Old 02-28-2009, 06:47 AM   #26
S10Fan
Old Heap Driver
Re: Scotts hot rods full frame
One of the welds looks to be off by 1/128th of an inch, fix that and it's perfect.
LOL.
Awesome work!
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 02-28-2009, 09:37 AM   #27
jlaird
jlaird's Avatar
What flare do you guys use on your brake lines, 37 or double 45?
By the looks of the sleeves and tube nuts, 37 AN?
jlaird is offline   Reply With Quote
Old 02-28-2009, 01:26 PM   #28
Scottshotrods
our brake lines are flared at 37 not 45.
Justin
www.scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 03-01-2009, 01:44 PM   #29
BurbDude454
BurbDude454's Avatar
Have you ever had a problem running aluminum AN fittings in a brake system? I was looking in to doing that, but was concerned about the pressures reached.
-Justin
BurbDude454 is offline   Reply With Quote
Old 03-01-2009, 03:36 PM   #30
68 short step
-Justin
i can guarentee you that those fittings wont fail.....i use-to test hoses/fittings, that went on aircraft....and i can tell ya that -3 or -4 size fittings/hoses got pressure tested to 3 times its intended pressure.......ive tested -3 and -4 hoses/fittings/lines to 6-10,000 PSI with no failures...
68 short step is offline   Reply With Quote
Old 03-01-2009, 05:21 PM   #31
Scottshotrods
we have never had any problems with
any of -3 or -4 or -6 or -7 or -8 or -10 fittings.As long as your flares are done correctly.
Justin
Old 03-01-2009, 06:55 PM   #32
jlaird
jlaird's Avatar
If you use stainless line, can you use the aluminum fittings, sleeves, and nuts or do you need stainless fittings, sleeves and nuts?
Old 03-01-2009, 10:53 PM   #33
Scottshotrods
On all of our chassis we build and cars and trucks we build.
We use s.s line for brake lines and fuel lines and we use
aluminum fittings on both and we have never had any
fail.In the chassis pic you see that is all s.s line.
Justin
Old 03-04-2009, 11:14 PM   #34
Scottshotrods
anybody interested we have
a chassis starter package
starting at $6000.00 this
will be less brakes,axles,3rd
member and brakelines
no motor mounts or tranny
mount.Anybody interested
pm us or call us (805)485-0382
justin
Old 03-05-2009, 07:51 PM   #35
jephs422
justin
Dang....
Well, if that's the case you can have a complete roller for dirt cheap. If anyone's interested drop us a line...
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
jephs422 is offline   Reply With Quote
Old 03-10-2009, 09:35 PM   #36
Scottshotrods
we have some more great deals on our chassis give us
a call at the shop and you
will see what you can get.
(805)485-0382
justin
Old 03-29-2009, 09:22 PM   #37
Scottshotrods
we can build a tube chassis
on air bags on all 4 corners
for a short bed or a long bed.Look at the pics and ask any questions you might have.
Justin
Old 03-29-2009, 10:24 PM   #38
EJC78
No Life Like Low Life
EJC78's Avatar
Whats up Justin, it's Eric the Bail Bondsmen from San Jose. Dang that frame looks bad @ss! Still working on my 78 but I really need a frame. I was thinking of ordering some mandrel bent frame rails from autoweld and having you install the IFS kit I bought from you and do some crosmembers. Would you be interested in doing something like that?
Eric
1978 Chevy Scottsdale
1960 Impala ZZ4
1965 Buick Riviera GS
2011 GMC Sierra Denali
EJC78 is offline   Reply With Quote
Old 03-29-2009, 10:52 PM   #39
Scottshotrods
Erik,
No problem we will take care of you call me at the shop so
we can go over the chassis for your 78
Justin
Old 03-30-2009, 01:58 AM   #40
C10Sim
C10Sim's Avatar
Jeph,
Can you explain how them bones (or setup) work?
What are thier purpose?
Can this setup be dont on a factory 68 c10 frame?
Will that lay 32inch tire?
EXCELLENT WORK!!!
1968 Chevy Pickup
http://67-72chevytrucks.com/vboard/s...d.php?t=321717
1959 Chevy Apache 3100 SWB Big Window
http://67-72chevytrucks.com/vboard/s...d.php?t=597069
C10Sim is offline   Reply With Quote
Old 03-30-2009, 02:15 AM   #41
six5
six5's Avatar
What spindles are used on this front end.........??
-Dave
My 1965 build...http://67-72chevytrucks.com/vboard/s...d.php?t=331302
six5 is offline   Reply With Quote
Old 03-30-2009, 09:10 AM   #42
N2TRUX
Happy to be here
N2TRUX's Avatar
Dave they use Mustang II spindles. I don't know what brand though.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-30-2009, 11:47 AM   #43
six5
six5's Avatar
NTRUX thanks for the info. I was talking in another post that a MII front end is another good choice for our trucks. And thought I had looked at a vendor on here using MII components. Thanks for the clarification. That is the same setup they are using for the c-10 truck kits. They actually make those control arms them selfs.
-Dave
Old 03-30-2009, 01:29 PM   #44
jephs422
C10Sim
The "dogbones" are essentially struts that do 2 things. First, they hold the rear axle in place. With our 2 bar style set up an upper link is necessary since we use a bushed joint for the lower mount, e.g, to keep it from swiveling. Second, it's adjustable and you can adjust and set your pinion angle with it.
six5
Yes they are a Mustang II style spindle, however that begs me to note that although we do use a mustang II style spindle, the suspension is not a Mustang II (most of you know that already)
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 03-30-2009, 01:50 PM   #45
six5
six5's Avatar
Please explain the difference between the dimension of a MII front suspension and yours? I realize you control arms may be different lengths. But would a MII control arm bolt up to your cross member?
Originally Posted by jephs422 View Post
C10Sim
six5
-Dave
Old 03-30-2009, 01:56 PM   #46
six5
six5's Avatar
After looking at a MII cross member and your C-10 I realize they are different. But they seem like your setup was engineered around a MII setup using C-10 measurements?
-Dave
Old 03-30-2009, 04:44 PM   #47
jephs422
Actually no they won't.
The difference between the two is pretty simple, it's like the difference between the front suspension on a 88 ford ranger, and a 2009 GMC Yukon. Two different cars/trucks, and two different suspensions completely. Yes, the spindles might look similar, and maybe the crossmember is vaguely similar also, but that doesn't make them the same.
With each and every car we build a front suspension for, we take the dimensions of the frame rail and "design, engineer, and build" a unique, one-off suspension. We do not have any a-arms laying around on the shelf, nor de we have cross members piled up in the back. If you order a suspension and need a unique ride height, that's what it'll be built too. If you need a little bit narrower track, that's what we'll do.
Basically imagine the the CEO of Ford Racing was building himself a one off race car. Do you think he'd pull the suspension off of something he had laying around? No, he'd have his engineers design, and build him the best working suspension for the parameters of that vehicle. Well, that's what we do.
The Mustang II spindle is simply used so that brake parts and bearings are redily available.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 03-30-2009, 05:16 PM   #48
six5
six5's Avatar
Thanks.....
-Dave
