yelmer used?
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
01-19-2013, 11:51 AM | #38 |
A lot can happen to a finish of a 45 to 50 year old engine. Years of chemical degreasers can bleach out a color, besides wear and tear hot and cold. Danbury mint does a lot of high end toys and researches there subjects very carefully before pulling the trigger. Here a 292 when brand new.
01-19-2013, 11:58 AM | #39 |
Danbury Mints engine compartment for a '66
01-19-2013, 12:51 PM | #40 |
Been watching this thread and there has been a lot of different colors used between 60-66. Does anyone have a chart detailing what colors were used on what years and engines? I read somewhere that V8's were grey and 6's were blue but I see examples that don't support that. What is the official list? I painted my engine orange because I grw up thinking Chevy was orange, Pontiac was blue, Ford was a different blue. I would like to paint mine the correct color even though it never came factory with a 350.
01-19-2013, 01:15 PM | #41 | |
01-19-2013, 07:05 PM | #42 |
Will the valve covers pictuerd in thread #35 fit a mid 70's 350 out of a blazer?
01-19-2013, 07:52 PM | #43 | ||
By the way, I noticed in that pic you posted of the Danbury Mint truck that they have the oil filler tube painted engine color as well. I was always under the impression that those were installed after the engine was painted and therefore remained black like on Yelmer's truck. Or maybe that's another one of those things that varied between assembly plants. Quote:
Also note that there were a couple different versions of these Chevrolet script valve covers. The 55-59 ones have a staggered bolt pattern and won't fit newer heads. |
01-19-2013, 11:35 PM | #44 |
Good eye, didn't notice that oil tube, was focusing on the engine color. Ok, that is a boo boo, that should be black and the radiator hose should be black too, not gray.
01-20-2013, 01:32 AM | #45 |
the 66 owners manual i have says 327 is grey . be we know that is not true . i do not know if all owners manuals were wrong?
01-20-2013, 12:21 PM | #46 |
01-20-2013, 12:42 PM | #47 | |||
Well, I'm confused. According to the gentleman above, he had one that was grey. |
01-20-2013, 02:02 PM | #48 |
01-20-2013, 05:21 PM | #49 |
member #16
That is right, ANYONE can say anything on the internet!
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
01-20-2013, 08:47 PM | #50 |
In my opinion, I think the Danbury Mint engine color is too "blue". The color needs to have more green in it.
The shade of the valve covers that John (theastronaut) posted are the right shade. Yes, they are old, dirty, and have faded, but they are more "green" than the Danbury color.
