Old 03-05-2009, 09:25 AM   #26
m6z
m6z's Avatar
Re: Post up your 22s
Originally Posted by au03z71 View Post
Surely, out of 577 views, somebody would know this...
I don't see a reason why they wouldn't work. If a 8.5" wide wheel works with 5 1/2" bs. Then a 9" wide wheel with 5 1/2" of bs is going to stick out 1/2" further.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 03-05-2009, 09:45 AM   #27
au03z71
au03z71's Avatar
That's what I was thinking, but I'm still on the learning curve with the back-spacing issue. I want to make sure I can tuck them...
au03z71 is offline   Reply With Quote
Old 03-05-2009, 10:47 AM   #28
m6z
m6z's Avatar
I think I'm going to stick with a 20/22 combo. You start to run out of room with a 22 on the front of these trucks. It all depends on how low your wanting to go. Check out this thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=234118
Doug
Old 03-05-2009, 11:28 AM   #29
68laydout
Junior Member
68laydout's Avatar
If you want to tuck deep and still drive on 22's you will need a narrowed track width, unless you get a wheel with mucho BS, and I think its still going to be close. The dropmember and 22x9 coys will drive ok tucked deep. Find the "Tootsie Roll" build and you will see what I'm talking about. It is discussed there.
68laydout is offline   Reply With Quote
Old 03-05-2009, 11:48 AM   #30
au03z71
au03z71's Avatar
I'm not going to put the rockers on the ground or anything. I just want the fenders to drop to the lip of the rim or so. I guess I should look for a 22"8" or 8.5" rim?
Old 03-05-2009, 11:51 AM   #31
duceducenine
duceducenine's Avatar
on my blazer i have 22 X 9.5 wheels with 265 35's
the fronts are 6 3/4 backspacing and the rear are 6 3/8....
then i added 1" adapters with makes the backspacing 5 3/4 & 5 3/8
here are pics showing how far they tuck.....
duceducenine is offline   Reply With Quote
Old 03-05-2009, 12:58 PM   #32
au03z71
au03z71's Avatar
How does it drive?
Old 03-05-2009, 01:19 PM   #33
lyrikz
PITbut
lyrikz's Avatar
I'd like to see everyone's 22" combos. I'm either going to run a 22"-20" combo or go 22" all around. Let me see em'. Give me some specs too!
See avatar...
lyrikz is offline   Reply With Quote
Old 03-05-2009, 04:04 PM   #34
68laydout
Junior Member
68laydout's Avatar
22x9 with 5.5" BS up front will be close, but should be ok. I have 18x8 with 4.5" BS which is the same as a 9" wide wheel with 5.5" BS. I'm running a 27.3" and before I pulled the inners, the top of my rim came almost to the bottom of fender at ride height and never rubbed. The tire was close but never rubbed.
Here's some old pics so you can see.
Old 03-05-2009, 06:14 PM   #35
duceducenine
How does it drive?
it drives good but heated coils all around little bumpy!!!!
Old 03-05-2009, 11:07 PM   #36
Cooleys Custom Werx
hope this helps i just moved my stock crossmember up 2" and forward 1". a lot of steering and control arm modifying but they are 22x9 coys.
Cooleys Custom Werx is offline   Reply With Quote
Old 03-06-2009, 06:43 PM   #37
lbrtzmr
odes 72
lbrtzmr's Avatar
billet specialties
odes 72
lbrtzmr is offline   Reply With Quote
Old 03-06-2009, 06:59 PM   #38
VA72C10
VA72C10
VA72C10's Avatar
Nice...the work was worth it to center the rims up nicely....looks great!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 03-06-2009, 08:46 PM   #39
Cooleys Custom Werx
thanks man.
Old 03-06-2009, 08:56 PM   #40
edflores
Originally Posted by lbrtzmr View Post
billet specialties
post more pics please
edflores is offline   Reply With Quote
Old 03-06-2009, 11:39 PM   #41
N2TRUX
Happy to be here
N2TRUX's Avatar
There's a few more here-LINK
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-08-2009, 10:39 AM   #42
rddiaz
rddiaz's Avatar
Here are some I took at last year texas showdown, I should be able to make it this year with my truck....
GROUND ZERO IS R LIMIT
rddiaz is offline   Reply With Quote
Old 04-09-2009, 03:20 PM   #43
72 Sierra Grande
What drop is duceducenine running on the blazer with his 22's or is it stock?
72 Sierra Grande is offline   Reply With Quote
Old 04-09-2009, 03:21 PM   #44
lyrikz
PITbut
lyrikz's Avatar
Originally Posted by 72 Sierra Grande View Post
What drop are you running or is this stock?
Who is this question addressed to?
Old 04-09-2009, 03:28 PM   #45
72 Sierra Grande
Sorry about the mistake.
Old 04-09-2009, 03:32 PM   #46
XXL
Seņor Member
XXL's Avatar
It's all I've got.
XXL is offline   Reply With Quote
Old 04-09-2009, 03:57 PM   #47
72 Sierra Grande
Maybe you can give me some information I am running foose nitrous 22x9.5 5.9"bs front and back with 265/40's and stock height I am looking to drop it with ece 2.5 spindles and 4" coil out back will the drop in the front effect my turnning radius as far as rubbing lock to lock.
Old 04-09-2009, 06:30 PM   #48
badblu97
Double 6's
badblu97's Avatar
22x9 Rozzi Carbon, 265/35 Hankooks, unsure of backspacing
Street Glidin!
1966 LWB Custom Cab (sold)
1982 Short Fleet (under the knife)
1998 S10 2wd Fleet
2007 Chevy Silverado Crew
2007 Harley Davidson Street Glide
badblu97 is offline   Reply With Quote
Old 04-09-2009, 07:40 PM   #49
72 Sierra Grande
Can anyone give me some help I am running foose nitrous 22x9.5 5.9"bs front and back with 265/40's and stock height I am looking to drop it with ece 2.5 spindles and 4" coil out back will the drop in the front effect my turnning radius as far as rubbing lock to lock. My truck is a 71 swb cheyenne.
Old 04-10-2009, 01:06 PM   #50
72 Sierra Grande
Hello I am new to the site and was wondering what drop you are running?
