Old 02-03-2009, 11:58 PM   #26
4x4s4allie
4x4s4allie's Avatar
Re: i cried a little bit ...
Originally Posted by 70rs/ss View Post
If it is a 3 on the tree, pull the column apart and you may need to weld up the linkage holes on the arms, they are old and get worn out. I rebuilt my 3OTT column in my 68 4X4 Burb, i used some parts from another junk column I had and fixed it up, they never were very smooth when new so a floor shifter is a better solution, if you don't mind cutting a hole in the floor??
it has been converted already to the floor shift, but it wiggles a WHOLE lot ... i can find the gears, sort of, but its so loose and everything wiggles i grind it so much ... so if i can get it tightened up and whatnot, i think it might work??? wish me luck ...
1948 CJ-2A Jeep 3spd
1961 C2500 305 V6 4spd
1967 C-10 Long Fleetside
1968 C-10 Long Stepside 250 Saginaw 3spd
1978 Scottsdale K10 355 4spd
1983 Honda Shadow VT750
1990 Toyota 4Runner SR5 4x4 5spd
2008 Toyota Yaris
1978 Scottsdale K10 355 4spd the "Ruby Build"
4x4s4allie is offline   Reply With Quote
Old 02-04-2009, 12:01 AM   #27
Andy4639
Old member
Andy4639's Avatar
Take the linkage loose at the transmission and get it out of the truck and look at the bushings and such. If there missing are they are out of shape go buy new ones.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-04-2009, 12:03 AM   #28
4x4s4allie
4x4s4allie's Avatar
transmission's coming clear out to put the clutch in ... gonna flush it and all since that hasn't been done ... and then see what we can figure out ... good news is its supposed to be 60 on thursday ... from today's brisk high of 29 ...
2008 Toyota Yaris
Old 02-04-2009, 12:08 AM   #29
Andy4639
Old member
Andy4639's Avatar
Is it the three speed still? Take the shifter out of the truck and see if it has come apart. You might have some slop in the shifter itself.
Old 02-04-2009, 12:09 AM   #30
4x4s4allie
4x4s4allie's Avatar
its still the 3spd converted to floor ...
the best i can see, which isn't much is that the linkage joints aren't tight, looks like the bolt thru there is where there's play, but until i get it all up in the air to see, and taken apart, i can't be certain, of course ...
2008 Toyota Yaris
Old 02-04-2009, 12:14 AM   #31
Andy4639
Old member
Andy4639's Avatar
Might be a good time to buy a good shifter to go along with the clutch.
I converted mine way back when to the floor but I swaped for a 4 speed, did that for a few years then went to a auto.
