Old 02-27-2009, 04:20 AM   #26
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
Re: A daily driver, fixer-upper thread
So I sorted all that out, got it straight in my head, then started looking at how to further upgrade to the CS alternator that came with the ’95 serpentine drive. The factory plug on the CS contained only one wire, which was, appropriately, a brown one.
Here’s the pin assignments for the CS:
"P" Not used.
"L" Hooked to key power (a switched ignition source). Turns the regulator on and connects to the original brown wire. If this circuit has a dash warning light, you're fine. If it doesn't you need to wire a 35-100 ohm, 3+ watt resistor into it or it'll bake the regulator.
"F" Not used.
"S" Voltage Sensing wire. Connects to the red wire splice, or in my case, the added junction block on my firewall.
ACDelco makes an adapter harness to go from an SI to a CS. P/N is 8078. Long GM P/N is 12102921. It has the resistor built into the "L" wire. Delco also makes an adapter without the resistor. I cut the "SI" end off and spliced it into my harness. Evidently the regulator inside this CS is sensing power right in the alternator, hence the one-wire original plug. I hooked up the remote sensing feature anyway. A replacement one may not be internally wired the same (edit: looks like it's remote sensing now, since I enabled that circuit).
The result: a steady 14.3 volts across the battery at idle. Works great.
Bret
Check out the site's Truck Tech FAQ.
Be a site supporter.
My more-or-less pathetic build thread.
Board members I've met:
Longhorn Man
Dieselwrencher
jholley
big mike71
Lugnut64052 is offline   Reply With Quote
Old 03-24-2009, 09:58 PM   #27
ERASER5
ERASER5's Avatar
Thanks for mentioning the difference between the 12 bolt and the D-60. You saved me a big oops!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-25-2009, 04:38 AM   #28
3quartertime
My Mistress the Sea
3quartertime's Avatar
Great build thread. Very informative and easy to follow...
Thanks!!!
,,,they'd look alot better as beer cans...
'71 K20 350/350 Rusty but trusty... gone
'70 C20... gone
'88 K1500... gone
'90 C1500... gone
'91 C2500... gone
'95 C3500 6.5L Dually love this one!...
3quartertime is offline   Reply With Quote
Old 03-25-2009, 11:20 AM   #29
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice build thread keep up the good work.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-25-2009, 08:41 PM   #30
Lugnut64052
I saw over in Engine & Drivetrain you got a 6-lug Dana. Thought about commenting on the thread but then saw you had it all sorted out.
What are you going to put that bad boy in?
And thanks guys. I've kinda been stalled on it for the last few weeks, but have another picture or two to put up. Be back later.
Bret
Longhorn Man
Dieselwrencher
jholley
big mike71
Old 03-25-2009, 11:38 PM   #31
ERASER5
ERASER5's Avatar
The D-60 is going in a 70 GMC 1/2 ton. I wanted a lower gear and a posi. The D-60 has 3.54 and posi plus the bonus of one of the strongest rear end out there! The plan includes air bags over leaf springs to carry about 1-1/4 tons of water late this summer. I am still hunting a drive shaft, but so far no luck. I may have to have on built.
Some time in the future, an OD trans is going in. The 3.54 gear will be perfect.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 03-26-2009, 02:12 AM   #32
tdave00
Restoring a 68 SWB
tdave00's Avatar
Subscribing. Good info here.
tdave00 is offline   Reply With Quote
Old 03-27-2009, 10:22 AM   #33
Lugnut64052
Okay, back to the Dana 60.
Mine is a 3.54 Posi unit as well, but an 8-lug full floater. Andy drove his 'Burb home from Washington state to Ohio and thought the brakes might be okay, or at least driveable for a while.
Um....no. Once I got the rear hung in there I took the brakes apart for a look, and everything was junk. The only thing save-able were the star wheels and the brake bars. The backing plates had deep, heavy grooves worn into them where the shoes ride. Never seen that before. I welded up them up and ground them off flat.
Bret
Longhorn Man
Dieselwrencher
jholley
big mike71
Old 03-27-2009, 10:29 AM   #34
Lugnut64052
Fresh brakes.......and drums.......and E-brake cables.
Yow-wee! Cost me three times as much to fix the brakes as I gave Andy for the whole rear. Should be good as factory fresh at this point though.
Bret
Longhorn Man
Dieselwrencher
jholley
big mike71
Old 03-27-2009, 10:51 AM   #35
Lugnut64052
The more I look at this truck, the more I think it's a 1/2-ton wearing a 3/4-ton body. No matter. I'll put some fresh rear springs in it pretty soon.
Finally got it all fitted together. Got the rear half of the driveshaft shortened. It's the smaller 1/2-ton shaft but I'm going with it for now. Had to get a conversion U-joint to hook up to the Dana. The shaft has a 1310 series yoke on it, while the Dana's yoke is a 1350 series. The Precision brand part number for the conversion joint is 348. Dana/Spicer part number is 5-460X.
