Old 01-24-2009, 07:18 PM   #26
joe231
joe231's Avatar
Re: Trailing Arm ?
even with the arms angled in the stock location you need a panhard or watts link...
also the factory arms have some "flex" designed into them, otherwise you would have little to no articulation, not that there is much anyway....
http://67-72chevytrucks.com/vboard/s...+trailing+arms
CHEVY ONLY
Old 01-24-2009, 11:43 PM   #27
SCOTI
SCOTI's Avatar
Re: Trailing Arm ?
Originally Posted by oldno7 View Post
OK so I was thinking. You could prob run a 10-11 inch tire with the stock setup, but I'm wanting to run a 17 x 11 rim. So I was thinking of running the trailing arms straight back to the rearend. This would allow you to run bigger rubber out back. You would have to do a few things though. Prob a panhard bar of some sort and modify your wheel wells. You would have to make your own brackets for the trailing arms to bolt to. Prob a coil over shock. Sounds like a lot of work but prob easier than a rearclip. So am I of my rocker or what?
No need to relocate the trailing arm mounts to run wider wheels & rubber. In their stock location, you can fit 14" wide wheels w/the correct back spacing. You'll definitely need to widen the wheeltubs & should use an aftermarket Panhard bar (one that attaches to the pass trailing arm from the drivers side).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-30-2009, 09:10 PM   #28
bentfab
bentfab's Avatar
Re: Trailing Arm ?
Here's a few pics of the arms I've been modifying I still have one more thing left (which will add the character to the arm) and also the shock mount once I get them in the chassis. But this will give you an idea of what you can do with just a little clean up and thought.
bentfab is offline   Reply With Quote
Old 01-31-2009, 03:14 AM   #29
quickchevy
quickchevy's Avatar
Re: Trailing Arm ?
I am looking at running a 15 by 10 rim with a 3.5 backspacing.the tire will be mt drag radial 325 50 15.Will it fit under the stock wheel well.
quickchevy is offline   Reply With Quote
Old 01-31-2009, 03:00 PM   #30
SCOTI
SCOTI's Avatar
Re: Trailing Arm ?
It will be just about flush or extend just beyond the outer wheel well lip. So it will fit if you're not lowered. If lowered, more back-space will be required.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
