Old 03-03-2009, 12:35 AM   #26
cedorris
1972 Chevy Cheyenne Super
cedorris's Avatar
Re: Seatbelts: Why used when LMC has them?
I planned on keeping my factory lap belts in my 72. Is this not advisable?
cedorris is offline   Reply With Quote
Old 03-03-2009, 12:51 AM   #27
COc10cst50th
my truck is a 68, no seat belt is required for me.... hehe.
on the otheehand, i will be installing full 3point seatbelts in my truck, becaus i plan on having to transport my daughter in my truck and her saftey is #1.
1968 C-10 CST LWB 50th anny
work in progress.
Coloradical Lowlife
COc10cst50th is offline   Reply With Quote
Old 03-03-2009, 01:04 AM   #28
tekno62
I want to add them for my kids safety as well as my own.
tekno62 is offline   Reply With Quote
Old 03-03-2009, 09:09 AM   #29
I wish someone made original looking modern shoulder/lap belts.I`d pay good money for those.I think Cheyenne Super Man does.
Old 03-06-2009, 08:24 PM   #30
ratpackv8sonly
ratpackv8sonly's Avatar
Well they came in on wednesday. Love LMCs shipping time. So here are the pictures of the belts and hardwear. I will get the instaltion pictures up tonight.
This is the shoulder belt
This is the lap belt
The baged hardwear that comes with the shoulder belts
The three bolts are to small to use in the factory holes but the big flat washers wil be needed on the bottom of the floor for one of the holes that will need to be added.
ratpackv8sonly is offline   Reply With Quote
Old 03-06-2009, 08:33 PM   #31
texanidiot25
Eat My Rust
texanidiot25's Avatar
Grade 8 bolts I assume?
And what needs the new hole? I assume the retractor eh?
texanidiot25 is offline   Reply With Quote
Old 03-06-2009, 08:38 PM   #32
ratpackv8sonly
Some more pictures.
These are the 3 point shoulder belts now. The first pictures above are of the lap belt and a few of the shoulder belt. Lap belt had a gray cover on the buckel and the shoulder belts have a black cover.
Old 03-06-2009, 08:44 PM   #33
ratpackv8sonly
Yess all grade 8 bolts. And verry good looking bolt as well. Not like some of the cheep looking bolts you get lately with things.
You will need to add one hole to the cab floor. I used the original belt hole for the retractor but you need to add one hole infront of it for the othe part of the lap part of the belt. Remember these are THREE point now. Every point should have its own bolting point to the floor. I will get more picture of the belts in the cab up in a few. Only have one side done. About an hour of work. I will also show you the extra hardwear that I had to buy.
Old 03-06-2009, 08:47 PM   #34
ratpackv8sonly
Sorry for the spelling errors. Texting and typing at the same time
Old 03-06-2009, 08:48 PM   #35
texanidiot25
Eat My Rust
So the retractor side is bolted down on 2 areas?
That's one thing I did like about the S10 belts, one hole for each side. Though with my buckets, both had to be added since the retractor hit the gas tank on the driver's side, and the buckle side wasn't long enough to be mounted in the stock bolt holes.
Backed all holes with 1/8th steel plate and body washers. Solid
Old 03-06-2009, 09:10 PM   #36
ratpackv8sonly
The instruction were so simple.....looked like a caveman drew them
The bolt hole in the cab did have the same threads as the supplied bolt for the top of the shoulder belt.
Here I added 2 grade 8 flat washers so the supplied lock washer didnt just dig into the cab and it didnt really lock down well on the shoulder of the bolt alone.
The ratchet part bolted to the factory hole. Dont know if it would clear the gas tank as I removed my leaky tank (notice stained carpet) and relocated it to the rear.
This is where I added the extra hole. Used the two supplied flat washers but used a grade 8, 1/2''x1 1/2'' long bolt with lock nut.
The drivers buckel and the center persons belt.
Old 03-06-2009, 09:17 PM   #37
ratpackv8sonly
This is where the drivers and middle belt bolt together using the factory bolt hole.
This is the extra hardwear I bought. 6 of the bolt, 6 flat washers, 6 lock washers and 2 spring washers that I used on the top of the shoulder bolt where it bolts to the cab wall.
Old 03-06-2009, 09:52 PM   #38
tekno62
Looks Sweet to me
