#26 |
Re: 1SIK69 build....
this is what we did over the weekend. Lowers and a crossmember. Kinda working back and forth between the rear set up and stripping the firewall.
#27 |
Looks really good, i had to take a double look at your cap on the diff, i was like, wtf, but never mind it is your cap for the rims, my bad, i will say one thing, that pipe you are using will be fine, but make sure that you gusset it some, front and possible the bottom, otherwise it will flex the frame and crack out, other wise great job guys.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#28 | |
#29 |
VA72C10
![]() Join Date: Mar 2008
Lookin good.....will be watching this...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#30 |
Thanks. Well today it seems like a took a step forward and then had to take 2 steps back. Hopefully tomorrow will be more productive. I got to use a manual pipe bender. That freaking sucked. We made some horse shoes to wrap around the lower bag brackets. Oh yeah and we decided to do bag on bars instead of over the axle. I am also thinking of using a wishbone as well.
#31 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Gonna be sweeeeeeeeet. Cant wait to see the final product. Keep up the good work.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#32 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Should be sweet but man that deadline is really comming up fast.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#33 |
Yeah do you still think you can make it
70 SWB STEPSIDE 70 BLAZER 09 challenger |
#34 | |
Well here is an update on what I got done the past few days. Well yesterday it rained all day so needless to say I wasn't out working on it being I am working out of a car port. I got all my valves plumbed and figured out how I was gonna run my compressors and tanks. The fitting are freaking expensive. I had to go buy about $50 worth of fittings today. I also got the holes drilled for the upper bag mounts up front. I am gonna take a wire wheel to the control arms and frame and give it a coat of flat black before I get it all together. I bought the rubber break line that runs from the calipers to hard line and the one for the back. I also ordered a new master cylinder and break booster and proportioning valve. I need to go to the pick n pull and get the break lines off a later model truck since all my breaks are off an 86 Suburban. I ordered a halnd full of stuff from LMC and ebay yesterday. So once I get a seat and break lines I should have everything to put this thing back together. Ok enough of me rambling. I will update more as it happens. |
#35 |
Today it finally stopped raining. I decided to get the frame cleaned up in the front and strip the firewall so I can get it smoothed out and ready for the motor. I probably took off about 3lbs of surface rust off the frame. The firewall had like 3 layers of paint. It was Black on top, whatever kinda paint it was it was thick, then Chevy orange, then red. I got the steering column and everyting thing else taken out so tomorrow I can hopefully start making filler plates for the holes. Here are a few pics of what I got done. Crap I hope I can remember how everything goes together. lol
![]() ![]() ![]() Last edited by 1SIK69; 03-15-2009 at 12:39 AM. |
#36 |
Ok, today the wishbone got built. Welded in the rear bag mounts and installed the front bags and ran line to the front. Here are some pics. What do yall think?
#37 |
Epoxy Primer Friendly
See you at TEX MEX
#38 |
The rear bag mount like that will cause your bar to flex and roll over. If you do them like that, they need to be centered over the bar.
#39 | |
I aint gonna make it this year. Truck has sucked all my money into it and it isn't ready. I will be there next year.
Tonight I got a few things done. Mounted the tanks and compressors. The fitting and compressors are just mocked in until after I paint the frame. I am still waiting on my tabs to mount the wish bone. We change the crossmember by the cab with the bend tubing. Tomorrow I am gonna finish working on the firewall so I can get the motor put back in and running. Still got a crap load of stuff to do. ![]() ![]() |
#40 |
lookin good. cant wait to start baggin mine some day
#41 |
#42 |
Yep its definately going to destroy your bag twist your bars and hurt the bushings prematurely if you rock the lower bag brackets like that. I would also put a gusset along your lower bar since its round tubing. Also TEX MEX will be a show no to miss this year!
#43 | |
#44 |
Got the brake lines ran and did a little firewall work yesterday. Here are a few pics before bondo and primer.
#45 |
Under Construction
keep at it. looking good.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#46 |
Thanks I appreciate it.
A little update. Not a lot done cuz of the weather.Either rain or butt ass cold. Got the firewall bondo'ed and hopefully should have it smoother totally tonight. Will post some pics when I am done with it. Then it is off to planting the motor and tranny. |
#47 |
Looks good you think your gonna make it to the show in may
#48 |
Thanks bro. Well, I better have it done for my clubs show in 2 1/2 weeks. I should. I am just about done with the firewall. Then I am gonna drop in the motor. Then it is just finalizing a few things to get it on the road. I will probably roll it without the bed to it though.
#49 |
![]() Got the firewall somewhat done. Still needs to be blocked real good before it gets paint. Time to start assembling the motor. Got the intake on and water pump painted. Gonna finish it up tomorrow. |
#50 |
OK got the motor and tranny dropped in. Time to start bolting on all the billet and the SD tranny X-member.
