Old 09-21-2010, 07:34 PM   #26
dznucks
dznucks's Avatar
Re: 3 Speed Column Rebuild
I just rebuilt my three speed column from two donor columns i got from board members. My old column bearings went bad and the shifter housing started to go out. i wanted to build a good column and just swap them out.
I ordered my bearings from LMC or Classic Parts, cant remember, but the lower bearing is an AC Delco & GM Part #3981935, the upper bearing is gm#5679205, and the lower spring is gm#7804771.
I have some left over parts that you cant buy retail, free to a good home. If someone wants them or has questions PM me.
Just to throw it out there....
I stripped the old paint from the column with aircraft paint remover (from advanced auto) and then used Rustoleum's autobody primer as a base/primer. It adhered very well to the sheet metal column and the pot-metal shifter housing. after that you can lay whatever color down you want.
This is not a difficult thing to do and thanks for posting the pics, i forgot to document how i rebuilt mine.
dznucks is offline   Reply With Quote
Old 09-21-2010, 07:39 PM   #27
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
The only thing I couldnt find was the rubber bushings that go into the two shift levers on the bottom of the column that connect to the shift rods. Everything else was available.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 09-21-2010, 09:03 PM   #28
70c/10barebone
Junior Member
70c/10barebone's Avatar
Those rubber bushings for the shift arms are avaliable from classic parts. you need to reuse the original metal sleeve/spacer.
http://www.classicparts.com/1947-76-...ctinfo/91-062/
70 C/10 LWB 250
70c/10barebone is offline   Reply With Quote
Old 09-22-2010, 08:11 AM   #29
dznucks
dznucks's Avatar
Thats where i got mine too. they have the transmission linkage bushings too.
Old 01-30-2011, 09:35 PM   #30
kursed
kursed's Avatar
WOW! Sorry for the NEVER update guys! I'm a huge procrastinator and completely forgot about this thread.
Ok, I sold the truck that I was having issues with, so the donor column is still torn apart in my basement. I still have a 70 longbed that it will go in when finished. I used the 3 speed adjustment article and it solved my shifting problems so I just dealt with the column slop issues. Then got overall burnt out on the truck so she's gone. Now I'm looking for another. Found a 72 shortbed automatic truck I may trade my 57 VW for, but we'll wait and see what happens on that one. In the meantime I'll try to get motivated and update this thread soon. Sorry again for slacking.
kursed is offline   Reply With Quote
Old 01-30-2011, 09:39 PM   #31
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Pics of VW?
John
1999 Toyota Tacoma 4x4
Old 01-30-2011, 09:50 PM   #32
kursed
kursed's Avatar
$4500 PM or e-mail me at xkursedx@hotmail.com for more info and pics
Old 12-10-2017, 07:54 PM   #33
sharkskinman
Damnit those pictures no longer show up
sharkskinman is offline   Reply With Quote
Old 12-10-2017, 11:15 PM   #34
zosoppp
There is a fix for the photo bucket heist.
http://67-72chevytrucks.com/vboard/s...d.php?t=747742
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights
zosoppp is offline   Reply With Quote
Old 12-11-2017, 03:42 AM   #35
In The Ten Ring
I would like to rebuild my shifter at some point, no desire to get rid of 3OTT.
In The Ten Ring is offline   Reply With Quote
Old 12-14-2017, 07:18 PM   #36
oldchevy07
I am new here so I may have missed this if previously covered. I have a 64 C10 and am having issues with the 3OTT (sloppy shifting if I can find the gears), and would prefer to stay stock, or as close to as possible.
I took it into my mechanic and he says he will need the following parts:
Two- 3771727 Lever Assembly
One- 3773472 Tube Assembly
https://imgur.com/gallery/htPbs
These parts numbers from the catalog (page linked) are obsolete. If anyone has any direction, I would appreciate it. I have contacted classicparts to no avail and waiting to hear back from oldchevytrucks.
oldchevy07 is offline   Reply With Quote
Old 01-13-2018, 01:02 AM   #37
vetnat
Hi oldchevy. Just stumbled across your post, know its a bit old. I rebuilt a 1969 3OTT column for my 61 last spring (has a collapsible shaft to prevent impalement in accident). Not sure if the shift tube is the same between those years or not, but when I was looking for parts, there was a NOS shift tube for sale on Ebay, for about $100 if I recall. I got the GM part number from my local dealership parts counter (they still have the old parts books) and then googled the part number. The lever closest to the end is a separate piece (can sometimes find for sale on this site, or try Ebay), the lever above it is all in one piece with the shift tube, IIRC.
1961 GMC half ton, short step, Canadian model. Just starting work on it.
vetnat is offline   Reply With Quote
