Old 09-11-2013, 06:24 PM   #26
MusicMan70
MusicMan70's Avatar
Re: v6 carb problems
Vintage, I'm pretty sure I went with a #68 from a #73 for my 305A.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 09-11-2013, 07:14 PM   #27
TommyDuncan
The numbers I keep hearing are in the mid 60s. At least if you buy 2 or 3 sets to try in your 305 one of them might work in your 351.
I just put one on mine a couple days ago... haven't messed with it yet and it is MUCH better.
TommyDuncan is offline   Reply With Quote
Old 11-05-2015, 12:07 AM   #28
canonball
canonball's Avatar
Bringing this thread back from the dead! Got the Holley and adapter plate, just want to verify a couple things before I start cranking down bolts. It looks like I need to remove the studs from the intake manifold and bolt the adapter plate to it with the allen bolts that come with the plate, right?
Also, on the 6066gmcguy write up they mention replacing some fuel line fittings in order to hook up fuel to the carb. Was this needed with you guys' swap?
One last question, my truck has a glass fuel filter, although it's not really a filter. I've had a few older vehicles including a '66 C20 and I've never seen one of these. It looks pretty sweet but since it doesn't do much in the way of filtering so I want to switch it out but it should be good to run for a little while in the meantime with the new carb, right?
(Don't know why the photo pops up sideways, sorry about that!)
canonball is offline   Reply With Quote
Old 11-05-2015, 12:43 AM   #29
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I did a 4 barrel swap so I can't help with the 2 barrel, but I will say...ALWAYS put a new fuel filter in. That's Cheap insurance.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-05-2015, 12:54 AM   #30
padresag
this is the link that you need to solve your problems. there is a box at the bottom. click on 500 holley
http://6066gmcguy.com/performance.html
there is also a wealth of knowledge in the forum there on these engines and there has been a lot discussion on carbs(in the archives)
ron
the site changed hands a couple of years ago and a lot of the old links to the site don't work any more, but all of the info is available
padresag is offline   Reply With Quote
Old 11-05-2015, 01:48 AM   #31
canonball
canonball's Avatar
Yeah been checking out that page, answered a bunch of questions but still running into to some issues. I've got a carb thread already going so I'll continue there I guess...