Here it is, wearing 8-lug steelies on the rear and 5-lug rallys on the front. Should have entered it in this month's Beater contest.
Bret
Longhorn Man
Dieselwrencher
jholley
big mike71
Old 03-27-2009, 03:41 PM   #36
ERASER5
ERASER5's Avatar
I am right behind you, but my brake system was in a little better shape, but not much. I hope to keep the drums. The rest of the wear items will be replaced... unless I figure out a cheap disc brake alternative. Hmm...I wonder if Danna 44 brake parts will fit?
How much did you shorten the rear section? About 2"?
I am hunting a factory shaft right now. LHM no longer has his d-shaft from your Dana, so I am out of luck there. I have a few more places to check before I have one made or cut. I have time and I am trying to keep costs down.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 03-27-2009, 06:53 PM   #37
Lugnut64052
No idea. One of the four-wheel drive guys probably would know, however. I like a front disk/rear drum setup personally. When you get the rear shoes adjusted up properly you get a nice, high, firm brake pedal. If you stayed with the drum system you wouldn't create any rear disk emergency brake issues to contend with either. It'd be cool though.
Near as I could tell, the Dana stuck 1 3/4" further forward than the 12-bolt, so that's how much I had the rear driveshaft section shortened. Wasn't enough however. It fit, but the transmission yoke is almost all the way in with the rear suspension loaded. If I had it to do over again, I'd shorten it 2" minimum and probably 2 1/4"
I think he ended up using his original front section. Then the rear section that came with his new rear end miraculously slipped right into his original front section. He didn't have to do any length or yoke modifications at all.
Further on down the road I'm planning on installing a Turbo 400 and a one-piece driveshaft. Saw a thread on the main forum a while back where some guys were talking about just finding a junkyard shaft out of, say, a newer extended cab truck and having it shortened and rebalanced. Much cheaper than having a custom shaft built. You would have to find one with the right joints/yokes on the ends, but I wouldn't think that'd be too tough.
Bret
Longhorn Man
Dieselwrencher
jholley
big mike71
Old 03-27-2009, 08:31 PM   #38
ERASER5
ERASER5's Avatar
Yea, I am trying to do the exact reverse of what LHM did.
Rear disc brakes are just a wish for now, but I am always looking for possible modifications.
I calculated that I will need to cut about 2". Ride height will change the needed shaft length a little bit.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 03-29-2009, 10:09 AM   #39
Lugnut64052
Well now, this is interesting. The 12-bolt I pulled out of my truck displayed this same malady. The drums were hanging about a quarter of the way off the shoes and I thought some blockhead had put the wrong drums on it. Looks like it's an earlier 12-bolt with later 5-lug axles in it.
Bret
Longhorn Man
Dieselwrencher
jholley
big mike71
Old 03-29-2009, 03:17 PM   #40
thelonerife
thelonerife's Avatar
I notice its a Highlander too. just like mine started out as. 3/4 ton camper special.\/build thread
thelonerife is offline   Reply With Quote
Old 03-29-2009, 03:52 PM   #41
VA72C10
VA72C10
VA72C10's Avatar
Nice truck, and GREAT writeup...I'm sure I'll come back to this for information as I work on my truck.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 03-29-2009, 09:01 PM   #42
Lugnut64052
I'm diggin' the 3/4-ton Custom Camper thing. It was way run down when I got it, but I wouldn't have bought any other truck, now that I've had it a while.
Bret
Longhorn Man
Dieselwrencher
jholley
big mike71
Old 04-20-2009, 10:46 AM   #43
robmrtnbb5
robmrtnbb5's Avatar
lookin good there bret
bondo bob
http://s424.photobucket.com/albums/p...albumview=grid <<<link to my stuff and project 68 step side build
robmrtnbb5 is offline   Reply With Quote
Old 04-25-2009, 01:22 PM   #44
chuckmc8
It's alsways something.....
chuckmc8's Avatar
subbing for this helpful info-thanks!
chuckmc8 is offline   Reply With Quote
Old 08-31-2009, 05:45 PM   #45
chevyndn
awsome
chevyndn is offline   Reply With Quote
Old 08-31-2009, 08:56 PM   #46
mcbassin
Still Learning
mcbassin's Avatar
Nice build, I would have made you a real good deal on a 3/4 front and rear setup. I'm planning on turning mine into a 1/2 short bed. Of course you would still have to do a full brake job front and back. Keep up the good work.
mcbassin is offline   Reply With Quote
Old 09-01-2009, 07:50 PM   #47
Lugnut64052
Heck, that's always the way it goes. Seems like you always find what you were looking for cheaper after you already get it. Actually, I have a complete 3/4-ton front end laying in wait to install, but it'll have to keep for a while. I got laid off about four months ago and work on my truck came to a screeching halt. Haven't done anything to it since. No fun money.
Bret
Longhorn Man
Dieselwrencher
jholley
big mike71
