Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-28-2009, 02:26 AM   #26
bigt76_98
Re: overcammed 350
For your combo you have too much duration and too tight of a lobe seperation that is why you have no torque, you need to be on a 112 with about 236 degrees probably max this is the cam that i had in my 11.5:1 455 pontiac with a tight 3000 stall and 4.10 and you have no combo like that
bigt76_98 is offline   Reply With Quote
Old 03-28-2009, 02:30 AM   #27
bigt76_98
Re: overcammed 350
Sorry forgot to add this yes get rid of that dp and get a vacume sec... Imo im am not new to engines or c10's just to this messageboard
Old 03-28-2009, 01:03 PM   #28
85_prairieboy
85_prairieboy's Avatar
Re: overcammed 350
Well there was one day warm enough to fire up the truck so I pulled the carb off and adjusted the secondary throttle plates but I still couldn't get it to idle slow enough to adjust the mixture. So I ended up drilling a 1/16 hole in each primary plate. A funny thing happened. It was idling too fast when I put the carb back on so I was backing off the idle speed screw and when it got to a certain point it actually increased. Must have been when it came off of the transfer slots and started using the idle circuit. The idle cleaned up a lot and I can actually leave it running at 900 rpm without having to sit there and keep it running. I have a 50cc pump to try to fix the lean pop but I haven't had a chance to put it in yet. Its still too cold up here!
85 GMC toy Lowered, newer box swap, 350 .060 over with AFR 195s, forged pistons, TCI TH350
1.83 60' 13.14 @ 100 on motor
1.49 60' 11.52 @ 116 w/150 shot
1952 Chevy truck project
1980 Z28 Camaro
1967 Camaro drag car 10.60@126
85_prairieboy is offline   Reply With Quote
Old 04-13-2009, 11:26 PM   #29
85_prairieboy
Re: overcammed 350
Well i am ashamed to admit it but I will anyway. In a previous post I said the timing was set to 36 degrees. I wanted to verify that today and lo and behold the timing was at around 23. Either the distributor moved (the bolt wasn't tightened very tight) or I set the timing without removing the vacuum line. Anyway now I have a truck that performs like its supposed to. No popping back, no hesitation, and the idle quality exceeds what I thought it ever could be(still rough but it doesn't stall). I am amazed at how much power it makes. Time for a few g-tech runs! Thanks for all the help and advice guys.
1980 Z28 Camaro
Old 04-14-2009, 02:22 PM   #30
71chevytruckguy
71chevytruckguy's Avatar
Re: overcammed 350
having that timing right make all the difference. i was up at the track and had mine about 7 degrees too low. bumped it up and knocked 4 tenths off my et and picked up 2 mph. gotta love it when it something simple. Chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 05-17-2009, 11:01 PM   #31
85_prairieboy
Re: overcammed 350
Well I got the new transmission in. I went with the TCI th350 transbrake, manual valve body, reverse shift pattern. Took the truck out for a couple gtech runs on a closed course First run 14.07 at 98 with wheel spin and surging at the top end. The second run is the one in the video and I rolled into the throttle off the line. The truck didn't surge but definately ran out of power at the top of third gear. It was 14.45 at 95 mph.
1980 Z28 Camaro
