#26 | |
Re: Front track too wide
I used 6.5" van ralleys & had no issues w/about 6" of front drop. You mentioned this was going to be a road warrior so you wanted the same size tire all around. Would you consider the same height all around? That would get you closer to your goal w/o having to resort to an air suspension (which it sounds like you don't want). A 215-75-15 is less than .500" difference in height & would work well on a 6.5-7" wheel & compliment the rear sizing for good symmetry. A 215-75 spare is easier to conceal & would work @ every corner. Pic below is w/215-75's & 275-60's on 6.5" & 8" wheels respectively. Food for thought . . . ....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-27-2009 at 11:58 PM. |
#27 |
BlahBlahBlah
I didnt know that was your truck...I really like it. Its one of the couple I was going back and forth on when trying to decide my tire size.
#28 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-28-2009 at 02:01 AM. |
