02-13-2015, 09:00 PM | #26 |
Re: Gas Tank Fillers?
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 |
02-13-2015, 09:31 PM | #27 |
One thing to remember if you are mounting the filler neck at the rear of the bed is that it needs to still be above the top of the tank far enough so that fuel doesn't run out if you have a full tank and park on an incline I remember certain models of cars with the filler in the middle of the rear being famous for that in the 60's or early 70's. You could always tell when they had a full tank because gas would run out when they parked facing up hill a bit.
I've got the filer in the bed in the 48 and it is a pain at times with every issue others mentioned previously. I'm not sure what I will do this time around but it won't be in the floor of the bed again.
02-13-2015, 10:22 PM | #28 | |
02-13-2015, 10:35 PM | #29 |
Here's what I did for my 3200 89" long bed:
The tank is from Tanks, Inc. http://www.tanksinc.com/index.cfm/pa...prod/prd73.htm It's perfect for those that don't want to fill from the bed. What I did for my fill was to cut out the original flange in the cab and found a place on the rear fender with a similar curve and welded the flange in there. I also tucked this tank in up as high as I could for clearance: |
02-14-2015, 01:16 PM | #30 |
^^nice work on that!
since in need to install my filler in the middle of my rear sill, what if i used a filler neck from a '68 camaro or a '65-'66 mustang. they are almost identical . ill post the pic of the camaro filler neck
02-14-2015, 02:10 PM | #31 | |
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
02-14-2015, 03:44 PM | #32 |
Adding mine since someone may reference this thread in the future. Fleetside bed so the side spear keeps it pretty low. I looked at in bed solutions but figured the odds were pretty good I might have the truck full (it will be used) when I wanted to fill up. Door is out of a mid 90's caravan, I made a template of the bed curve and took it to junk yard. I wanted a round door so I did not have to worry about getting it square! Has inside cable latch which I kept. I also grabbed the file tube, but did not use it, I modified the stock one and used a tailpipe adaptor to get from 2" caravan to 1.5" tank. It is pretty flat but fuel fill in on the top of the tank so after a few miles will settle down.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
