Old 02-11-2009, 11:12 AM   #26
jlaird
jlaird's Avatar
Re: Porterbuilt replacement trailing arm Xmember
Originally Posted by porterbuilt View Post
Here's the specs on the carrier bearing:
It's out of a 95 Chevy 3500 with a 454.
The Carquest part# HB88107A.
The bore is 1.378.
JLaird- I don't know if the original style bearing will work... but this one does!
So are you saying the carrier bearing from the 95 chevy will fit on my stock driveshaft?
jlaird is offline   Reply With Quote
Old 02-11-2009, 11:14 AM   #27
m6z
m6z's Avatar
Is this required when running your rear kit? I'm not wanting to modify the cab for driveshaft clearence.
If so go ahead and build me one also and send it with the rear kit.
Any ideas on where to get a 2 pc driveshaft built?
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 02-11-2009, 11:36 AM   #28
SCOTI
SCOTI's Avatar
How well do 'modern' carrier bearings survive under duress? For example.... BBC, 4l80e, 3.73's, & 600ft lbs of torque?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-11-2009, 11:38 AM   #29
PBFAB.COM
PBFAB.COM's Avatar
From the information I have, this bearing will NOT fit on the driveshaft you have pictured. Here's what I know:
There were two different carrier bearings available; the one that you have pictured which has the mounting holes in-line with the driveshaft; and the one that I have pictured, that has the mounting holes perpindicular to the drive-shaft. The one that I have pictured is more commonly available due to the fact that it was used through the 90s. The critical diffrenece between the two lies in the bore diameters.
The one you have (carquest part# HB206FF) has a bore diameter of 1.181"
The one I have (carquest part# HB88107A) has a bore diameter of 1.378"
Also, yours has a centerline that is 1.25" taller than the one I have.
Options are:
New yolk on the driveshaft.
Modify the xmember to work for your application. I could send a tab that YOU weld in place.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-11-2009, 11:40 AM   #30
PBFAB.COM
PBFAB.COM's Avatar
I would assume they would hold up just fine. I would make sure I purchased a quality replacement part... not a chinese version if I were running that kind of torque.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-11-2009, 11:43 AM   #31
SCOTI
SCOTI's Avatar
Would be nice to not have to cut up the bottom of the floor for clearance.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-11-2009, 11:45 AM   #32
PBFAB.COM
PBFAB.COM's Avatar
Not "required" just allows the cab floor to remain in-tact.
We have a local shop build the driveshafts for us, they ask for some measurements and have it to us within a day. If you can't find a local shop to help you out, we can always have one made for you.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-11-2009, 12:30 PM   #33
jlaird
jlaird's Avatar
I was planning on using this inland bearing on my driveshaft.
I'll have to think about this...
Old 02-11-2009, 02:56 PM   #34
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Not yet... PM me.
PM sent
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-11-2009, 03:48 PM   #35
theyammieguy
accepting donations
theyammieguy's Avatar
I have a one piece driveshaft but I want one anyway.
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 02-11-2009, 07:22 PM   #36
jasonb72
PorterBuilt Man Crush
I was as well, but inland also has the other version as well if I am not mistaken.
J
The 72 will live again
jasonb72 is offline   Reply With Quote
Old 02-11-2009, 09:40 PM   #37
gringoloco
A guy with a truck
gringoloco's Avatar
Yep. This is the Inland Empire version of that support bearing:
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-11-2009, 09:50 PM   #38
jlaird
jlaird's Avatar
Can you explain what you mean by "new yolk on the driveshaft." I'm not sure how these things go together. Does the bearing press on the yolk, then the yolk attaches to the driveshaft?
Old 02-11-2009, 10:02 PM   #39
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
No problem with carrier or pillar style bearings holding up with serious power. My buddy runs a 525" blown alky rear engine bogger that makes 2800 HP and 1800 TQ., the front shafts run through two pillar bearings...never a problem!! Clocked in excess of 140 MPH in 200 feet, so speed rating is not an issue!!!
crawdadfox is offline   Reply With Quote
Old 02-12-2009, 12:00 AM   #40
SCOTI
SCOTI's Avatar
Excellent. What brand of 'bearing' was used to withstand that type of power (ok not exactly that type of power . ...... but more than most OE powerplants of the 60's - 80's)? Any info is appreciated.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-12-2009, 12:25 AM   #41
PBFAB.COM
PBFAB.COM's Avatar
It is easier to explain with pictures, but the front half of the two piece driveshaft necks down at the yolk so the carrier can slide over it. It's a tight fit, but the last few I remember replacing it wasn't necessary to use a press.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-12-2009, 07:23 AM   #42
crawdadfox
crawdadfox's Avatar
Inland Empire, also have another pillar bearing on the chain drive "transfer case" behind a Lenco transmission...so thats three total with no failures or problems, and this will be the third race season.
Old 02-12-2009, 01:34 PM   #43
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
I WANT one, put it on my tab I have the inline style carrier now but was having a complete new D/L made once I got the xmember in so I can use the newer carrier fine. My old D/l has issues from PO using it to slide my poor lil c-10 burb over rocks. From here on out all she have to worry about is them manholes and sewer mains that stick up
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 02-12-2009, 02:58 PM   #44
gringoloco
A guy with a truck
gringoloco's Avatar
Me too. How do I get a PB line of credit?
PM sent.
-Chris
Old 02-13-2009, 09:22 AM   #45
N2TRUX
Happy to be here
N2TRUX's Avatar
PM sent.
Does Capitol One offer a Porterbuilt edition of their card?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-13-2009, 10:19 AM   #46
SCOTI
SCOTI's Avatar
PM sent.
There's a joke somewhere in this one . . ..... .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-13-2009, 11:54 AM   #47
RunninLo
RunninLo's Avatar
Silly! I have a credit from a previous order I overpaid for I don't think Nate should or would get into the credit game
Josh
88 4x4 crew DD
Old 02-13-2009, 09:14 PM   #48
gringoloco
A guy with a truck
gringoloco's Avatar
Left the door open didn't I? Well played Scoti, well played...
-Chris
Old 02-17-2009, 08:48 AM   #49
N2TRUX
Happy to be here
N2TRUX's Avatar
Inside joke?
Articles-
"Refining Sierra"
Old 02-17-2009, 12:56 PM   #50
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by N2TRUX View Post
Inside joke?
I hope not. I'm not making any 'prison payments'...
-Chris
