#26 |
Re: Time to go on air
Firedog has been feeling under the weather so I will give a update. Today we removed the air tank freshened up the paint & added blocks under it so it could be drained. Also installed grommets where the wiring goes thru the back panel. Added hose clamps to secure the lines once they come in so they look organized. Should get pics tomorrow. Hopefully the DOT line makes the trip tonight.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
#27 |
Front progress today.
#28 |
front progress 2
#29 |
progress front 3..A little insight. Got the front tore apart. Ruined one tie rod end by tearing the rubber or already torn. Removed the old spindles, painted the new drop spindles. found the hole for the lower control arm too big, had Gramps weld a huge washer to fill the hole in. Everything is going smoother than we figured. Now final assy coming up next work day. As my 69 is going to get wet outside the garage which is a no no.
#30 |
thanks dad it cant hurt that old thing hell mine is even older and it sits out all the time.
the front has gone very well now ready for reassembly i am using my tubular lower control arms with a drop pocket along with the drop spindles then i stepped back to think about cutting the cup down that is on the bags for the front and did some measuring and if i want to be able to drive this thing out of the drive way i wont be able to cut any off the cups since they are already the same length of the drop springs that we just took out so i am going to leave the cups alone and hopefully get back to work on this sunday eve. any questions or comments i am brand new to this airbag stuff so they are very appreciated
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black ![]() Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
#31 |
Happy to be here
![]() Join Date: Mar 2000
Are the tube A-arms dropped or just set for bags? Combining dropped spindles and lowered A-arms usually doesn't work.
#32 |
Why not? Guess we will see today then. Do have a stock set of A-Arms if we have to change em..or go back to the standard spindles what ever it takes?? Looks like everything is kosher though so far.
#33 |
well we put it all together the control arms have a dropped pocket on them the control arm it self is not bent to be lowered so i hope it works i got the pass side done today and it sets low air'd out but still have enough to get it to a decent ride height hope it works out definitely need a wheel alignment tho
#34 |
One day...
Wow looking good! Cant wait to see it aired out!
Good looking truck! ![]() |
#35 |
Heres the results after today. Firedog will give you the update on how much more needing to get completed.
#36 |
Last couple..
#37 |
VA72C10
![]() Join Date: Mar 2008
Looking good!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#38 |
If he goes lower in the back he will need to move the pipes/ mufflers in the rear.
#39 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Move those pipes/mufflers! Looks GREAT!
#40 |
here's the update from today:
got the drivers side completed and routed all the permanent lines all that is left is to do the electrical wiring. sammy is right the back won't go any lower right because the mufflers are sandwiched between the trailing arms and the bed floor so they will need moved the rear has no c notch either so after the mufflers are moved we will have to see how low it goes my plans for the air bags is mainly just for show so i dont plan on driving this really low thanks everyone for the inspiration this board is great i never would have attempted it without the great minds from here so everyone enjoy the pics its because of all of you that its gotten to this point
#41 |
Resistance is Futile
I think N2TRUX comment about the a-arms and spindles being used together is a scrub line issue. The suspension will hit the ground if your tire goes flat. Running 20's you probably wont have any issue, but check it out and be aware.
Nice looking set-up and I dig the scrounging....been doing the same thing ![]() ![]() ![]()
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#42 |
well its done today i drove the truck home and will be taking it to the alignment shop in morning then by the exhaust shop and get a quote on moving the mufflers out of the way hope they dont rape me but i got it all wired up and it will debut at the st louis Easter car show at forest park unless something crazy comes up before sunday stop by and say hi if you are there
#43 |
well i met my goal and took the truck to the forest park car show i got lots of comments on it it was well worth the hard work thanks sammy for your help
#44 |
Tot Roddin'
Ok... we need the final shots of this.
![]() Glad to hear that you met the goal for the Easter show, how was the turnout?
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#45 |
final pics are above
the rear still needs the c notch and blocks i have to work up the nerve to cut a perfectly fine swb frame the show was huge the street rod portion of the show had over 5oo cars i never did go check out the model t clubs portion of the show i was surprised that my truck was the only one showing from our year
#46 |
Tot Roddin'
I'm surprised as well, but I'm glad to hear they had a good turnout.
When you get a chance could you post a side profile shot of your truck aired out (on a level surface) before you install the C-notch?
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 04-17-2009 at 08:23 AM. |
#47 |
if you look in post 35 there is a side view of my truck aired out hope that helps there is also a pic of it aired up
#48 |
Tot Roddin'
I did see that picture, but I guess since it's a black truck (the angle, cloudy...) I'm not able to see how far the rear wheels/tires tuck in the fenderwell.
No biggie...
#49 |
One day.....
Looks awesome! ,ine will be there soon.
DZL1. |
#50 |
Looks great. If you guys see or know of any more of these trucks laying around down there, shoot me a PM. I've been scouring CL too for a truck to build. Found one for $200 w/o a title. Hoping to go look at it Sat.
I'm in SoCo, originally from Barnhart. |
