#26 |
Size Matters
Re: C-20 Mileage.
Very interesting. I prolly should have noted that my knowledge is limited to one truck with this diff.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ![]() ![]() |
#27 |
its all about the +6 inches
Re: C-20 Mileage.
lol... it's all good. Before I found this board and was corrected, I always said my truck had a Dana rear, becouse *in my head* all 3/4 ton and one ton trucks had a dana.
#28 |
Re: C-20 Mileage.
My 72 3/4 ton GMC with the 350/350 setup gets 8-10 mpg with an Edelbrock 1406 carb (600 cfm). Towing a car trailer dropped it down to 7mpg. Then again, I found that my fuel line going from the fuel pump to the carb was rotting apart. More gas was being dumped on the ground than in the carb.
The rear end gears are 4:10s. In '72 three different rear axles were offered in the 3/4 ton. I can't remember all of the names, its been a while. When I rebuilt the rear brakes, all I know is that I have the largest rear offered that year. Which is a good thing, cause it meant I got the biggest drum brakes. My planned upgrade is to install a 700r4, cause at 70 mph, this truck screams on the highway, running on 31 inch tall tires. I picked up the trans at a wrecking yard for 80 bucks (half price day). Just need a stock torque converter and the TV linkage for my Edelbrock 1406. Dtech... check and make sure your brakes aren't dragging. This could be a problem on older vehicles, as brake parts rust and corrode.
'72 GMC custom camper 350/350 Last edited by spinning wheels; 03-14-2009 at 08:25 PM. |
#29 |
Size Matters
Re: C-20 Mileage.
Definitely always a chance to learn...I shoulda known that there was more than one possibility for a diff.. It's easy to assume but unless you have done the research, it's also easy to be wrong. The internet and this site are awesome things...to be able to share information is totally cool. Even with all of that tho, these things are 40 years old +or- a few years so to get it right 100% of the time is a task few would master. Kudos to those who get it right most of the time.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ![]() ![]() Last edited by Longhorn321; 03-14-2009 at 09:09 PM. Reason: Spelling |
#30 |
Cool Truck
Re: C-20 Mileage.
One of my dad's friends told me it had a 3.54 in it but my dad thought it was a 4.56. My brother and I have always assumed it was 3.73 or 4.10 for some reason. Is there any way to tell what gears are in it without tearing it apart?
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
#31 |
Re: C-20 Mileage.
Yes, you can mark the tires, and mark the drive shaft, and see how many turns of the drive shaft it takes to spin the tires once. Jack it up, obviously. That's a good way to approximate it.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
#32 |
Re: C-20 Mileage.
Dtech, thought of one more item you should check.
Make sure your alignment is true. Bad alignment can really cut your fuel milage down. Not to mention low inflated tires.
'72 GMC custom camper 350/350 |
#33 |
Re: C-20 Mileage.
Mine is a 350/400 combo with 4.11 gears and gets 11 mpg. 3400 rpm at 70mph, it does not do that very often.
Mark 67 c20 custom camper 55 Olds 2dr hardtop 96 mustang 11 dodge nitro |
#34 | |
Re: C-20 Mileage.
If you have a posi of any kind, jack up both rear wheels and rotate the tire 1X while counting the drive shaft turns. Take whatever drive shaft turns and compare that to the actual available gear set. For instance, if you count just over 3 turns, and you have a 12 bolt, then you have a 3.08
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#35 |
![]() Join Date: Dec 2008
Re: C-20 Mileage.
Oh, one tip I have not seen yet is, drive it easy, like you have an egg between your foot and the pedal (yes I know I sound like a Grandpa) and no I do not drive like this, but it will drasticaly improve mileage...
#36 |
Re: C-20 Mileage.
you guys are getting around 11mpg with around stock size tires and no lift. Im going to hate the gas mileage with 410s a 6in lift 36s and california traffic
![]() 72 gmc 2500 2wd drive convert ![]() My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 |
#37 |
Champagne Taste on Beer Budget
Is it me or does the exhaust look a bit restrictive?
Looks like one of the pipes are very narrow or its just the camera angle.
Coming Soon: Project 1970 Country Truck |
#38 |
Re: C-20 Mileage.
by the time the exhaust gets clear back there and through the mufflers, an over the axle pipe isn't going to restrict it much at all.
#39 |
Green club
Re: C-20 Mileage.
Try bumping your initial timing to 12-15*, but keep your total timing to around 36* all in by 2500-3000rpm. If it detonates back it off until it doesn't and keep it there.
Also, I don't know if this needs to be said or not,but make sure you have the vacuum advance hooked up and working (not when settting your initial timing though, you will be way off if you do) and have it hooked up to a ported source on your carb. On a Holley this will be the port on the upper part of the pass side metering block. Doing this will bring your idle speed down and keep your throttle blades out of the transition slots at idle keeping extra fuel from being pulled in without need. Quadrajets ARE good carbs , but as mentioned can be finiky if not set up with the right factory combo. Jets, metering rods, power piston springs, main feed well resrictor sizing and float settings has allot to do with the carb being happy on any engine. There are quite a few of different setups from the factory, and as Longhornman said mass rebuilders don't care to much about this and put in whatever they have laying around and those carbs have more of a chance of running badly right out of the box than good.... Every little bit will help, pay attention to every detail and you will be rewarded.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
