#26 |
Re: Conversion tie rod sleeve for DISC brakes on a 67-70,...
I think you're right , haven't tried it also , but looks like it will work in my old chassis parts dimension catalogues.
#27 |
![]() Join Date: Nov 2014
Anyone try this yet? I am using 73-87 drop spindles and 67 C20 center link. Would like to go with off the shelf parts but am having no luck with the 73-87 inner tie rods.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
#28 |
From what I can tell , the astro stud is to small for the c20 hole. The book dimensions on 73-87 inner 1/2 ton is allmost identical (.020 difference on taper lenght) to your 67 c20. I have used a 72-72 c20 centerlink on a 69 c10 conversion , but not your specific center link. Do 73-87 inners not fit the centerlink?
#29 |
Just called and ordered my sleeves from DCA racefab
11/16-18 is RH (right hand) and the 5/8-18 is left hand. The length for these trucks is 5-1/4" I am running 68 outers and 72 inners. probably going to have to switch them around like previous people done on this thread |
#30 |
Mjminino,
How did those tie rod sleeves work with the specs you posted above? |
